View all threadsI have N2x0 radios and I have installed the GPSDO in several of them.
Sometimes I want use the external reference and sometimes I want to use the GPS reference. Do I have to open them up and move the jumper when I want to switch or does it still honor the software command?
There are also times when I want the 1 PPS to come from the GPSDO and the 10 MHz to come from an external source. Is this doable?
Also, I think I may want to take the GPSDO 10 MHz out and feed it into a distribution amp for multiple devices. One of the outputs of the distribution amp comes back into the radio as an external reference. So, does the GPSDO keep running even when I have the reference set to external?
Thanks,
Frank
You'll have to move the jumper.
These are independently selectable, yes.
I believe all it needs is the power supply, the GPSDO is largely
independent, but "in skin".
Thanks,
Frank
USRP-users mailing list
USRP-users@lists.ettus.com
Marcus Leech
Principal Investigator
Shirleys Bay Radio Astronomy Consortium
http://www.sbrac.org
