I am just beginning to explore electronic charting and have enjoyed all the
comments about electronic vs paper charts.
I admit the technology is a bit overwhelming.
I tend to subscribe to the KISS theory.
I do not need to be able to see the rocks and mud.
My current plan is to dedicate a laptop for plotting only.
Can anyone tell me what nav. software will work with the S-57 format vector
charts available for download from NOAA?
Frank
M/V Drifter on the hard in Mobile
Fugawi ENC (http://www.fugawi.com) will handle the S-57 charts, as
well as the more common BSB raster charts, and a variety of graphic
formats so you can scan your own paper charts and use them in the
program.
Peter Bennett, VE7CEI Vancouver, B.C., Canada
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver-webpages.com/van-ps
At 11:17 AM 3/15/03 -0800, you wrote:
What am I missing here? Why are more people not taking advantage of FREE
charts from NOAA....Or are they? I have some questions for the Electronic
Charting knowledgable on the List. (Please excuse me in advance for my
These are low resolution charts. The detail like the buoy number and light
info is barely readable.
The actual resolution is about 1 to 4 over a high resolution.
Capt. Mike Maurice
Wilsonville, Near Portland Oregon
Hello all,
ignorance on this subject!)
Is the free download policy temporary? The NOAA site eludes to the
charts being made available for evaluation.
The coverage appears to be incomplete at this time. When will this
improve?
What is the future of this program? Will other charting software become
available to read these charts?
One of the 'Pros' of this is obviously the cost. What are the 'cons'?
I assume that the NOAA data is the basis for all of the other electronic
charts (chips or CD's). True?
What else are you getting for your money with C-map, Maptech, etc.
(Assuming that I don't care about the topography of the ocean floor.)
The following was pasted from the NOAA web site. What does anyone
think?
Question - Do NOAA ENC.s enhance marine navigation and will they replace the
paper chart completely?
Answer - NOAA ENC.s and RNCs will eventually replace paper charts for
vessels using electronic navigation. NOAA will continue to produce paper
charts for those users who do not choose to use electronic navigation. NOAA
ENC.s and ECS are the greatest advancement in maritime safety since the
introduction of radar to ships.
Thanks, Scott
See you all at Trawler Fest (Snow again today. I can't wait.)
the
vector
program.
-----Original Message-----
Scott Coles asked:
REPLY
In time NOAA will catch up with the paper chart coverage.
There are a multitude of issues involved in compiling the database that
drives the S-57 chart system.
Meanwhile they are doing a pre-launch promotional effort to generate public
awareness and a market demand for a product they expect to produce.
In view of the fact s-57 is an international standard endorsed by IMO for
commercial shipping, NOAA has no choice but to develop the database needed
for producing a full set of S-57 type vector charts for commercial
shipping. So yes other software programs will become available.
In the long run, S-57 will become the new charting standard for all
countries providing charts for ECDIS systems required by law on commercial
ships.
REPLY
With vector charts, it is easy for a neophyte to suppress a data layer
containing crucial information.
Knowing a feature is possible and actually enabling the feature is two
different things.
Suppose the depth contours are suppressed and the route planner forgets to
check for and set the shoal depth alarm.
Now the vessel is taken across the shoal patch at low tide and strikes
bottom or a rock.
Zooming in is a very natural inclination when running close to known
charted hazards.
Unfortunately chart scale is lost when you do that.
Chart scale is critical to the understanding of chart data.
Chart scale is decided before an area is surveyed.
Chart scale determines the spacing of survey sounding lines, and it
determines which features are actually shown and which are omitted.
Therefore, if an area was surveyed for an intended chart scale of 1:80,000
only certain specific details will be included and tithe sounding lines
will be spaced fairly far apart compared to when the final chart scale
would be 1:20,000
To get an idea of what I mean find a chart of something where both a
general sailing chart and a detailed chart is available.
Now compare the chart appearance of the same place contained in both.
Compare how the contour lines look different and consider how that might
influence your decision as to where to place a route line.
REPLY
Yes and no.
NOAA data is stored in many forms. Paper charts were originally created in
by physically drawing line on paper with ink.
The work was meticulous and painstaking. It took a long time.
When complete, checked for accuracy and verified by an independent check,
the chart was printed by creating color separations on film.
These film masters constituted the core data held for safe keeping by NOAA.
The process of converting such a picture into digital data depends on
which format the electronic chart will be delivered in.
For raster charts the actual finished print could be scanned in using a
large flat bed scanner.
This was a technique use by both Laser Plot and Maptech in the early days.
For vector charts the current practice is to obtain the database
information and use it directly.
However, before this database information can be used an interface program
must be used to convert database fields into a graphic display.
A nav-aid is an object defined by a geographic point and a sub file
describing what the image will look like on the screen.
A shore line is a series of point defined by lat/long but spaced apart
from each other.
When displayed there is software which connects the dots into a shore line.
Zooming in or out determines how many point to include or skip when
tracing the line that connect the dots.
Unfortunately, when you over zoom, a curved line stops looking smooth and
instead begins to look jagged and consisting of straight lines joining
points.
These are the points actually stored in the database.
For an area surveyed to a scale of 1:80,000 these points will be far
apart.
In many places this is the only scale of chart available right now.
When you look at the areas when S-57 charts are currently available you
will see that it coincides with areas that have been surveyed in great
detail; and large scale charts ( harbour charts) are available. Not much
point in spending time creating a database of area where the details are
missing.
NIMA ( formerly Defense Mapping Agency) also have a database of charts but
you can't assume that the two agencies will necessarily share all this
information
since NIMA is primarily focused on providing military maps and charts.
CHS in Canada started developing digital charts for public use long before
NOAA did.
When NDI was designated the official distribution source for digital
they began using the film masters for the scanner instead of the paper
charts.
The film base is more stable than paper and less subject to dimensional
distortion over time.
As far as I know NOAA is now doing the same with the charts produced by
Maptech.
Companies such as C-Map and Navionics rely on manually digitizing the
paper charts using a plotting tool and annotating key data points using a
keyboard.
This is likely how the errors I found got made.
At one point C-Map bought a share of NDI but was later compelled to sell
their share in view of the conflict of interest this situation posed.
At this time both Navionics and C-MAP pay Maptech and NDI for the data
they use in creating the latest product versiosn they offer.
Garmin does not produce very good data for Canadian waters compared to US
water because they declined to pay NDI for the data.
REPLY
When you have a database instead of a bitmap picture; a lot of additional
features can be enabled.
For example, pointing to a marina symbol will bring up the database file
describing the facility, services and limiting depth of water in the
approach channel.
Call channel, and even a picture of the approach or an overhead view of
the place.
This is much like what you might expect from the Coast Pilot book but is
not limited to just navigational information.
As an example CHS is already experimenting with including advertisements
from commercial establishments; restaurants fuel dock and tackles shops, not
to mention shopping centers, taxi and hotels.
These value added features are dependent on the individual third party
vendors and not all features will be available from all companies.
REPLY
Wishful thinking based on projecting present trends into expected future
developments.
It is also based on the assumption that the users are knowledgeable and
trained navigators. ( ? valid assumption?? )
It further assumes that the users of vector charts and ECS equipment have
been properly trained in all aspects of navigation using this equipment.
While this is true for commercial mariners holding USCG tickets, it is not
necessarily true for all marines who may not have received proper training
in other parts of the world.
In fact last year there was a major kafuffle when it was discovered that a
lot of certificate blanks had been stolen.
In recent times, it has also become apparent that not all maritime
academies have the same high standards for their curriculum.
But what about recreational boaters like ourselves?
In Canada and the US there is training available from the Power Squadrons,
the UK have the Yacht Master program and other countries each have
something.
BUT, very few of these have a comprehensive program that really teach
electronic navigation using ECS or ECDIS equipment.
I am willing to bet most of our list members are self taught when it comes
to using ECS.
So what of the rest of the recreational boaters? How can we be assured
these people also understand how to properly use ECS and e-charts.
Do they even realize the pitfalls you can encounter? I doubt it!
So, while this technology is the best development yet, it remains to be
seen if it will actually produce the overall benefits speculated in the
hype.
Cheers
Arild
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.423 / Virus Database: 238 - Release Date: 11/25/2002
If anyone lurking is from NIMA or NOAA, I can safely say you will be
heroes with the cruising community if you add grocery stores, Post
Offices, and libraries to the charts.
I'm also trying to get Microsoft to add a grocery store category to
Streets & Trips. Between Streets & Trips and The CAPN, I can usually
find my way around a new cruising area and Streets and Trips uses my
little Deluo GPS to establish position when I rent a car..
Regards.....
Phil Rosch
Old Harbor Consulting
M/V "Curmudgeon" Marine Trader 44 TC
Currently Moored in Fort Pierce, FL
"Twenty years from now you will be more disappointed by the things you
didn't
do than by the ones you did do. So throw off the bowlines. Sail away
from
the safe harbor. Catch the trade winds in your sails. Explore. Dream.
Discover." - Mark Twain
before
NOAA did.
charts.
dimensional
Maptech.
It's called "copydot" scanning. Each of the four (Cyan, Magenta, Yellow
and Black) films are scanned, dot for dot, and then registration
(dimensional) adjustments can be made to the resulting bitmaps. The
files may then be distributed to any number of different printing
facilities for reproduction.
In the publication world this is a dying art. Although there are a few
who still believe the only way to insure the accuracy of distributed
digital (graphic) data is by means of a bitmap (like Maptech raster
files), the industry has finally come around to realizing the benefits
of PDF as the container. PDF has, pretty much, become the de-facto
standard for distribution of publication graphics. Don't minimize the
importance. A full page ad in Time magazine or the New York Times
newspaper ain't cheap and errors or omissions can be very serious
indeed.
I would suggest that NOAA will, eventually, catch up to the IRS and
distribute ENCs in PDF. However, there may be considerable pressure
from parties with vested interest for this not to happen.
Thanks for a great dissertation, Arild!!
-fred
Thank you Arild,
Your reply to my post was very enlightening.
We are planning a Great Loop adventure in 2007 and I am starting to think
about what primary method of navigation I will use (paper charts, e-charts
w/ dedicated plotter or e-charts with a PC). My first inclination is for
the PC approach. Obviously I will have paper charts on board at least as
back-up. (I am not looking to re-visit that discussion!)
Do you think that dedicated chart plotters will become obsolete in the
(near) future? It appears to me that a PC is a valuable tool to have
available in any case, so why not use it for real time navigation as well as
trip planning, e-mail, Internet, etc.
My inclination at this point would be to use Maptech products on a laptop
because of their alliance with NOAA and because they are not trying to sell
me any hardware.
For my local area, region 2, a full blown set would be installed however it
would be tempting to download and use free charts for an area that will be
visited for only a relatively short time.
I assume that Maptech's Offshore Navigator software doesn't read the S-57
charts, so that means that a second nav program would be required. This
might be loaded on a second PC (for redundancy).
We currently are looking for the proper boat for us so at this time, I have
no particular preference based on existing equipment. Obviously, if we find
a boat with state of the are electronics (not likely!), that might dictate
which direction I would head. More likely will be an 80's vintage with 80's
vintage electronics.
What are your thoughts?
Thanks again,
Scott Coles
Two more days till T-fest!!
the PC approach.
snip<<
REPLY
Dedicated chart plotters will continue to be in use for some years to come.
After all t they are just a computer with specialized keys instead of a
keyboard.
However they do not suffer from some of the common problems encountered with
laptops.
Check the archives for an in-depth thread on this subject last fall.
Laptops will continue to be perceived as a cheap solution to acquire
computing horsepower for a variety of tasks.
It is viewed as a general purpose box into which you can now load task
specific software.
So far so good.
However programmers being what they are cannot resist tinkering and won't
leave well enough alone.
After all its only a few more lines of code - right? :-(
Like any general purpose tool it does many things fairly well but none of
them perfectly.
Chart plotters are specialized tools designed for one task only and usually
they do this to perfection!
The very fact you speak of " why not use it for real time navigation as well
as
trip planning, e-mail, Internet, etc" says it all. This is simply asking
for problems.
the resource conflict and interaction between various programs may cause
problems and sometimes crashes.
The eye candy of glitzy features and dazzling graphic displays is what
consumes most of the computing power and memory not to mention demands
speed.
So pay your money and take you chance!
Or, you can review the numerous and sometimes lengthy threads on this
subject in the archive and really learn something.
At least then you will be making an informed decision.
Good luck
