Dear Mike,
I have a smaller version of this gen-set MDJE 7.5 KW on an 1981
Silverton 37 convertible. The beast of a machine rattles like hell when
running. It sounds like hammer beating an anvil (this was an actual
quote from the Onan rep. Seems they were made for Tanks in WWII. Noise
wasn't an issue. At any rate I had the same leak....it started small
until one day it would just not hold any oil at all. The oil pan is
cast iron and the drain tube is just black iron pipe. As you look at it
(I had to pull the gen-set to finally see it) it will appear that the
drain pipe is beating against the drain pan. Over the years it will
just crack on the threads. See if you can unscrew the drain pipe and
check the threads for a crack. Mine was about an 8th inch gap. I cut
off the bad threads, turned it around and used it again. I figure I
should get another 23 years out of it. (the damn things never seem to
die)
Hope this helps.
J. Peter Zimmer
