Now I am interested in low-g oscillators.
http://www.freqelec.com/oscillators/g-comp_qz_brfg_04-07.pdf
Which accelerometer is selected in the low-g oscillator?
How to hack my normal oscillator to low-g one ?
Any other suggestion?
wei
Hi
Are you interested in simple tip over compensation or are you really after vibration compensation? If so, to how high a frequency? To what levels of vibration? On what sort of oscillator?
A fairly simple 2G 3 axis accelerometer can compensate just about any oscillator for tip over. There are some fairly cheap digital ones out there from several semiconductor outfits. The question would be - how fast can I tip it? Some oscillators respond to temperature effects of a tip as well as gravity. That's going to slow things down a lot. The simple approach wold be to pick another oscillator, that may not be an option in your case.
Lots of options / questions / routes to run down. Lots of answers that all start out with "that depends ...".
Pretty much the best case hardware for vibration:
Even with all that stuff, you need to ask, how far down do you want to compensate, and at what frequency?
Bob
wei
