time-nuts@lists.febo.com
Re: [time-nuts] Conducting Bench Top Material
JF
J. Forster
Sat, Jan 30, 2010 4:10 AM
The attached spectrum is from a Circline Fluourescent that screws into a
table lamp.
-John
On Fri, Jan 29, 2010 at 08:00:41PM -0800, J. Forster wrote:
I believe that is correct, but don't have a part number on the LED to
verify it. It's certainly NOT a line spectrum.
BTW, I also looked at a CFL and there were plenty of lines.
The mercury vapor discharge in those has lots of visible light
lines - especially green and blue if I remember correctly (could obviously
look it up)...  so you have a mixture of phosphor output and direct light
from the mercury vapor...
-John
Dave Emery N1PRE/AE, die@dieconsulting.com  DIE Consulting, Weston, Mass
02493
"An empty zombie mind with a forlorn barely readable weatherbeaten
'For Rent' sign still vainly flapping outside on the weed encrusted pole -
in
celebration of what could have been, but wasn't and is not to be now
either."
The attached spectrum is from a Circline Fluourescent that screws into a table lamp. -John ============= > On Fri, Jan 29, 2010 at 08:00:41PM -0800, J. Forster wrote: >> I believe that is correct, but don't have a part number on the LED to >> verify it. It's certainly NOT a line spectrum. >> >> BTW, I also looked at a CFL and there were plenty of lines. > > The mercury vapor discharge in those has lots of visible light > lines - especially green and blue if I remember correctly (could obviously > look it up)... so you have a mixture of phosphor output and direct light > from the mercury vapor... > > > >> >> -John > > > -- > Dave Emery N1PRE/AE, die@dieconsulting.com DIE Consulting, Weston, Mass > 02493 > "An empty zombie mind with a forlorn barely readable weatherbeaten > 'For Rent' sign still vainly flapping outside on the weed encrusted pole - > in > celebration of what could have been, but wasn't and is not to be now > either." > >
CH
Chuck Harris
Sat, Jan 30, 2010 7:17 AM
AARGH!  No wonder those things hurt my eyes!
One of my biggest concerns with the circline fluorescent lamp in my Luxo
magnifier is it burns my hands with UV when I work under it.
-Chuck Harris
table lamp.
-John
AARGH! No wonder those things hurt my eyes! One of my biggest concerns with the circline fluorescent lamp in my Luxo magnifier is it burns my hands with UV when I work under it. -Chuck Harris J. Forster wrote: > The attached spectrum is from a Circline Fluourescent that screws into a > table lamp. > > -John >
MD
Magnus Danielson
Sat, Jan 30, 2010 1:22 PM
table lamp.
This is the type of spectrum I would like to avoid.
Continuous spectrum and warm white is my preference for normal light.
Fluorescent "sky blue white" is what I don't want.
Cheers,
Magnus
J. Forster wrote: > The attached spectrum is from a Circline Fluourescent that screws into a > table lamp. This is the type of spectrum I would like to avoid. Continuous spectrum and warm white is my preference for normal light. Fluorescent "sky blue white" is what I don't want. Cheers, Magnus
JF
J. Forster
Sat, Jan 30, 2010 5:30 PM
In general I agree, but the blue-white LED flashlight is pretty useful for
looking inside electronics.
-John
table lamp.
Cheers,
Magnus
In general I agree, but the blue-white LED flashlight is pretty useful for looking inside electronics. -John ============= > J. Forster wrote: >> The attached spectrum is from a Circline Fluourescent that screws into a >> table lamp. > > This is the type of spectrum I would like to avoid. > > Continuous spectrum and warm white is my preference for normal light. > Fluorescent "sky blue white" is what I don't want. > > Cheers, > Magnus > >
