trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Re: T&T: VHF Antenna Question
G
ghechtman@aol.com
Thu, Feb 8, 2007 6:08 PM
Milt, I have forwarded this to the DA people I know and they will contact you. Non-reponse on their part is extremely unusual.
The first question is, where are you?
In some situations an 8 ft 6db will indeed "outperform" a 16' 10 because the higher gain 10, with its narrower field, will "miss" a particular station. This can particularly happen at dock. The 16' 10db will be in it's element when you are out at sea.
Tear down a Shakespeare and a DA side by side sometime if you want to compare quality. Disclaimer : a division of my company distributes DA cellular amps and repeaters. I have seen the comparison test when an offshore oil service company was doing a "beauty contest of suppliers.
George
-----Original Message-----
Subj:  T&T: VHF Antenna Question
Date:  Thu Feb 8, 2007 10:35 am
To:  TrawlerWorld List - Post Messagetrawlers-and-trawlering@lists.samurai.com
This is to ask if anyone might have an explanation for something very odd happening with a couple of VHF antennas on my boat.  What's happening mystifies me and my electronics tech--it ain't supposed to happen but it does!
The boat has a Digital Antenna model 532 VW-R 16-foot 10 DB gain antenna that does not function properly.  It is mounted on the cabin top of my Nordhavn 47.  A few feet away is a DA 8-foot 6 DB gain antenna also mounted on the cabin top at the same exact level.  The antennas are mounted so there is no shadowing from one another or any other antenna or structure.  The two antennas feed identical Standard Horizon QUEST VHF radios.
The problem is that the 6DB gain antenna outperforms the 10 DB gain antenna by a wide margin.
To confirm this, my dealer and I swapped antenna leads--no matter which radio we use, the 6
outperforms the 9 by about 50% when bringing in distant stations.
Based on that, it appeared to me that something had gone wrong with the 10 DB gain antenna,
so we obtained a brand Digital Antenna model 532 WV-R 9 DB gain antenna and tried it.  The PL-259
(end fitting) used was the one furnished by the manufacturer with the antenna, and we ran the cable
straight from the antenna to both radios with no additional cables or connections.  We had identical
results: the 6 DB gain antenna outperformed the taller 9 DB gain antenna by 50%, as judged by
bringing in a weak station--we used a NOAA weather station.
Neither my technician nor I has an explanation for this.  Clearly, the taller, higher-gain antenna
should outperform the shorter, lower-gain one.  But here we have two cases where that is not
happening.
I spec'd Digital Antenna brand antennas because I felt they make the best.  Now I am thinking it't
time to go back to Shakespeare, whom I used for many years--especially so, since I cannot get a
anyone from Digital Antenna on the phone to talk to me about this.  Also, no e-mail response to
a request for advice left on their website.
Any ideas what's happening here?  My best explanation is some kind of systemic problem with the
10 DB antennas.
Many thanks for your ideas,
--Milt Baker
Nordhavn 47 Bluewater
954-610-5193
http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering
To unsubscribe send email to
trawlers-and-trawlering-request@lists.samurai.com with the word
UNSUBSCRIBE and nothing else in the subject or body of the message.
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
Milt, I have forwarded this to the DA people I know and they will contact you. Non-reponse on their part is extremely unusual. The first question is, where are you? In some situations an 8 ft 6db will indeed "outperform" a 16' 10 because the higher gain 10, with its narrower field, will "miss" a particular station. This can particularly happen at dock. The 16' 10db will be in it's element when you are out at sea. Tear down a Shakespeare and a DA side by side sometime if you want to compare quality. Disclaimer : a division of my company distributes DA cellular amps and repeaters. I have seen the comparison test when an offshore oil service company was doing a "beauty contest of suppliers. George -----Original Message----- From: Milt Baker <miltbaker@mindspring.com> Subj: T&T: VHF Antenna Question Date: Thu Feb 8, 2007 10:35 am Size: 2K To: TrawlerWorld List - Post Message<trawlers-and-trawlering@lists.samurai.com> This is to ask if anyone might have an explanation for something very odd happening with a couple of VHF antennas on my boat. What's happening mystifies me and my electronics tech--it ain't supposed to happen but it does! The boat has a Digital Antenna model 532 VW-R 16-foot 10 DB gain antenna that does not function properly. It is mounted on the cabin top of my Nordhavn 47. A few feet away is a DA 8-foot 6 DB gain antenna also mounted on the cabin top at the same exact level. The antennas are mounted so there is no shadowing from one another or any other antenna or structure. The two antennas feed identical Standard Horizon QUEST VHF radios. The problem is that the 6DB gain antenna outperforms the 10 DB gain antenna by a wide margin. To confirm this, my dealer and I swapped antenna leads--no matter which radio we use, the 6 outperforms the 9 by about 50% when bringing in distant stations. Based on that, it appeared to me that something had gone wrong with the 10 DB gain antenna, so we obtained a brand Digital Antenna model 532 WV-R 9 DB gain antenna and tried it. The PL-259 (end fitting) used was the one furnished by the manufacturer with the antenna, and we ran the cable straight from the antenna to both radios with no additional cables or connections. We had identical results: the 6 DB gain antenna outperformed the taller 9 DB gain antenna by 50%, as judged by bringing in a weak station--we used a NOAA weather station. Neither my technician nor I has an explanation for this. Clearly, the taller, higher-gain antenna should outperform the shorter, lower-gain one. But here we have two cases where that is not happening. I spec'd Digital Antenna brand antennas because I felt they make the best. Now I am thinking it't time to go back to Shakespeare, whom I used for many years--especially so, since I cannot get a anyone from Digital Antenna on the phone to talk to me about this. Also, no e-mail response to a request for advice left on their website. Any ideas what's happening here? My best explanation is some kind of systemic problem with the 10 DB antennas. Many thanks for your ideas, --Milt Baker Nordhavn 47 Bluewater 954-610-5193 _______________________________________________ http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering To unsubscribe send email to trawlers-and-trawlering-request@lists.samurai.com with the word UNSUBSCRIBE and nothing else in the subject or body of the message. Trawlers & Trawlering and T&T are trademarks of Water World Productions. Unauthorized use is prohibited.
