trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Re: T&T: New washer / dryer CORRECTION!
KW
Ken Williams
Wed, Sep 27, 2006 2:43 PM
I'm a dumb ass! I have a MAYTAG, not a Whirlpool! Sorry bout that!
Here is a link from Sears. The units are 33 1/4 high (24" wide) each so it
will slide perfectly into the KK42 opening. I also picked up a plastic
bracket that wraps around where the bottom of the dryer sits on the top of
the washer. It makes them "secure". I mentioned I do have to remove the
steps to load the washer. It a nice setup and we have used them for over a
year.
Sears item #02636922000 Mfr. model #MAH2400AWW  (WASHER)
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&pid=02636922000&
cat=Washers+%26+Dryers&subcat=Front-Load+Washers&vertical=APPL&ihtoken=1
Sears item #02646922000 Mfr. model #MDE2400AYW  (DRYER)
http://www.sears.com/sr/javasr/product.do?cat=Washers+%26+Dryers&pid=02646922
000&vertical=APPL&subcat=Dryers&BV_SessionID=@@@@0148274570.1159367249@@@@&BV
_EngineID=cdcdaddimfeejglcefecemldffidfjg.0
----- Original Message -----
To: "Ken Williams" matrix8@mindspring.com
Sent: Wednesday, September 27, 2006 9:18 AM
Subject: Re: T&T: New washer / dryer
It seems that all the offerings from Sears are now 72" high, too high to
use without major modification. I'm still on the search.
I'm a dumb ass! I have a MAYTAG, not a Whirlpool! Sorry bout that! Here is a link from Sears. The units are 33 1/4 high (24" wide) each so it will slide perfectly into the KK42 opening. I also picked up a plastic bracket that wraps around where the bottom of the dryer sits on the top of the washer. It makes them "secure". I mentioned I do have to remove the steps to load the washer. It a nice setup and we have used them for over a year. Sears item #02636922000 Mfr. model #MAH2400AWW (WASHER) http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&pid=02636922000& cat=Washers+%26+Dryers&subcat=Front-Load+Washers&vertical=APPL&ihtoken=1 Sears item #02646922000 Mfr. model #MDE2400AYW (DRYER) http://www.sears.com/sr/javasr/product.do?cat=Washers+%26+Dryers&pid=02646922 000&vertical=APPL&subcat=Dryers&BV_SessionID=@@@@0148274570.1159367249@@@@&BV _EngineID=cdcdaddimfeejglcefecemldffidfjg.0 ----- Original Message ----- From: "Keith" <keith@anastasia3.com> To: "Ken Williams" <matrix8@mindspring.com> Sent: Wednesday, September 27, 2006 9:18 AM Subject: Re: T&T: New washer / dryer > It seems that all the offerings from Sears are now 72" high, too high to > use without major modification. I'm still on the search.
