Dave,
your message:
(I just want to point out a mistake I made with the spacer required on
older Racor 500 filters. I put the spacer on the top of the filter.
This is incorrect, the spacer has to go on first then the filter. This
probably explains why my vacuum gauge hasn't moved at all. Racor told
me I have been bypassing my filter. I hope you haven't made the same
mistake.)
I am not sure I fully understand. I dont have any small spacer when I purcase
the Racor 500 filters (2010)
Are you saying I need to use a spacer under the filter?
All I get with a filter is the larger "o" ring a couple of inches in diameter
and the small "o" ring that is used on top of the housing on the handle.
Greg
Ocean Alex.
HHI, SC
purcase
diameter
handle.
Greg
Ocean Alex.
HHI, SC
Greg:
I am not an expert on this but the older 500 filters (not sure of the
cutoff year but I think it is units produced prior to January 1996)
have to have this spacer installed with the filter. The newer filters
are shorter then the older filters. Racor will give you the spacer for
free. Without the spacer, if one is required, the filter does nothing.
You can call Racor at 800-344-3286 for more info.
Dave
32' Island Gypsy
in the snow off Lake Ontario
Everyone is raving about the all-new Yahoo! Mail beta.
http://new.mail.yahoo.com
