ctbirds@lists.ctbirding.org
For discussing birds and birding in Connecticut
Hummingbird Feeder Problem
RE
Robley Evans
Sun, Jul 31, 2016 9:04 PM
Sugar water in my brand-new hummingbird feeder (plastic red-capped space
craft design) turns yellow after a day or two.  Birds will not stay to
drink, and I assume this is the reason.  Any solutions for this problem?
Thanks    Robley Evans  North Stonington CT
Sugar water in my brand-new hummingbird feeder (plastic red-capped space craft design) turns yellow after a day or two. Birds will not stay to drink, and I assume this is the reason. Any solutions for this problem? Thanks Robley Evans North Stonington CT
KV
Kathy Van Der Aue
Sun, Jul 31, 2016 10:49 PM
You need to change the sugar water in the feeders as soon as it gets
cloudy!  Mix it up yourself; 1 part sugar to 4 parts water (e.g., 1/4 C
sugar to  1 C water) put it in the microwave until it comes to a boil and
let it cool.  Meanwhile wash out the feeder with a soap and bleach solution
and rinse well.  During this hot spell I have changed my hummer food every
other day.  They can get ill and even die if they eat moldy food.  Their
tongues can swell up from the fungus infection and they starve to death.
Maybe this doesn't happen often but often enough that it's worth the extra
work.  I only fill my feeders 1/2 way during hot spells as it get cloudy so
quickly.  I have lots of juvies around right now and they may not recognize
that the sugar water has gone by so I am extra careful.  If this is too
much work for you, better to bring in the feeder and let them find other
sources.  You can put it out again when the weather cools and it stays
fresh longer.  Good luck!
Kathy Van Der Aue
Southport, Connecticut
Visit my Blog at http://naturaliststable.wordpress.com
On Sun, Jul 31, 2016 at 5:04 PM, Robley Evans via CTBirds <
This list is provided by the Connecticut Ornithological Association (COA)
for the discussion of birds and birding in Connecticut.
For subscription information visit
http://lists.ctbirding.org/mailman/listinfo/ctbirds_lists.ctbirding.org
You need to change the sugar water in the feeders as soon as it gets cloudy! Mix it up yourself; 1 part sugar to 4 parts water (e.g., 1/4 C sugar to 1 C water) put it in the microwave until it comes to a boil and let it cool. Meanwhile wash out the feeder with a soap and bleach solution and rinse well. During this hot spell I have changed my hummer food every other day. They can get ill and even die if they eat moldy food. Their tongues can swell up from the fungus infection and they starve to death. Maybe this doesn't happen often but often enough that it's worth the extra work. I only fill my feeders 1/2 way during hot spells as it get cloudy so quickly. I have lots of juvies around right now and they may not recognize that the sugar water has gone by so I am extra careful. If this is too much work for you, better to bring in the feeder and let them find other sources. You can put it out again when the weather cools and it stays fresh longer. Good luck! Kathy Van Der Aue Southport, Connecticut Visit my Blog at http://naturaliststable.wordpress.com On Sun, Jul 31, 2016 at 5:04 PM, Robley Evans via CTBirds < ctbirds@lists.ctbirding.org> wrote: > Sugar water in my brand-new hummingbird feeder (plastic red-capped space > craft design) turns yellow after a day or two. Birds will not stay to > drink, and I assume this is the reason. Any solutions for this problem? > Thanks Robley Evans North Stonington CT > _______________________________________________ > This list is provided by the Connecticut Ornithological Association (COA) > for the discussion of birds and birding in Connecticut. > For subscription information visit > http://lists.ctbirding.org/mailman/listinfo/ctbirds_lists.ctbirding.org >
RH
Roy Harvey
Mon, Aug 1, 2016 12:01 AM
I would add that the advantages of the saucer-shaped hummingbird feeders that I use (I assume others are similar) are that they are easy to clean - no unreachable corners - and that they don't hold a lot of food in this hot weather.  Also, be sure to use cane sugar sold for human consumption rather than anything sold as hummingbird food.
I don't use bleach as Kathy suggests, but I have a spare so the dirty one goes through the dishwasher (top shelf only).  Tears when I have gotten too busy I have taken it down as suggested rather than neglect it.
Roy Harvey
Beacon Falls, CT
  From: Kathy Van Der Aue via CTBirds <ctbirds@lists.ctbirding.org>
To: Robley Evans rjeva@conncoll.edu
Cc: Bird List Serve ctbirds@lists.ctbirding.org
Sent: Sunday, July 31, 2016 6:49 PM
Subject: Re: [CT Birds] Hummingbird Feeder Problem
Kathy Van Der Aue
I would add that the advantages of the saucer-shaped hummingbird feeders that I use (I assume others are similar) are that they are easy to clean - no unreachable corners - and that they don't hold a lot of food in this hot weather.  Also, be sure to use cane sugar sold for human consumption rather than anything sold as hummingbird food. I don't use bleach as Kathy suggests, but I have a spare so the dirty one goes through the dishwasher (top shelf only).  Tears when I have gotten too busy I have taken it down as suggested rather than neglect it. Roy Harvey Beacon Falls, CT From: Kathy Van Der Aue via CTBirds <ctbirds@lists.ctbirding.org> To: Robley Evans <rjeva@conncoll.edu> Cc: Bird List Serve <ctbirds@lists.ctbirding.org> Sent: Sunday, July 31, 2016 6:49 PM Subject: Re: [CT Birds] Hummingbird Feeder Problem You need to change the sugar water in the feeders as soon as it gets cloudy!  Mix it up yourself; 1 part sugar to 4 parts water (e.g., 1/4 C sugar to  1 C water) put it in the microwave until it comes to a boil and let it cool.  Meanwhile wash out the feeder with a soap and bleach solution and rinse well.  During this hot spell I have changed my hummer food every other day.  They can get ill and even die if they eat moldy food.  Their tongues can swell up from the fungus infection and they starve to death. Maybe this doesn't happen often but often enough that it's worth the extra work.  I only fill my feeders 1/2 way during hot spells as it get cloudy so quickly.  I have lots of juvies around right now and they may not recognize that the sugar water has gone by so I am extra careful.  If this is too much work for you, better to bring in the feeder and let them find other sources.  You can put it out again when the weather cools and it stays fresh longer.  Good luck! Kathy Van Der Aue Southport, Connecticut Visit my Blog at http://naturaliststable.wordpress.com On Sun, Jul 31, 2016 at 5:04 PM, Robley Evans via CTBirds < ctbirds@lists.ctbirding.org> wrote: > Sugar water in my brand-new hummingbird feeder (plastic red-capped space > craft design) turns yellow after a day or two.  Birds will not stay to > drink, and I assume this is the reason.  Any solutions for this problem? > Thanks    Robley Evans  North Stonington CT
L
Lemmon
Mon, Aug 1, 2016 12:47 AM
Are you using well water?  We always use filtered water from a Britta filter have no problems
Carol Lemmon
  From: Robley Evans via CTBirds <ctbirds@lists.ctbirding.org>
To: Bird List Serve ctbirds@lists.ctbirding.org
Sent: Sunday, July 31, 2016 5:04 PM
Subject: [CT Birds] Hummingbird Feeder Problem
This list is provided by the Connecticut Ornithological Association (COA) for the discussion of birds and birding in Connecticut.
For subscription information visit http://lists.ctbirding.org/mailman/listinfo/ctbirds_lists.ctbirding.org
Are you using well water?  We always use filtered water from a Britta filter have no problems Carol Lemmon From: Robley Evans via CTBirds <ctbirds@lists.ctbirding.org> To: Bird List Serve <ctbirds@lists.ctbirding.org> Sent: Sunday, July 31, 2016 5:04 PM Subject: [CT Birds] Hummingbird Feeder Problem Sugar water in my brand-new hummingbird feeder (plastic red-capped space craft design) turns yellow after a day or two.  Birds will not stay to drink, and I assume this is the reason.  Any solutions for this problem? Thanks    Robley Evans  North Stonington CT _______________________________________________ This list is provided by the Connecticut Ornithological Association (COA) for the discussion of birds and birding in Connecticut. For subscription information visit http://lists.ctbirding.org/mailman/listinfo/ctbirds_lists.ctbirding.org
RE
Robley Evans
Mon, Aug 1, 2016 7:13 PM
Thanks to everyone who suggested help for my rejected hummingbird feeder.
I will try to re-coup my terrible reputation among apodiforms tomorrow and
bring the feeder in for today.  I don't have a place out of the sun to hang
it, so must try something in its place.  Robley Evans North Stonington CT
On Sun, Jul 31, 2016 at 6:49 PM, Kathy Van Der Aue kathyvda@gmail.com
Kathy Van Der Aue
Thanks to everyone who suggested help for my rejected hummingbird feeder. I will try to re-coup my terrible reputation among apodiforms tomorrow and bring the feeder in for today. I don't have a place out of the sun to hang it, so must try something in its place. Robley Evans North Stonington CT On Sun, Jul 31, 2016 at 6:49 PM, Kathy Van Der Aue <kathyvda@gmail.com> wrote: > You need to change the sugar water in the feeders as soon as it gets > cloudy! Mix it up yourself; 1 part sugar to 4 parts water (e.g., 1/4 C > sugar to 1 C water) put it in the microwave until it comes to a boil and > let it cool. Meanwhile wash out the feeder with a soap and bleach solution > and rinse well. During this hot spell I have changed my hummer food every > other day. They can get ill and even die if they eat moldy food. Their > tongues can swell up from the fungus infection and they starve to death. > Maybe this doesn't happen often but often enough that it's worth the extra > work. I only fill my feeders 1/2 way during hot spells as it get cloudy so > quickly. I have lots of juvies around right now and they may not recognize > that the sugar water has gone by so I am extra careful. If this is too > much work for you, better to bring in the feeder and let them find other > sources. You can put it out again when the weather cools and it stays > fresh longer. Good luck! > > > Kathy Van Der Aue > Southport, Connecticut > Visit my Blog at http://naturaliststable.wordpress.com > > On Sun, Jul 31, 2016 at 5:04 PM, Robley Evans via CTBirds < > ctbirds@lists.ctbirding.org> wrote: > >> Sugar water in my brand-new hummingbird feeder (plastic red-capped space >> craft design) turns yellow after a day or two. Birds will not stay to >> drink, and I assume this is the reason. Any solutions for this problem? >> Thanks Robley Evans North Stonington CT >> _______________________________________________ >> This list is provided by the Connecticut Ornithological Association (COA) >> for the discussion of birds and birding in Connecticut. >> For subscription information visit >> http://lists.ctbirding.org/mailman/listinfo/ctbirds_lists.ctbirding.org >> > >
