So listees,
We're off cruising Island Eagle this summer, and as opposed to the past few
years this year we are doing things in a more leisurely fashion. Cruise a few
hours... anchor a few days... repeat.
So it's all very nice, but I realize that my charging system needs a bit of
beefing up. In the past, the 150 amp Ample Power alternator on the main had
no problem keeping the batteries (800 Ah of AGM @ 24 volts) topped up when we
were spending 6 to 8 hours underway. However, using the genset to charge the
batteries I am relying on the Xantrex SW4024 charger, which has a max output
of 150 amps. This translates to about 4 hours per day of genset run time,
which I'd like to lower.
I have about 3000 additional watts of genset capacity at my disposal, so I'm
thinking of adding a big (say 100 A) 24 volt charger. However, they seem to
be pretty thin on the ground, in fact I can find any. So my other thought is
a pair of 50 A 12 volt chargers, one for each half of the 24 volt bank. I was
looking at a pair of Xantrex XC5012
(http://www.xantrex.com/web/id/180/p/1/pt/24/product.asp). I also have
experience with Analytic Systems
(http://www.analyticsystems.com/products/bca1000.htm) so that's a possibility.
So, I'll throw the door open: any suggestions?
Scott Welch
FirstClass Product Manager
www.firstclass.com
Those who make no mistakes rarely make anything.
Victron
< http://www.lewcoelectricinc.com/index.html >
Charles
Ron Rogers
Scott,
I just went through the same exercise and Bob Campbell, my Annapolis
electrician (an Arild recommendation, thx again Arild!), suggested an
inverter instead of just a charger. So, I coupled a new Magnum 4KW inverter
(100 amp charging @ 24v) to my old ProSine with 60 amp charging. My AGM
battery bank is 470 Ahrs @ 24v, so I can charge at a rate up to 190 amps.
While at anchor I keep the bank between 50 and 85% charge...160 Ahrs or
about a one hour bulk charge now...twice a day...for a total usage of about
320 Ahrs. Seems to be working fine...
Curiously, your power usage is 50 percent more than mine. Just how big is
ISLAND EAGLE?
Bob
R C Smith Jr
M/V MARY KATHRYN
1977 Hatteras 58 LRC
South River
Annapolis, Md
