Re: [pjsip] Application crash on Windows Mobile 5.0
SF
Samer Faour
Tue, Feb 19, 2008 7:24 PM
OK so I tried running the application with each of the available
codecs in turn (by setting priority 0 for the others), and it seems
that GSM is the only codec that is working with the PDAs.
I've added the following line to improve sound quality to config_site.h:
#define PJMEDIA_SOUND_BUFFER_COUNT  16
The sound quality is not very good and I want to try to improve it
further. There is a delay of 1 or 2 seconds at times and audio
dropouts as well. The CPU Utilization is low so that's not an issue. I
did not find any audio underflows/overflows either. What else can I do?
And anyway, how can I make the other codecs work? The current behavior
is either crash of application (on pcma and pcmu) or a weird humm
[very bad understandable voice] (for
speex/8000,speex/16000,speex/32000, and ilbc). The clock rate is the
default of 8000 Hz.
Samer M. Faour
Computer and Communications Engineering
American University of Beirut
P.O. Box 11-0236/ 1461
Riad el Solh Square 1107 - 2020
Email: smf18@aub.edu.lb
OK so I tried running the application with each of the available codecs in turn (by setting priority 0 for the others), and it seems that GSM is the only codec that is working with the PDAs. I've added the following line to improve sound quality to config_site.h: #define PJMEDIA_SOUND_BUFFER_COUNT 16 The sound quality is not very good and I want to try to improve it further. There is a delay of 1 or 2 seconds at times and audio dropouts as well. The CPU Utilization is low so that's not an issue. I did not find any audio underflows/overflows either. What else can I do? And anyway, how can I make the other codecs work? The current behavior is either crash of application (on pcma and pcmu) or a weird humm [very bad understandable voice] (for speex/8000,speex/16000,speex/32000, and ilbc). The clock rate is the default of 8000 Hz. ______________________________________ Samer M. Faour Computer and Communications Engineering American University of Beirut P.O. Box 11-0236/ 1461 Riad el Solh Square 1107 - 2020 Email: smf18@aub.edu.lb ----------------------------------------------------------------
BP
Benny Prijono
Thu, Feb 21, 2008 9:56 AM
default of 8000 Hz.
I tried the latest SVN with PocketPC 2003 yesterday and it seems to
work just fine. I can make call using pcma, pcmu, and gsm fine. No
crash or anything nasty. Couldn't try with speex or iLBC since my poor
PDA is too slow for the codec.
What's in your config_site.h? Make sure it includes
<pj/config_site_sample.h> to activate WinCE specific settings.
cheers,
-benny
On 2/19/08, Samer Faour <smf18@aub.edu.lb> wrote: > OK so I tried running the application with each of the available > codecs in turn (by setting priority 0 for the others), and it seems > that GSM is the only codec that is working with the PDAs. > > I've added the following line to improve sound quality to config_site.h: > #define PJMEDIA_SOUND_BUFFER_COUNT 16 > > The sound quality is not very good and I want to try to improve it > further. There is a delay of 1 or 2 seconds at times and audio > dropouts as well. The CPU Utilization is low so that's not an issue. I > did not find any audio underflows/overflows either. What else can I do? > > And anyway, how can I make the other codecs work? The current behavior > is either crash of application (on pcma and pcmu) or a weird humm > [very bad understandable voice] (for > speex/8000,speex/16000,speex/32000, and ilbc). The clock rate is the > default of 8000 Hz. I tried the latest SVN with PocketPC 2003 yesterday and it seems to work just fine. I can make call using pcma, pcmu, and gsm fine. No crash or anything nasty. Couldn't try with speex or iLBC since my poor PDA is too slow for the codec. What's in your config_site.h? Make sure it includes <pj/config_site_sample.h> to activate WinCE specific settings. cheers, -benny
