trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Re: T&T: Hydraulic Steering Update
GL
Garrett Lambert
Sun, Aug 13, 2006 3:51 PM
Hi Larry
I appreciate your comment. Part of my difficulty is the fact that I
purchased this 5 year old boat  in April, so don't have any history on the
steering. I will certainly monitor the fluid level - easy since it has the
extra fll kit installed with a filler cap on the exteriror of the upper
helm - and if I see any further loss will do a much more careful inspection.
Cheers, Garrett.
----- Original Message -----
To: "'Garrett Lambert'" garrettlambert@shaw.ca
Sent: Sunday, August 13, 2006 8:22 AM
Subject: RE: Hydraulic Steering Update
-----Original Message-----
Last week I asked for and received excellent advice re my steering
problems.
Today I checked the system for leaks - none that I could find - but the
fluid
level was down about 2 ounces, and topping it up restored the former
"feel"
and tightened everything up.
Garrett,
If your fluid level is down, you've got a leak in the system, and a
steering
failure waiting to happen.
Under normal conditions, the system should never leak any fluid. Unless
you know
where the fluid is leaking, and positively know it is not going to cause a
steering failure when you can least afford it, you've got a serious
situation
that needs fixing. On the other hand, if it is only leaking from the seals
in
the ram, and you are monitoring the leak and keeping the fluid topped up,
it can
probably wait for winter maintenance (provided it doesn't get worse).
Regards,
Kevin
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.405 / Virus Database: 268.10.9/417 - Release Date: 8/11/2006
Hi Larry I appreciate your comment. Part of my difficulty is the fact that I purchased this 5 year old boat in April, so don't have any history on the steering. I will certainly monitor the fluid level - easy since it has the extra fll kit installed with a filler cap on the exteriror of the upper helm - and if I see any further loss will do a much more careful inspection. Cheers, Garrett. ----- Original Message ----- From: "Kevin Redden" <kredden@BoatMoves.com> To: "'Garrett Lambert'" <garrettlambert@shaw.ca> Sent: Sunday, August 13, 2006 8:22 AM Subject: RE: Hydraulic Steering Update >> -----Original Message----- >> Last week I asked for and received excellent advice re my steering >> problems. >> Today I checked the system for leaks - none that I could find - but the >> fluid >> level was down about 2 ounces, and topping it up restored the former >> "feel" >> and tightened everything up. > > Garrett, > > If your fluid level is down, you've got a leak in the system, and a > steering > failure waiting to happen. > > Under normal conditions, the system should never leak any fluid. Unless > you know > where the fluid is leaking, and positively know it is not going to cause a > steering failure when you can least afford it, you've got a serious > situation > that needs fixing. On the other hand, if it is only leaking from the seals > in > the ram, and you are monitoring the leak and keeping the fluid topped up, > it can > probably wait for winter maintenance (provided it doesn't get worse). > > Regards, > Kevin > > > > -- > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.1.405 / Virus Database: 268.10.9/417 - Release Date: 8/11/2006
