trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
MacBookPro and Air mobile charging
RP
Randy Pickelmann
Sat, Dec 28, 2013 1:05 PM
A quick look at the charger for my MacBook Pro 13 shows an output voltage of 16.5V@3.65A. I electrically challenged and don't know how that will work with 12V.
Having said that, Blue Seas makes a 12V receptacle that sports two USB plugs. If it will work, that would be an elegant way to keep things tidy.
Regards,
Randy Pickelmann
Morning Star
lying Sunset Bay Marina-Stuart, Fl
www.CruisingMorningStar.com
Sent from my iPad
A quick look at the charger for my MacBook Pro 13 shows an output voltage of 16.5V@3.65A. I electrically challenged and don't know how that will work with 12V. Having said that, Blue Seas makes a 12V receptacle that sports two USB plugs. If it will work, that would be an elegant way to keep things tidy. Regards, Randy Pickelmann Morning Star lying Sunset Bay Marina-Stuart, Fl www.CruisingMorningStar.com Sent from my iPad
BM
Bob McLeran
Sat, Dec 28, 2013 1:24 PM
Randy, you need to look at the output voltage for the 2 USB plugs on the
receptacle at which you are looking. USB chargers typically output only
5 volts at 1 or 2 amps.
On the other end of the line, you need to determine how little/much
current your laptop needs. Just because the output of the "brick" is
16.5V doesn't necessarily mean that your laptop requires that much to
operate.
A few years back I bought a power supply with a 12 volt plug on one end
(for those "cigarette lighter" receptacles), a very small "brick," and
interchangeable tips for the laptop end. Think it might be a Targus but
it's on the boat in Carrabelle. I used it on two different laptops over
the years by changing the tips. Newer laptops take even less
voltage/amperage but I'm still using it with my 8 year old Toshiba that
is our "navigation" laptop.
My new HP ultrabook (everything but navigation) would easily work with
the 12 volt supply if I could find a tip that would fit.
<><><><><><><><><><><><>Mozilla Thunderbird<><><><><><><><><><>
Bob McLeran and Judy Young              Manatee Cove Marina
MV Sanderling                            Patrick Air Force Base
DeFever 41 Trawler                      Melbourne, Florida
Blog: http://mvsanderling.net/Blog
Web: http://cruising.mvsanderling.net/
Randy, you need to look at the output voltage for the 2 USB plugs on the receptacle at which you are looking. USB chargers typically output only 5 volts at 1 or 2 amps. On the other end of the line, you need to determine how little/much current your laptop needs. Just because the output of the "brick" is 16.5V doesn't necessarily mean that your laptop requires that much to operate. A few years back I bought a power supply with a 12 volt plug on one end (for those "cigarette lighter" receptacles), a very small "brick," and interchangeable tips for the laptop end. Think it might be a Targus but it's on the boat in Carrabelle. I used it on two different laptops over the years by changing the tips. Newer laptops take even less voltage/amperage but I'm still using it with my 8 year old Toshiba that is our "navigation" laptop. My new HP ultrabook (everything but navigation) would easily work with the 12 volt supply if I could find a tip that would fit. <><><><><><><><><><><><>Mozilla Thunderbird<><><><><><><><><><> Bob McLeran and Judy Young Manatee Cove Marina MV Sanderling Patrick Air Force Base DeFever 41 Trawler Melbourne, Florida Blog: http://mvsanderling.net/Blog Web: http://cruising.mvsanderling.net/ On 12/28/2013 8:05 AM, Randy Pickelmann wrote: > A quick look at the charger for my MacBook Pro 13 shows an output > voltage of 16.5V@3.65A. I electrically challenged and don't know how > that will work with 12V. Having said that, Blue Seas makes a 12V > receptacle that sports two USB plugs. If it will work, that would be > an elegant way to keep things tidy.
R
rt
Sat, Dec 28, 2013 3:43 PM
Hi Randy,
For my 15" MacBook Pro w/ Retina display, I use the following:
http://store.marinebeam.com/macbook-magsafe-12vdc-charger.html
With:
http://store.apple.com/us/product/MD504ZM/A/magsafe-to-magsafe-2-converter?fnode=5a
Connected to a 12v cig lighter outlet in the pilot house.
Used this combo all last year without issues.
Randy
Soul Tender
KK39007
Sent from my iPhone
Regards,
Randy Pickelmann
Morning Star
Sent from my iPad
http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com
To unsubscribe or modify your subscription options (get password, change email address, etc) go to: http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com
Trawlers & Trawlering and T&T are trademarks of Water World
Productions. Unauthorized use is prohibited.
Hi Randy, For my 15" MacBook Pro w/ Retina display, I use the following: http://store.marinebeam.com/macbook-magsafe-12vdc-charger.html With: http://store.apple.com/us/product/MD504ZM/A/magsafe-to-magsafe-2-converter?fnode=5a Connected to a 12v cig lighter outlet in the pilot house. Used this combo all last year without issues. Randy Soul Tender KK39007 Sent from my iPhone > On Dec 28, 2013, at 8:05 AM, Randy Pickelmann <rwp_48@yahoo.com> wrote: > > A quick look at the charger for my MacBook Pro 13 shows an output voltage of 16.5V@3.65A. I electrically challenged and don't know how that will work with 12V. > Having said that, Blue Seas makes a 12V receptacle that sports two USB plugs. If it will work, that would be an elegant way to keep things tidy. > > Regards, > Randy Pickelmann > Morning Star > lying Sunset Bay Marina-Stuart, Fl > www.CruisingMorningStar.com > Sent from my iPad > _______________________________________________ > http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com > > To unsubscribe or modify your subscription options (get password, change email address, etc) go to: http://lists.trawlering.com/mailman/listinfo/trawlers_lists.trawlering.com > Trawlers & Trawlering and T&T are trademarks of Water World > Productions. Unauthorized use is prohibited. >
