discuss@lists.openscad.org
OpenSCAD general discussion Mailing-list
Center of a 2d object
ME
Mark Erbaugh
Mon, Nov 11, 2024 3:46 PM
Is there programmatic way to get the center (or any other reference, such as a corner) point of a 2d object at an arbitrary position in the XY plane?
Mark
Is there programmatic way to get the center (or any other reference, such as a corner) point of a 2d object at an arbitrary position in the XY plane? Mark
SP
Sanjeev Prabhakar
Mon, Nov 11, 2024 4:22 PM
Its long time since I have written any function in openSCAD, but this
should work
p0=[[2,0],[10,5],[5,10]];
function center_point(p,p1=[0,0,0],n=0)=
n==(len(p))?p1/len(p):center_point(p,p1+p[n],n+1);
echo(center_point(p0));
basically center of mass for any object would be
sum of all the points(2d or 3d coordinates)/ number of points
On Mon, 11 Nov 2024 at 21:16, Mark Erbaugh via Discuss <
Mark
OpenSCAD mailing list
To unsubscribe send an email to discuss-leave@lists.openscad.org
Its long time since I have written any function in openSCAD, but this should work p0=[[2,0],[10,5],[5,10]]; function center_point(p,p1=[0,0,0],n=0)= n==(len(p))?p1/len(p):center_point(p,p1+p[n],n+1); echo(center_point(p0)); basically center of mass for any object would be sum of all the points(2d or 3d coordinates)/ number of points On Mon, 11 Nov 2024 at 21:16, Mark Erbaugh via Discuss < discuss@lists.openscad.org> wrote: > Is there programmatic way to get the center (or any other reference, such > as a corner) point of a 2d object at an arbitrary position in the XY plane? > > Mark > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
GS
Guenther Sohler
Mon, Nov 11, 2024 4:25 PM
Issue IS that in openscad you dont have Access to the objects vertices 😞
Sanjeev Prabhakar via Discuss discuss@lists.openscad.org schrieb am Mo.,
11. Nov. 2024, 17:22:
should work
Mark
Issue IS that in openscad you dont have Access to the objects vertices 😞 . Sanjeev Prabhakar via Discuss <discuss@lists.openscad.org> schrieb am Mo., 11. Nov. 2024, 17:22: > Its long time since I have written any function in openSCAD, but this > should work > > p0=[[2,0],[10,5],[5,10]]; > > function center_point(p,p1=[0,0,0],n=0)= > n==(len(p))?p1/len(p):center_point(p,p1+p[n],n+1); > > echo(center_point(p0)); > > basically center of mass for any object would be > sum of all the points(2d or 3d coordinates)/ number of points > > On Mon, 11 Nov 2024 at 21:16, Mark Erbaugh via Discuss < > discuss@lists.openscad.org> wrote: > >> Is there programmatic way to get the center (or any other reference, such >> as a corner) point of a 2d object at an arbitrary position in the XY plane? >> >> Mark >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
SP
Sanjeev Prabhakar
Mon, Nov 11, 2024 4:32 PM
oh I thought to make a polygon in openSCAD you have to define points anyway.
Nevermind, I wrote a recursive function after a long time in openSCAD
On Mon, 11 Nov 2024 at 21:56, Guenther Sohler via Discuss <
should work
plane?
Mark
oh I thought to make a polygon in openSCAD you have to define points anyway. Nevermind, I wrote a recursive function after a long time in openSCAD On Mon, 11 Nov 2024 at 21:56, Guenther Sohler via Discuss < discuss@lists.openscad.org> wrote: > Issue IS that in openscad you dont have Access to the objects vertices 😞 > > . > > Sanjeev Prabhakar via Discuss <discuss@lists.openscad.org> schrieb am > Mo., 11. Nov. 2024, 17:22: > >> Its long time since I have written any function in openSCAD, but this >> should work >> >> p0=[[2,0],[10,5],[5,10]]; >> >> function center_point(p,p1=[0,0,0],n=0)= >> n==(len(p))?p1/len(p):center_point(p,p1+p[n],n+1); >> >> echo(center_point(p0)); >> >> basically center of mass for any object would be >> sum of all the points(2d or 3d coordinates)/ number of points >> >> On Mon, 11 Nov 2024 at 21:16, Mark Erbaugh via Discuss < >> discuss@lists.openscad.org> wrote: >> >>> Is there programmatic way to get the center (or any other reference, >>> such as a corner) point of a 2d object at an arbitrary position in the XY >>> plane? >>> >>> Mark >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
JB
Jordan Brown
Mon, Nov 11, 2024 5:25 PM
To make a polygon primitive, yes.
But you can also get 2D objects from Boolean combinations of other 2D objects, from projection(), from imported 2D objects, et cetera, and there’s currently no way to retrieve the coordinates of such an object.
It’s exactly the same situation as for 3D objects, but flatter.
 > oh I thought to make a polygon in openSCAD you have to define points anyway. To make a polygon primitive, yes. But you can also get 2D objects from Boolean combinations of other 2D objects, from projection(), from imported 2D objects, et cetera, and there’s currently no way to retrieve the coordinates of such an object. It’s exactly the same situation as for 3D objects, but flatter.
TA
Todd Allen
Mon, Nov 11, 2024 5:42 PM
Use the 2d shape functions from BOSL2 which return geometry and you can
manipulate it with their functions such as rotate, scale, union and
difference which return geometry.  BOSL2 also has functions such
as path_closest_point() which you might use to find corners and calculate a
center point.  The BOSL2 code can also provide a starting point to modify
into your own solutions when there isn't a routine in the library that can
do what you need.
On Mon, Nov 11, 2024 at 10:33 AM Sanjeev Prabhakar via Discuss <
anyway.
should work
plane?
Mark
Use the 2d shape functions from BOSL2 which return geometry and you can manipulate it with their functions such as rotate, scale, union and difference which return geometry. BOSL2 also has functions such as path_closest_point() which you might use to find corners and calculate a center point. The BOSL2 code can also provide a starting point to modify into your own solutions when there isn't a routine in the library that can do what you need. On Mon, Nov 11, 2024 at 10:33 AM Sanjeev Prabhakar via Discuss < discuss@lists.openscad.org> wrote: > oh I thought to make a polygon in openSCAD you have to define points > anyway. > > Nevermind, I wrote a recursive function after a long time in openSCAD > > On Mon, 11 Nov 2024 at 21:56, Guenther Sohler via Discuss < > discuss@lists.openscad.org> wrote: > >> Issue IS that in openscad you dont have Access to the objects vertices 😞 >> >> . >> >> Sanjeev Prabhakar via Discuss <discuss@lists.openscad.org> schrieb am >> Mo., 11. Nov. 2024, 17:22: >> >>> Its long time since I have written any function in openSCAD, but this >>> should work >>> >>> p0=[[2,0],[10,5],[5,10]]; >>> >>> function center_point(p,p1=[0,0,0],n=0)= >>> n==(len(p))?p1/len(p):center_point(p,p1+p[n],n+1); >>> >>> echo(center_point(p0)); >>> >>> basically center of mass for any object would be >>> sum of all the points(2d or 3d coordinates)/ number of points >>> >>> On Mon, 11 Nov 2024 at 21:16, Mark Erbaugh via Discuss < >>> discuss@lists.openscad.org> wrote: >>> >>>> Is there programmatic way to get the center (or any other reference, >>>> such as a corner) point of a 2d object at an arbitrary position in the XY >>>> plane? >>>> >>>> Mark >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
JB
Jon Bondy
Mon, Nov 11, 2024 5:49 PM
I love it!
<grin>
This email has been checked for viruses by AVG antivirus software.
www.avg.com
I love it! <grin> On 11/11/2024 12:25 PM, Jordan Brown via Discuss wrote: > It’s exactly the same situation as for 3D objects, but flatter. > -- This email has been checked for viruses by AVG antivirus software. www.avg.com
AM
Adrian Mariano
Mon, Nov 11, 2024 5:51 PM
I think maybe you meant to say that BOSL2 has functions that return point
lists and you can manipulate them with rotate, scale, union, difference
etc.  In addition, BOSL2 has centroid() which computes the centroid
(center of mass) of a polygon or polyhedron, which is not simply the
average of the vertices.  You can compute the average of the vertices---if
you want that value instead---with mean().
On Mon, Nov 11, 2024 at 12:43 PM Todd Allen via Discuss <
do what you need.
anyway.
should work
plane?
Mark
I think maybe you meant to say that BOSL2 has functions that return point lists and you can manipulate them with rotate, scale, union, difference etc. In addition, BOSL2 has centroid() which computes the centroid (center of mass) of a polygon or polyhedron, which is not simply the average of the vertices. You can compute the average of the vertices---if you want that value instead---with mean(). On Mon, Nov 11, 2024 at 12:43 PM Todd Allen via Discuss < discuss@lists.openscad.org> wrote: > Use the 2d shape functions from BOSL2 which return geometry and you can > manipulate it with their functions such as rotate, scale, union and > difference which return geometry. BOSL2 also has functions such > as path_closest_point() which you might use to find corners and calculate a > center point. The BOSL2 code can also provide a starting point to modify > into your own solutions when there isn't a routine in the library that can > do what you need. > > On Mon, Nov 11, 2024 at 10:33 AM Sanjeev Prabhakar via Discuss < > discuss@lists.openscad.org> wrote: > >> oh I thought to make a polygon in openSCAD you have to define points >> anyway. >> >> Nevermind, I wrote a recursive function after a long time in openSCAD >> >> On Mon, 11 Nov 2024 at 21:56, Guenther Sohler via Discuss < >> discuss@lists.openscad.org> wrote: >> >>> Issue IS that in openscad you dont have Access to the objects vertices 😞 >>> >>> . >>> >>> Sanjeev Prabhakar via Discuss <discuss@lists.openscad.org> schrieb am >>> Mo., 11. Nov. 2024, 17:22: >>> >>>> Its long time since I have written any function in openSCAD, but this >>>> should work >>>> >>>> p0=[[2,0],[10,5],[5,10]]; >>>> >>>> function center_point(p,p1=[0,0,0],n=0)= >>>> n==(len(p))?p1/len(p):center_point(p,p1+p[n],n+1); >>>> >>>> echo(center_point(p0)); >>>> >>>> basically center of mass for any object would be >>>> sum of all the points(2d or 3d coordinates)/ number of points >>>> >>>> On Mon, 11 Nov 2024 at 21:16, Mark Erbaugh via Discuss < >>>> discuss@lists.openscad.org> wrote: >>>> >>>>> Is there programmatic way to get the center (or any other reference, >>>>> such as a corner) point of a 2d object at an arbitrary position in the XY >>>>> plane? >>>>> >>>>> Mark >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
TA
Todd Allen
Mon, Nov 11, 2024 6:29 PM
lists
I said what I meant as I thought the point lists returned were one form of
geometry and a VNF is another type of data representing geometry.  The
centroid() function which can operate on point lists and VNFs  is in a file
named geometry.scad.  But if the word geometry is technically reserved for
something else such as the output of rendering then thanks for the
correction and explanation.
On Mon, Nov 11, 2024 at 11:52 AM Adrian Mariano via Discuss <
do what you need.
anyway.
should work
plane?
Mark
> I think maybe you meant to say that BOSL2 has functions that return point lists I said what I meant as I thought the point lists returned were one form of geometry and a VNF is another type of data representing geometry. The centroid() function which can operate on point lists and VNFs is in a file named geometry.scad. But if the word geometry is technically reserved for something else such as the output of rendering then thanks for the correction and explanation. On Mon, Nov 11, 2024 at 11:52 AM Adrian Mariano via Discuss < discuss@lists.openscad.org> wrote: > I think maybe you meant to say that BOSL2 has functions that return point > lists and you can manipulate them with rotate, scale, union, difference > etc. In addition, BOSL2 has centroid() which computes the centroid > (center of mass) of a polygon or polyhedron, which is not simply the > average of the vertices. You can compute the average of the vertices---if > you want that value instead---with mean(). > > On Mon, Nov 11, 2024 at 12:43 PM Todd Allen via Discuss < > discuss@lists.openscad.org> wrote: > >> Use the 2d shape functions from BOSL2 which return geometry and you can >> manipulate it with their functions such as rotate, scale, union and >> difference which return geometry. BOSL2 also has functions such >> as path_closest_point() which you might use to find corners and calculate a >> center point. The BOSL2 code can also provide a starting point to modify >> into your own solutions when there isn't a routine in the library that can >> do what you need. >> >> On Mon, Nov 11, 2024 at 10:33 AM Sanjeev Prabhakar via Discuss < >> discuss@lists.openscad.org> wrote: >> >>> oh I thought to make a polygon in openSCAD you have to define points >>> anyway. >>> >>> Nevermind, I wrote a recursive function after a long time in openSCAD >>> >>> On Mon, 11 Nov 2024 at 21:56, Guenther Sohler via Discuss < >>> discuss@lists.openscad.org> wrote: >>> >>>> Issue IS that in openscad you dont have Access to the objects vertices >>>> 😞 >>>> >>>> . >>>> >>>> Sanjeev Prabhakar via Discuss <discuss@lists.openscad.org> schrieb am >>>> Mo., 11. Nov. 2024, 17:22: >>>> >>>>> Its long time since I have written any function in openSCAD, but this >>>>> should work >>>>> >>>>> p0=[[2,0],[10,5],[5,10]]; >>>>> >>>>> function center_point(p,p1=[0,0,0],n=0)= >>>>> n==(len(p))?p1/len(p):center_point(p,p1+p[n],n+1); >>>>> >>>>> echo(center_point(p0)); >>>>> >>>>> basically center of mass for any object would be >>>>> sum of all the points(2d or 3d coordinates)/ number of points >>>>> >>>>> On Mon, 11 Nov 2024 at 21:16, Mark Erbaugh via Discuss < >>>>> discuss@lists.openscad.org> wrote: >>>>> >>>>>> Is there programmatic way to get the center (or any other reference, >>>>>> such as a corner) point of a 2d object at an arbitrary position in the XY >>>>>> plane? >>>>>> >>>>>> Mark >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
RW
Raymond West
Mon, Nov 11, 2024 6:37 PM
Without getting feedback from cursor position, I'm not sure how you
could define corners - 'top-left' wouldn't always work, for example. I
expect, if you could define the point you wanted to select, you could
just as easily calculate it in most cases. Openscad creates, it does not
deconstruct.
Mark
Without getting feedback from cursor position, I'm not sure how you could define corners - 'top-left' wouldn't always work, for example. I expect, if you could define the point you wanted to select, you could just as easily calculate it in most cases. Openscad creates, it does not deconstruct. On 11/11/2024 15:46, Mark Erbaugh via Discuss wrote: > Is there programmatic way to get the center (or any other reference, such as a corner) point of a 2d object at an arbitrary position in the XY plane? > > Mark > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
JB
Jordan Brown
Mon, Nov 11, 2024 10:44 PM
I think for that most people would be happy with an "ordinary" view of
the coordinate system - in 2D, "top left" is minimum-X, maximum-Y.  Of
course, your observation is itself relative to the surrounding
coordinate system.
On 11/11/2024 10:37 AM, Raymond West via Discuss wrote: > Without getting feedback from cursor position, I'm not sure how you > could define corners - 'top-left' wouldn't always work, for example. I think for that most people would be happy with an "ordinary" view of the coordinate system - in 2D, "top left" is minimum-X, maximum-Y.  Of course, your observation is itself relative to the surrounding coordinate system.
JB
Jordan Brown
Tue, Nov 12, 2024 3:24 AM
explanation.
I don't think there's a clear nomenclature that distinguishes between
"data values that represent a shape" and "the result of OpenSCAD
model-creation operations".
I do think that we need to adopt some nomenclature there, for two
reasons, both tied to my PR#4478 but applicable to similar proposals.
First, as we introduce what JavaScript calls objects and Python calls
dictionaries, the word "object" becomes ambiguous:  does it refer to a
name-value data structure (perhaps eventually with other OO behaviors),
or to a geometric shape?
Second, PR#4478 introduces a mechanism for taking a piece of an OpenSCAD
model and treating it as a data value - you can put it into a variable,
pass it to a module or function, return it from a function, et cetera.
(For the curious:  internally, it's a CSG tree.)  What do we call that
data type?  To make things trickier, there's a render() function that
takes that opaque value and returns a conventional array / name-value
data structure that is the result of rendering it - metadata plus for a
list of points plus for 2D object a list of paths and for 3D objects a
list of faces.  (For BOSL2 fans, it's basically the same as a VNF.)
What do we call that?
I like "object" for the data structure, by way of analogy to "objects"
in other languages, especially when and if we gain additional
object-like behavior.  "dictionary" has some appeal, based on Python,
but in Python objects and dictionaries are different animals.  In
JavaScript, on the other hand, there are only objects.
I've been trying to use "geometry" or "shape" to refer to the OpenSCAD
part-of-the-model construct and its associated data type.
But my opinion is not the authoritative answer.
On 11/11/2024 10:29 AM, Todd Allen via Discuss wrote: > But if the word geometry is technically reserved for something else > such as the output of rendering then thanks for the correction and > explanation. I don't think there's a clear nomenclature that distinguishes between "data values that represent a shape" and "the result of OpenSCAD model-creation operations". I *do* think that we need to adopt some nomenclature there, for two reasons, both tied to my PR#4478 but applicable to similar proposals. First, as we introduce what JavaScript calls objects and Python calls dictionaries, the word "object" becomes ambiguous:  does it refer to a name-value data structure (perhaps eventually with other OO behaviors), or to a geometric shape? Second, PR#4478 introduces a mechanism for taking a piece of an OpenSCAD model and treating it as a data value - you can put it into a variable, pass it to a module or function, return it from a function, et cetera.  (For the curious:  internally, it's a CSG tree.)  What do we call that data type?  To make things trickier, there's a render() function that takes that opaque value and returns a conventional array / name-value data structure that is the result of rendering it - metadata plus for a list of points plus for 2D object a list of paths and for 3D objects a list of faces.  (For BOSL2 fans, it's basically the same as a VNF.)  What do we call *that*? I like "object" for the data structure, by way of analogy to "objects" in other languages, especially when and if we gain additional object-like behavior.  "dictionary" has some appeal, based on Python, but in Python objects and dictionaries are different animals.  In JavaScript, on the other hand, there are only objects. I've been trying to use "geometry" or "shape" to refer to the OpenSCAD part-of-the-model construct and its associated data type. But my opinion is not the authoritative answer.
