Fwd: UHD 4.7 - Building X310_XG FPGA
C
cyberphox
Fri, Jul 19, 2024 11:59 AM
Hi All,
I have a clone of UHD 4.7 (Tags: v4.7.0.0) and am trying to build the
default X310_XG FPGA to check if my setup is OK.
I ran the following commands from /uhd/fpga/usrp3/top/x300
source ./setupenv.sh
rfnoc_image_builder -y x310_XG_rfnoc_image_core.yml -t X310_XG
After some time I get this error:
BUILDER: Adding IP:
/home/gssltest/git/uhd/fpga/usrp3/top/x300/build-ip/xc7k410tffg900-2/axi_fft/axi_fft.xci
BUILDER: Adding IP:
/home/gssltest/git/uhd/fpga/usrp3/top/x300/build-ip/xc7k410tffg900-2/axi_hb31/axi_hb31.xci
ERROR: [Common 17-107] Cannot change read-only property
'generate_synth_checkpoint'.
Resolution: Please refer to Vivado Properties Reference Guide (UG912) for
more information on setting properties.
INFO: [Common 17-206] Exiting Vivado at Fri Jul 19 12:38:28 2024...
Thanks for your help
Marino
Hi All, I have a clone of UHD 4.7 (Tags: v4.7.0.0) and am trying to build the default X310_XG FPGA to check if my setup is OK. I ran the following commands from /uhd/fpga/usrp3/top/x300 source ./setupenv.sh rfnoc_image_builder -y x310_XG_rfnoc_image_core.yml -t X310_XG After some time I get this error: BUILDER: Adding IP: /home/gssltest/git/uhd/fpga/usrp3/top/x300/build-ip/xc7k410tffg900-2/axi_fft/axi_fft.xci BUILDER: Adding IP: /home/gssltest/git/uhd/fpga/usrp3/top/x300/build-ip/xc7k410tffg900-2/axi_hb31/axi_hb31.xci ERROR: [Common 17-107] Cannot change read-only property 'generate_synth_checkpoint'. Resolution: Please refer to Vivado Properties Reference Guide (UG912) for more information on setting properties. INFO: [Common 17-206] Exiting Vivado at Fri Jul 19 12:38:28 2024... Thanks for your help Marino
WF
Wade Fife
Fri, Jul 19, 2024 6:28 PM
IP generation issues tend to be caused by using the wrong Vivado version,
or having stale files laying around from previous versions. Make sure
you're using Vivado 2021.1 with the patch AR76780 installed. If you changed
Vivado versions at some point, you may need to clean the repo to remove any
stale files remaining from previous build attempts. Running "make cleanall"
in the FPGA's top directory is usually sufficient for this.
Also, if you changed anything in the code, that might be relevant as well.
Beyond that, you might need to share more of your logs since there may be
clues in the log further up before this failure.
Thanks,
Wade
On Fri, Jul 19, 2024 at 6:59 AM cyberphox cyberphox@gmail.com wrote:
Hi All,
BUILDER: Adding IP:
BUILDER: Adding IP:
Marino
IP generation issues tend to be caused by using the wrong Vivado version, or having stale files laying around from previous versions. Make sure you're using Vivado 2021.1 with the patch AR76780 installed. If you changed Vivado versions at some point, you may need to clean the repo to remove any stale files remaining from previous build attempts. Running "make cleanall" in the FPGA's top directory is usually sufficient for this. Also, if you changed anything in the code, that might be relevant as well. Beyond that, you might need to share more of your logs since there may be clues in the log further up before this failure. Thanks, Wade On Fri, Jul 19, 2024 at 6:59 AM cyberphox <cyberphox@gmail.com> wrote: > > Hi All, > > I have a clone of UHD 4.7 (Tags: v4.7.0.0) and am trying to build the > default X310_XG FPGA to check if my setup is OK. > > I ran the following commands from /uhd/fpga/usrp3/top/x300 > > source ./setupenv.sh > rfnoc_image_builder -y x310_XG_rfnoc_image_core.yml -t X310_XG > > After some time I get this error: > > BUILDER: Adding IP: > /home/gssltest/git/uhd/fpga/usrp3/top/x300/build-ip/xc7k410tffg900-2/axi_fft/axi_fft.xci > BUILDER: Adding IP: > /home/gssltest/git/uhd/fpga/usrp3/top/x300/build-ip/xc7k410tffg900-2/axi_hb31/axi_hb31.xci > ERROR: [Common 17-107] Cannot change read-only property > 'generate_synth_checkpoint'. > Resolution: Please refer to Vivado Properties Reference Guide (UG912) for > more information on setting properties. > INFO: [Common 17-206] Exiting Vivado at Fri Jul 19 12:38:28 2024... > > Thanks for your help > > Marino > > _______________________________________________ > USRP-users mailing list -- usrp-users@lists.ettus.com > To unsubscribe send an email to usrp-users-leave@lists.ettus.com >
C
cyberphox@gmail.com
Mon, Jul 22, 2024 2:31 PM
Thanks for your reply. I resolved it once I updated Vivado with the patch from Xilinx/AMD
https://support.xilinx.com/s/article/76780?language=en_US
Thanks for your reply. I resolved it once I updated Vivado with the patch from Xilinx/AMD https://support.xilinx.com/s/article/76780?language=en_US
