time-nuts@lists.febo.com
Re: [time-nuts] 5087B (was What's the cleanest way to produce 1 and 5 MHz from 10 MHz?)
CH
christopher hoover
Tue, Jul 28, 2009 11:48 PM
From: "Lux, James P (337C)" james.p.lux@jpl.nasa.gov wrote:
There's slots for three input modules (A,B,C), and 10 output modules
(1-10), and they're all optional and easily reconfigurable.
Just to be clear, the modules themselves aren't reconfigurable, but the
mainframe is.
That said, the 1 MHz, 5 MHz and 10 MHz output amps share the same
circuit topology and board layout (although IIRC the actual boards are
marked distinctly.).  It is easy to convert a 5MHz output amp to 10MHz
and vice versa by changing a couple off-the-shelf Cs.  The 1MHz output
amp has a different transformer in addition to several other parts.  The
transformers are HP specials with unspecified characteristics.
-ch
From: "Lux, James P (337C)" <james.p.lux@jpl.nasa.gov> wrote: > > > There's slots for three input modules (A,B,C), and 10 output modules > (1-10), and they're all optional and easily reconfigurable. Just to be clear, the modules themselves aren't reconfigurable, but the mainframe is. That said, the 1 MHz, 5 MHz and 10 MHz output amps share the same circuit topology and board layout (although IIRC the actual boards are marked distinctly.). It is easy to convert a 5MHz output amp to 10MHz and vice versa by changing a couple off-the-shelf Cs. The 1MHz output amp has a different transformer in addition to several other parts. The transformers are HP specials with unspecified characteristics. -ch
