trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Re: Windows cleanup:
R
rmcleran@ix.netcom.com
Fri, Apr 24, 1998 1:10 AM
jean ice wrote:
Here is a quick addition of about 7 megs of hardisk space. Remove all the
windows *.avi files. These are your tutorial files that you probably are no
longer using. Go to Windows explorer and "find" *.avi check them then
delete.
Actually, a number of programs use *.avi files.  If you follow this
advice, make sure you delete only those in your */windows/help
directory.  You can always check, after using "find" as suggested above,
by clicking on the file to see what information it presents.
Bob McLeran                              rmcleran@ix.netcom.com
M/V "Sanderling"                        Docked at Point Patience Marina
Hailing port: Wianno MA                      Solomons, MD
Hampton 35 Trawler
jean ice wrote: > > Here is a quick addition of about 7 megs of hardisk space. Remove all the > windows *.avi files. These are your tutorial files that you probably are no > longer using. Go to Windows explorer and "find" *.avi check them then > delete. Actually, a number of programs use *.avi files. If you follow this advice, make sure you delete only those in your */windows/help directory. You can always check, after using "find" as suggested above, by clicking on the file to see what information it presents. -- Bob McLeran rmcleran@ix.netcom.com M/V "Sanderling" Docked at Point Patience Marina Hailing port: Wianno MA Solomons, MD Hampton 35 Trawler
