time-nuts@lists.febo.com
GHz output from fe5680a
C0
chris 0
Mon, Jan 30, 2012 11:26 PM
hello everyone,
I'm just wondering if its possible to tap into the GHz output from the
rubidium in the fe5680a.
many thanks
Chris
hello everyone, I'm just wondering if its possible to tap into the GHz output from the rubidium in the fe5680a. many thanks Chris
W
WB6BNQ
Tue, Jan 31, 2012 12:30 AM
Hi Chris,
The short answer is NO !
Bill....WB6BNQ
chris 0 wrote:
hello everyone,
many thanks
Chris
Hi Chris, The short answer is NO ! Bill....WB6BNQ chris 0 wrote: > hello everyone, > > I'm just wondering if its possible to tap into the GHz output from the > rubidium in the fe5680a. > > many thanks > > Chris > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
B
beale
Tue, Jan 31, 2012 12:48 AM
What would you intend to do with the signal?
I'm not a microwave expert, but I believe the only microwave signals in the FE-5680A are the output of the step-recovery diode that multiplies the 60 MHz VCXO signal up to the 114th harmonic, plus that mixed with the 5.313 MHz DDS output to reach the Rb frequency. ( 114 * 60 Mhz - 5.313 Mhz -> 6.835 Ghz)  The SRD output would be just a mix of a lot of harmonics, not any sort of clean signal; I suspect the only real filter is the resonant cavity which is occupied by the Rb bulb.  I suppose a small enough probe into that cavity might not detune it too much, but you'd probably need an additional amplifier to do anything with that signal.  Iin this device the Rb vapor itself does not generate microwaves (like an active H maser), it just absorbs them, and it changes optically if the signal happens to be at the resonance frequency around 6.8 GHz.
-------Original Message-------
Subject: [time-nuts] GHz output from fe5680a
What would you intend to do with the signal? I'm not a microwave expert, but I believe the only microwave signals in the FE-5680A are the output of the step-recovery diode that multiplies the 60 MHz VCXO signal up to the 114th harmonic, plus that mixed with the 5.313 MHz DDS output to reach the Rb frequency. ( 114 * 60 Mhz - 5.313 Mhz -> 6.835 Ghz) The SRD output would be just a mix of a lot of harmonics, not any sort of clean signal; I suspect the only real filter is the resonant cavity which is occupied by the Rb bulb. I suppose a small enough probe into that cavity might not detune it too much, but you'd probably need an additional amplifier to do anything with that signal. Iin this device the Rb vapor itself does not generate microwaves (like an active H maser), it just absorbs them, and it changes optically if the signal happens to be at the resonance frequency around 6.8 GHz. > -------Original Message------- > From: chris 0 <viscousplacebo@gmail.com> > Subject: [time-nuts] GHz output from fe5680a > I'm just wondering if its possible to tap into the GHz output from the rubidium in the fe5680a.
BC
Bob Camp
Tue, Jan 31, 2012 1:20 AM
Hi
Simple answer is don't bother.
More complex answer - of course you can. You will get a forest of spikes (every 5, MHz or so ).
Bob
On Jan 30, 2012, at 6:26 PM, chris 0 viscousplacebo@gmail.com wrote:
hello everyone,
many thanks
Chris
Hi Simple answer is don't bother. More complex answer - of course you can. You will get a forest of spikes (every 5, MHz or so ). Bob On Jan 30, 2012, at 6:26 PM, chris 0 <viscousplacebo@gmail.com> wrote: > hello everyone, > > I'm just wondering if its possible to tap into the GHz output from the > rubidium in the fe5680a. > > many thanks > > Chris > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
MD
Magnus Danielson
Tue, Jan 31, 2012 1:52 AM
On 31/01/12 02:20, Bob Camp wrote:
Hi
Also, since the 5,3 MHz is modulated, 1,4 kHz apart is the two signals,
and then a skirt of side-bands as the frequency modulation is relatively
quick.
It's not clean.
BTW. A fun hack would be to hook up the 63,8976 MHz OCXO in replacement
of the 60 MHz and then re-adjusting the DDS to 2.35645 MHz, as the 107s
overtone of the OCXO minus the new DDS frequency hits the Rb resonance.
Cheers,
Magnus
On 31/01/12 02:20, Bob Camp wrote: > Hi > > Simple answer is don't bother. > > More complex answer - of course you can. You will get a forest of spikes (every 5, MHz or so ). Also, since the 5,3 MHz is modulated, 1,4 kHz apart is the two signals, and then a skirt of side-bands as the frequency modulation is relatively quick. It's not clean. BTW. A fun hack would be to hook up the 63,8976 MHz OCXO in replacement of the 60 MHz and then re-adjusting the DDS to 2.35645 MHz, as the 107s overtone of the OCXO minus the new DDS frequency hits the Rb resonance. Cheers, Magnus
TV
Tom Van Baak
Tue, Jan 31, 2012 5:24 AM
hello everyone,
many thanks
Chris
If I understand your question right...
Most rubidium frequency standards (and cesium for that matter)
do not actually output that frequency. I know in the popular press
they talk about the "precise vibrations of the cesium atom" or the
"precise frequency that they emit" but that's a metaphor and not
how they actually work. The atoms don't vibrate, they don't emit
a GHz frequency, and you don't count 9,192,631,770 of them to
make one second.
What typically happens is that electronics synthesizes an RF
(microwave) signal and continuously sweeps across a narrow
range of frequencies; the element (Rb or Cs or H) will respond
more or less depending on how correct the probe frequency is.
A servo then tries to keep the probe frequency centered on the
peak. These are all called "passive" standards.
The rare exception is the "active" hydrogen maser; where there
really is a live signal (1420+ MHz) coming out of the apparatus.
You may find these two papers helpful:
Introduction to time and frequency metrology
http://tf.nist.gov/general/pdf/1288.pdf
Fundamentals of Time and Frequency
http://tf.nist.gov/general/pdf/1498.pdf
/tvb
> hello everyone, > > I'm just wondering if its possible to tap into the GHz output from the > rubidium in the fe5680a. > > many thanks > > Chris If I understand your question right... Most rubidium frequency standards (and cesium for that matter) do not actually output that frequency. I know in the popular press they talk about the "precise vibrations of the cesium atom" or the "precise frequency that they emit" but that's a metaphor and not how they actually work. The atoms don't vibrate, they don't emit a GHz frequency, and you don't count 9,192,631,770 of them to make one second. What typically happens is that electronics synthesizes an RF (microwave) signal and continuously sweeps across a narrow range of frequencies; the element (Rb or Cs or H) will respond more or less depending on how correct the probe frequency is. A servo then tries to keep the probe frequency centered on the peak. These are all called "passive" standards. The rare exception is the "active" hydrogen maser; where there really is a live signal (1420+ MHz) coming out of the apparatus. You may find these two papers helpful: Introduction to time and frequency metrology http://tf.nist.gov/general/pdf/1288.pdf Fundamentals of Time and Frequency http://tf.nist.gov/general/pdf/1498.pdf /tvb
JH
Javier Herrero
Tue, Jan 31, 2012 6:27 AM
Hi
relatively quick.
It's not clean.
the Rb resonance.
Cheers,
Magnus
And then we will have a not less fun 10.6469MHz and 0.939Hz outputs :)
However, if the DDS can easily be reprogrammed to large offsets (and the
output filter is a simple lowpass...), that idea is very useful if you
need an strange frequency and have an OCXO at 6x that extrange frequency ;)
Regards,
Javier
El 31/01/2012 02:52, Magnus Danielson escribió: > On 31/01/12 02:20, Bob Camp wrote: >> Hi >> >> Simple answer is don't bother. >> >> More complex answer - of course you can. You will get a forest of >> spikes (every 5, MHz or so ). > > Also, since the 5,3 MHz is modulated, 1,4 kHz apart is the two > signals, and then a skirt of side-bands as the frequency modulation is > relatively quick. > > It's not clean. > > BTW. A fun hack would be to hook up the 63,8976 MHz OCXO in > replacement of the 60 MHz and then re-adjusting the DDS to 2.35645 > MHz, as the 107s overtone of the OCXO minus the new DDS frequency hits > the Rb resonance. > > Cheers, > Magnus > > And then we will have a not less fun 10.6469MHz and 0.939Hz outputs :) However, if the DDS can easily be reprogrammed to large offsets (and the output filter is a simple lowpass...), that idea is very useful if you need an strange frequency and have an OCXO at 6x that extrange frequency ;) Regards, Javier
MD
Magnus Danielson
Wed, Feb 1, 2012 12:16 AM
Hi
relatively quick.
It's not clean.
the Rb resonance.
Cheers,
Magnus
We seems to get those OCXOs alongside anyway, so I was just toying with
the idea to see what kind of performance that would give us. A quieter
OCXO. For more ordinary frequency output, an additional DDS like the
original 5680 would be nice.
Cheers,
Magnus
On 31/01/12 07:27, Javier Herrero wrote: > El 31/01/2012 02:52, Magnus Danielson escribió: >> On 31/01/12 02:20, Bob Camp wrote: >>> Hi >>> >>> Simple answer is don't bother. >>> >>> More complex answer - of course you can. You will get a forest of >>> spikes (every 5, MHz or so ). >> >> Also, since the 5,3 MHz is modulated, 1,4 kHz apart is the two >> signals, and then a skirt of side-bands as the frequency modulation is >> relatively quick. >> >> It's not clean. >> >> BTW. A fun hack would be to hook up the 63,8976 MHz OCXO in >> replacement of the 60 MHz and then re-adjusting the DDS to 2.35645 >> MHz, as the 107s overtone of the OCXO minus the new DDS frequency hits >> the Rb resonance. >> >> Cheers, >> Magnus >> >> > And then we will have a not less fun 10.6469MHz and 0.939Hz outputs :) > However, if the DDS can easily be reprogrammed to large offsets (and the > output filter is a simple lowpass...), that idea is very useful if you > need an strange frequency and have an OCXO at 6x that extrange frequency ;) We seems to get those OCXOs alongside anyway, so I was just toying with the idea to see what kind of performance that would give us. A quieter OCXO. For more ordinary frequency output, an additional DDS like the original 5680 would be nice. Cheers, Magnus
