trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
replacement windows/frames
L
LaBomba182@aol.com
Fri, Sep 3, 2004 1:23 PM
In a message dated 9/3/04 12:05:41 AM Eastern Daylight Time,
trawlers-and-trawlering-request@lists.samurai.com writes:
Generally it is fairly
easy to remove all of the paint, thoroughly clean the windows, apply
strontium
chromate primer (spray cans for outdrives) or two part epoxy strontium
chromate primer in the can by brush and then paint with one of the urethane
paints.
If this is what you call a "fairly easy" project, I'd hate to see your
definition of a PIA project. :-)
     Capt. Bill
In a message dated 9/3/04 12:05:41 AM Eastern Daylight Time, trawlers-and-trawlering-request@lists.samurai.com writes: > Generally it is fairly > easy to remove all of the paint, thoroughly clean the windows, apply > strontium > chromate primer (spray cans for outdrives) or two part epoxy strontium > chromate primer in the can by brush and then paint with one of the urethane > paints. > If this is what you call a "fairly easy" project, I'd hate to see your definition of a PIA project. :-) Capt. Bill
