time-nuts@lists.febo.com
Lifetime testing
HM
Hal Murray
Tue, Sep 1, 2020 8:09 PM
I believe that they simply don’t have a body of long term data “in house” to
study.
Interesting topic.
How many units do you have to test to get useful data?  How often do you have
to measure the output frequency?
Are electrolytics the typical weak link?  Do their vendors have good data?
What's next on the list?
I assume the first step is to run them 24/7 at max rated temperature.  What's
the next step and how much more do you learn?
How much life testing to vendors of other gear do?  PCs?  Disks?  Memory?
Instruments? (counters...)
Is there a good web page or video on long-term-testing of electronic gear?
I'm looking for the hour or three hour level rather than a PhD  program.
These are my opinions.  I hate spam.
kb8tq@n1k.org said: > I believe that they simply don’t have a body of long term data “in house” to > study. Interesting topic. How many units do you have to test to get useful data? How often do you have to measure the output frequency? Are electrolytics the typical weak link? Do their vendors have good data? What's next on the list? I assume the first step is to run them 24/7 at max rated temperature. What's the next step and how much more do you learn? How much life testing to vendors of other gear do? PCs? Disks? Memory? Instruments? (counters...) Is there a good web page or video on long-term-testing of electronic gear? I'm looking for the hour or three hour level rather than a PhD program. -- These are my opinions. I hate spam.
BK
Bob kb8tq
Tue, Sep 1, 2020 10:17 PM
Hi
On Sep 1, 2020, at 4:09 PM, Hal Murray hmurray@megapathdsl.net wrote:
study.
Interesting topic.
Likely a couple hundred spaced out over a few years of production.
They flat out die ( = no output ). If you catch that +/- a month it’s probably “good enough”.
They have been in the ones I’ve  fixed.
Apparently not.
Roughly 20 other parts in the device ….
You likely would run them at multiple temperatures.
What's
Power / temperature cycle them.
Since this is a “many years of testing” sort of thing ( = you run them for maybe 20 years)
I’d say zip ...
Nope. Nobody has the money to do it on large groups of parts. (well, almost nobody …).
What does happen is that the customer may be able to track field failures. The
issue there is that the environment (and other drivers) is rarely well documented.
That information is normally conveyed in quarterly review meetings.
Bob
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
Hi > On Sep 1, 2020, at 4:09 PM, Hal Murray <hmurray@megapathdsl.net> wrote: > > > kb8tq@n1k.org said: >> I believe that they simply don’t have a body of long term data “in house” to >> study. > > Interesting topic. > > How many units do you have to test to get useful data? Likely a couple hundred spaced out over a few years of production. > How often do you have > to measure the output frequency? They flat out die ( = no output ). If you catch that +/- a month it’s probably “good enough”. > > Are electrolytics the typical weak link? They have been in the ones I’ve fixed. > Do their vendors have good data? Apparently not. > What's next on the list? Roughly 20 other parts in the device …. > > I assume the first step is to run them 24/7 at max rated temperature. You likely would run them at multiple temperatures. > What's > the next step and how much more do you learn? Power / temperature cycle them. > > How much life testing to vendors of other gear do? PCs? Disks? Memory? > Instruments? (counters...) Since this is a “many years of testing” sort of thing ( = you run them for maybe 20 years) I’d say zip ... > > > Is there a good web page or video on long-term-testing of electronic gear? Nope. Nobody has the money to do it on large groups of parts. (well, almost nobody …). What does happen is that the customer may be able to track field failures. The issue there is that the environment (and other drivers) is rarely well documented. That information is normally conveyed in quarterly review meetings. Bob > I'm looking for the hour or three hour level rather than a PhD program. > > -- > These are my opinions. I hate spam. > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there.
MG
Mark Goldberg
Tue, Sep 1, 2020 10:55 PM
There is lots of work in this area. Search "accelerated life testing
electronics" and you will find lots of information at various levels.
These guys have the PhD version, but you have to pay to join or be an
academic for access.
https://calce.umd.edu/
I've worked with this in the Aviation industry for a long time. There is a
reason planes don't fall out of the sky all the time but consumer
electronics are throwaway items.
Regards,
Mark
house” to
study.
Interesting topic.
have
What's
gear?
There is lots of work in this area. Search "accelerated life testing electronics" and you will find lots of information at various levels. These guys have the PhD version, but you have to pay to join or be an academic for access. https://calce.umd.edu/ I've worked with this in the Aviation industry for a long time. There is a reason planes don't fall out of the sky all the time but consumer electronics are throwaway items. Regards, Mark On Tue, Sep 1, 2020, 2:16 PM Hal Murray <hmurray@megapathdsl.net> wrote: > > kb8tq@n1k.org said: > > I believe that they simply don’t have a body of long term data “in > house” to > > study. > > Interesting topic. > > How many units do you have to test to get useful data? How often do you > have > to measure the output frequency? > > Are electrolytics the typical weak link? Do their vendors have good data? > What's next on the list? > > I assume the first step is to run them 24/7 at max rated temperature. > What's > the next step and how much more do you learn? > > How much life testing to vendors of other gear do? PCs? Disks? Memory? > Instruments? (counters...) > > > Is there a good web page or video on long-term-testing of electronic > gear? > I'm looking for the hour or three hour level rather than a PhD program. > > -- > These are my opinions. I hate spam. > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@lists.febo.com > To unsubscribe, go to > http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com > and follow the instructions there. >
