Well, I design systems that we send out all over the world. I have various
spec numbers that indicate some rather optimistic tolerance. For example, I
have measured actual outlets in the US at 70VAC and 142VAC, which is well
outside the published tolerances. I get a lot of flack from management when
I try to use those numbers as operational limits instead of the utility
published ones. Some empirical evidence from a third party would help a lot.
70 and 142 seem more than a bit unreasonable. How long did they stay at that
level?
I like Jim's suggestion of asking the guys who are collecting the data.
I've been using my UPS to monitor line voltage. It's got commands to read
the min/max input voltage since the last time you asked.
My software writes a line to the log file every 5 minutes or more often if
the line voltage changes by more than 2 V. It runs about 30K per day.
Mostly, things are boring: 120-125 V. Occasionally I see a glitch.
I should write some code to scan the old files and collect statistics.
These are my opinions, not necessarily my employer's. I hate spam.
I recently changed to an APC UPS (which was an upgrade in communications,
but a downgrade in efficiency) that which supports reading the voltage.
It's one of those AVR type that can boost or drop the voltage so it's
closer to spec. It seems to drop out below 95v, and above 135v (factory
eeprom settings). Yet another thing i want to log. So busy playing with
everything makes it hard to find time.
Steve
various
example, I
when
lot.
that
level?
To unsubscribe, go to
