time-nuts@lists.febo.com
GPS antenna selection
HP
Herbert Poetzl
Thu, Aug 4, 2016 9:29 PM
Dear fellow time-nuts!
I'm currently investigating my options regarding
GPS antennae (of course for time related purposes)
and I'm really confused by the variety they come
in ... (my apologies in advance for the long post).
Setting:
I'm living in a three storey house with a sloped
roof, a covered balcony and a larger garden with
huge trees on the Austrian countryside (Europe).
I've walked around with my smartphone (older one)
and I get a GPS position fix within 35s in the
garden (nine satellites shown), within 100s on
the balcony (also nine satellites), and not a
single satellite can be seen indoors.
The obvious choice would be to put the antenna on
top in the middle of the slanted roof for a perfect
sky view, but this brings a number of problems as
the roof is very hard to reach and quite high.
I have my 'lab' at the floor where the balcony is,
so I'm considering putting an antenna there and
run about 5-15m of coax cable to the GPS receiver.
The advantage there is that the antenna would be
somewhat protected (it still gets very hot during
summer and very cold during winter, but no rain
and no snow) and easy to reach for maintenance.
The third alternative would be to put the antenna
somewhere in the garden and have a rather long
cable running to the house and up to my lab.
Antennae:
Looking on eBay and Amazon shows a huge pricerange
for active GPS antennae with and without cable.
It seems to start at about 10 bucks with rather
small black boxes [1] designed for cars, probably
containing a 25x25 ceramic GPS antenna and an
amplifier, progresses over very interesting out-
door constructions for boats and whatnot [2] in
the 20-100 bucks range and finally tops with high
end devices [3] way above 100 bucks.
The information about the cheap devices is usually
very scarce, but typically boils down to:
1575.42 +/- 5MHz
24-28dB LNA Gain with 10-25mA at (3-5V)
7dB f0 +/- 20MHz
20dB f0 +/- 50MHz
30dB f0 +/- 100MHz
They seem to use RG174 and come with SMA as well
as BNC connectors (and a number of others as well).
The mid range devices seem to use larger antennae
with smaller tolerances (+/- 1MHz) and larger
voltage ranges for the amplifier (3-13V).
Questions:
  • What are the key specifications which need to
    be verified before buying a GPS antenna?
  • How can they be compared based on incomplete
    specifications?
  • Is a place on the roof or in the garden worth
    the trouble over the covered balcony?
  • Are there any typical pit-falls or general
    tips and tricks regarding mounting and cable
    connection to the receiver?
Many thanks in advance and my apologies again for
the rather lengthy post. Please feel free to point
me to previous discussion regarding this topic.
All the best,
Herbert
[1] http://www.ebay.com/itm/99-Good-GPS-Antenna-SMA-Screw-Needle-10m-Super-Signal-Navigation-DVD-Antenna-/171802461614
https://www.amazon.com/Waterproof-Active-Antenna-28dB-Gain/dp/B00LXRQY9A
[2] http://www.ebay.com/itm/Standard-Horizon-XUCMP0014-GPS-Antenna-f-CP150-CP160-CP170/331364914004
https://www.amazon.com/Garmin-010-12017-00-GPS-GLONASS-Antenna/dp/B00EVT2HSE
https://www.amazon.com/SUNDELY®-External-Marine-Antenna-connector/dp/B00D8WAVTC
[3] http://www.ebay.com/itm/NEW-FURUNO-GPA018-Gps-dgps-Antenna-/182223355414
https://www.amazon.com/Garmin-nmea-2000-orders-over/dp/B0089DU96A
Dear fellow time-nuts! I'm currently investigating my options regarding GPS antennae (of course for time related purposes) and I'm really confused by the variety they come in ... (my apologies in advance for the long post). Setting: I'm living in a three storey house with a sloped roof, a covered balcony and a larger garden with huge trees on the Austrian countryside (Europe). I've walked around with my smartphone (older one) and I get a GPS position fix within 35s in the garden (nine satellites shown), within 100s on the balcony (also nine satellites), and not a single satellite can be seen indoors. The obvious choice would be to put the antenna on top in the middle of the slanted roof for a perfect sky view, but this brings a number of problems as the roof is very hard to reach and quite high. I have my 'lab' at the floor where the balcony is, so I'm considering putting an antenna there and run about 5-15m of coax cable to the GPS receiver. The advantage there is that the antenna would be somewhat protected (it still gets very hot during summer and very cold during winter, but no rain and no snow) and easy to reach for maintenance. The third alternative would be to put the antenna somewhere in the garden and have a rather long cable running to the house and up to my lab. Antennae: Looking on eBay and Amazon shows a huge pricerange for active GPS antennae with and without cable. It seems to start at about 10 bucks with rather small black boxes [1] designed for cars, probably containing a 25x25 ceramic GPS antenna and an amplifier, progresses over very interesting out- door constructions for boats and whatnot [2] in the 20-100 bucks range and finally tops with high end devices [3] way above 100 bucks. The information about the cheap devices is usually very scarce, but typically boils down to: 1575.42 +/- 5MHz 24-28dB LNA Gain with 10-25mA at (3-5V) 7dB f0 +/- 20MHz 20dB f0 +/- 50MHz 30dB f0 +/- 100MHz They seem to use RG174 and come with SMA as well as BNC connectors (and a number of others as well). The mid range devices seem to use larger antennae with smaller tolerances (+/- 1MHz) and larger voltage ranges for the amplifier (3-13V). Questions: - What are the key specifications which need to be verified before buying a GPS antenna? - How can they be compared based on incomplete specifications? - Is a place on the roof or in the garden worth the trouble over the covered balcony? - Are there any typical pit-falls or general tips and tricks regarding mounting and cable connection to the receiver? Many thanks in advance and my apologies again for the rather lengthy post. Please feel free to point me to previous discussion regarding this topic. All the best, Herbert [1] http://www.ebay.com/itm/99-Good-GPS-Antenna-SMA-Screw-Needle-10m-Super-Signal-Navigation-DVD-Antenna-/171802461614 https://www.amazon.com/Waterproof-Active-Antenna-28dB-Gain/dp/B00LXRQY9A [2] http://www.ebay.com/itm/Standard-Horizon-XUCMP0014-GPS-Antenna-f-CP150-CP160-CP170/331364914004 https://www.amazon.com/Garmin-010-12017-00-GPS-GLONASS-Antenna/dp/B00EVT2HSE https://www.amazon.com/SUNDELY®-External-Marine-Antenna-connector/dp/B00D8WAVTC [3] http://www.ebay.com/itm/NEW-FURUNO-GPA018-Gps-dgps-Antenna-/182223355414 https://www.amazon.com/Garmin-nmea-2000-orders-over/dp/B0089DU96A
TM
Tom Miller
Thu, Aug 4, 2016 9:57 PM
Do you have a picture of the balcony?
----- Original Message -----
To: time-nuts@febo.com
Sent: Thursday, August 04, 2016 5:29 PM
Subject: [time-nuts] GPS antenna selection
Setting:
Antennae:
1575.42 +/- 5MHz
7dB f0 +/- 20MHz
20dB f0 +/- 50MHz
30dB f0 +/- 100MHz
Questions:
    specifications?
All the best,
Herbert
[1]
[2]
[3]
To unsubscribe, go to
Do you have a picture of the balcony? ----- Original Message ----- From: "Herbert Poetzl" <herbert@13thfloor.at> To: <time-nuts@febo.com> Sent: Thursday, August 04, 2016 5:29 PM Subject: [time-nuts] GPS antenna selection > > Dear fellow time-nuts! > > I'm currently investigating my options regarding > GPS antennae (of course for time related purposes) > and I'm really confused by the variety they come > in ... (my apologies in advance for the long post). > > > Setting: > > I'm living in a three storey house with a sloped > roof, a covered balcony and a larger garden with > huge trees on the Austrian countryside (Europe). > > I've walked around with my smartphone (older one) > and I get a GPS position fix within 35s in the > garden (nine satellites shown), within 100s on > the balcony (also nine satellites), and not a > single satellite can be seen indoors. > > The obvious choice would be to put the antenna on > top in the middle of the slanted roof for a perfect > sky view, but this brings a number of problems as > the roof is very hard to reach and quite high. > > I have my 'lab' at the floor where the balcony is, > so I'm considering putting an antenna there and > run about 5-15m of coax cable to the GPS receiver. > The advantage there is that the antenna would be > somewhat protected (it still gets very hot during > summer and very cold during winter, but no rain > and no snow) and easy to reach for maintenance. > > The third alternative would be to put the antenna > somewhere in the garden and have a rather long > cable running to the house and up to my lab. > > > Antennae: > > Looking on eBay and Amazon shows a huge pricerange > for active GPS antennae with and without cable. > > It seems to start at about 10 bucks with rather > small black boxes [1] designed for cars, probably > containing a 25x25 ceramic GPS antenna and an > amplifier, progresses over very interesting out- > door constructions for boats and whatnot [2] in > the 20-100 bucks range and finally tops with high > end devices [3] way above 100 bucks. > > The information about the cheap devices is usually > very scarce, but typically boils down to: > > 1575.42 +/- 5MHz > 24-28dB LNA Gain with 10-25mA at (3-5V) > > 7dB f0 +/- 20MHz > 20dB f0 +/- 50MHz > 30dB f0 +/- 100MHz > > They seem to use RG174 and come with SMA as well > as BNC connectors (and a number of others as well). > > The mid range devices seem to use larger antennae > with smaller tolerances (+/- 1MHz) and larger > voltage ranges for the amplifier (3-13V). > > > Questions: > > - What are the key specifications which need to > be verified before buying a GPS antenna? > > - How can they be compared based on incomplete > specifications? > > - Is a place on the roof or in the garden worth > the trouble over the covered balcony? > > - Are there any typical pit-falls or general > tips and tricks regarding mounting and cable > connection to the receiver? > > Many thanks in advance and my apologies again for > the rather lengthy post. Please feel free to point > me to previous discussion regarding this topic. > > All the best, > Herbert > > > [1] > http://www.ebay.com/itm/99-Good-GPS-Antenna-SMA-Screw-Needle-10m-Super-Signal-Navigation-DVD-Antenna-/171802461614 > > https://www.amazon.com/Waterproof-Active-Antenna-28dB-Gain/dp/B00LXRQY9A > > [2] > http://www.ebay.com/itm/Standard-Horizon-XUCMP0014-GPS-Antenna-f-CP150-CP160-CP170/331364914004 > > https://www.amazon.com/Garmin-010-12017-00-GPS-GLONASS-Antenna/dp/B00EVT2HSE > > https://www.amazon.com/SUNDELY®-External-Marine-Antenna-connector/dp/B00D8WAVTC > > [3] > http://www.ebay.com/itm/NEW-FURUNO-GPA018-Gps-dgps-Antenna-/182223355414 > https://www.amazon.com/Garmin-nmea-2000-orders-over/dp/B0089DU96A > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
BC
Bob Camp
Thu, Aug 4, 2016 10:26 PM
Hi
Setting:
Antennae:
1575.42 +/- 5MHz
7dB f0 +/- 20MHz
20dB f0 +/- 50MHz
30dB f0 +/- 100MHz
That’s the spec on the interference  rejection filter. Tighter is better
as long as it still passes the desired signal(s).
The better ones will have a TNC connector on them
Questions:
You want one that is designed for permanent outdoor use. That eliminates the $10
car mounts. These days, I’d get one that does both GPS and GLONASS
    specifications?
They can’t. It’s just luck. The ones you see for about $40 and up that are designed
for mast mounting are usually pretty good.
The real question is how much of a sky view you get. Ideally you would like a clear view
of the sky from about NE clear around to NW (270 degrees). You also would like to be
able to “see” down to within 10 degrees of the horizon over that range. The segment from
E to W (180 degrees) is pretty important. Being able to see to within 30 degrees of the
horizon is also pretty important.
Some receivers put out +12V, most antennas don’t like +12 and want +5. Some modern
antennas will only handle +3.3V.
If you have a long run to the antenna, feed line loss is what matters. To some degree
you can cope with this by buying an antenna that has a higher gain amp in it. They
range from about 21 db to about 50 db. You also don’t want to over drive your receiver
so just getting the 50 db version is not a perfect solution.
Grounding the antenna is always a good idea. A surge suppressor  in the line could save
you some real cost if there is a lightning strike. I don’t know about Austria, but here in
the US, both are required.
Bob
Hi > On Aug 4, 2016, at 5:29 PM, Herbert Poetzl <herbert@13thfloor.at> wrote: > > > Dear fellow time-nuts! > > I'm currently investigating my options regarding > GPS antennae (of course for time related purposes) > and I'm really confused by the variety they come > in ... (my apologies in advance for the long post). > > > Setting: > > I'm living in a three storey house with a sloped > roof, a covered balcony and a larger garden with > huge trees on the Austrian countryside (Europe). > > I've walked around with my smartphone (older one) > and I get a GPS position fix within 35s in the > garden (nine satellites shown), within 100s on > the balcony (also nine satellites), and not a > single satellite can be seen indoors. > > The obvious choice would be to put the antenna on > top in the middle of the slanted roof for a perfect > sky view, but this brings a number of problems as > the roof is very hard to reach and quite high. > > I have my 'lab' at the floor where the balcony is, > so I'm considering putting an antenna there and > run about 5-15m of coax cable to the GPS receiver. > The advantage there is that the antenna would be > somewhat protected (it still gets very hot during > summer and very cold during winter, but no rain > and no snow) and easy to reach for maintenance. > > The third alternative would be to put the antenna > somewhere in the garden and have a rather long > cable running to the house and up to my lab. > > > Antennae: > > Looking on eBay and Amazon shows a huge pricerange > for active GPS antennae with and without cable. > > It seems to start at about 10 bucks with rather > small black boxes [1] designed for cars, probably > containing a 25x25 ceramic GPS antenna and an > amplifier, progresses over very interesting out- > door constructions for boats and whatnot [2] in > the 20-100 bucks range and finally tops with high > end devices [3] way above 100 bucks. > > The information about the cheap devices is usually > very scarce, but typically boils down to: > > 1575.42 +/- 5MHz > 24-28dB LNA Gain with 10-25mA at (3-5V) > > 7dB f0 +/- 20MHz > 20dB f0 +/- 50MHz > 30dB f0 +/- 100MHz That’s the spec on the interference rejection filter. Tighter is better as long as it still passes the desired signal(s). > > They seem to use RG174 and come with SMA as well > as BNC connectors (and a number of others as well). The better ones will have a TNC connector on them > > The mid range devices seem to use larger antennae > with smaller tolerances (+/- 1MHz) and larger > voltage ranges for the amplifier (3-13V). > > > Questions: > > - What are the key specifications which need to > be verified before buying a GPS antenna? You want one that is designed for permanent outdoor use. That eliminates the $10 car mounts. These days, I’d get one that does both GPS and GLONASS > > - How can they be compared based on incomplete > specifications? They can’t. It’s just luck. The ones you see for about $40 and up that are designed for mast mounting are usually pretty good. > > - Is a place on the roof or in the garden worth > the trouble over the covered balcony? The real question is how much of a sky view you get. Ideally you would like a clear view of the sky from about NE clear around to NW (270 degrees). You also would like to be able to “see” down to within 10 degrees of the horizon over that range. The segment from E to W (180 degrees) is pretty important. Being able to see to within 30 degrees of the horizon is also pretty important. > > - Are there any typical pit-falls or general > tips and tricks regarding mounting and cable > connection to the receiver? Some receivers put out +12V, most antennas don’t like +12 and want +5. Some modern antennas will only handle +3.3V. If you have a long run to the antenna, feed line loss is what matters. To some degree you can cope with this by buying an antenna that has a higher gain amp in it. They range from about 21 db to about 50 db. You also don’t want to over drive your receiver so just getting the 50 db version is not a perfect solution. Grounding the antenna is always a good idea. A surge suppressor in the line could save you some real cost if there is a lightning strike. I don’t know about Austria, but here in the US, both are required. Bob > > Many thanks in advance and my apologies again for > the rather lengthy post. Please feel free to point > me to previous discussion regarding this topic. > > All the best, > Herbert > > > [1] http://www.ebay.com/itm/99-Good-GPS-Antenna-SMA-Screw-Needle-10m-Super-Signal-Navigation-DVD-Antenna-/171802461614 > https://www.amazon.com/Waterproof-Active-Antenna-28dB-Gain/dp/B00LXRQY9A > > [2] http://www.ebay.com/itm/Standard-Horizon-XUCMP0014-GPS-Antenna-f-CP150-CP160-CP170/331364914004 > https://www.amazon.com/Garmin-010-12017-00-GPS-GLONASS-Antenna/dp/B00EVT2HSE > https://www.amazon.com/SUNDELY®-External-Marine-Antenna-connector/dp/B00D8WAVTC > > [3] http://www.ebay.com/itm/NEW-FURUNO-GPA018-Gps-dgps-Antenna-/182223355414 > https://www.amazon.com/Garmin-nmea-2000-orders-over/dp/B0089DU96A > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
AP
Alex Pummer
Thu, Aug 4, 2016 10:32 PM
Hi Herbert,
just look the loss of the cable at 1500 MHz, and you will start to cry
at 1500MHz tha cable will have cca 30dB for a 30meter long
piece....basically that RG174 looks very nice with that small antenna
but that is the only positive aspect. Meinberg in Germany has one
up/down converting system, which makes it possible to go more than 50 meter.
On the other hand if you could stay on the balcony and use the cable
which came with the antenna, 2m  to 3 meter,  you could have a good
working system, but with 15m RG174  is asking to much. For 1500 MHz BNC
is not the best solution,
73
KJ6UHN
Alex
P.S.: wo ist diese "Austrian countryside"
Setting:
Antennae:
1575.42 +/- 5MHz
7dB f0 +/- 20MHz
20dB f0 +/- 50MHz
30dB f0 +/- 100MHz
Questions:
    specifications?
All the best,
Herbert
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2016.0.7690 / Virus Database: 4627/12745 - Release Date: 08/04/16
Hi Herbert, just look the loss of the cable at 1500 MHz, and you will start to cry at 1500MHz tha cable will have cca 30dB for a 30meter long piece....basically that RG174 looks very nice with that small antenna but that is the only positive aspect. Meinberg in Germany has one up/down converting system, which makes it possible to go more than 50 meter. On the other hand if you could stay on the balcony and use the cable which came with the antenna, 2m to 3 meter, you could have a good working system, but with 15m RG174 is asking to much. For 1500 MHz BNC is not the best solution, 73 KJ6UHN Alex P.S.: wo ist diese "Austrian countryside" On 8/4/2016 2:29 PM, Herbert Poetzl wrote: > Dear fellow time-nuts! > > I'm currently investigating my options regarding > GPS antennae (of course for time related purposes) > and I'm really confused by the variety they come > in ... (my apologies in advance for the long post). > > > Setting: > > I'm living in a three storey house with a sloped > roof, a covered balcony and a larger garden with > huge trees on the Austrian countryside (Europe). > > I've walked around with my smartphone (older one) > and I get a GPS position fix within 35s in the > garden (nine satellites shown), within 100s on > the balcony (also nine satellites), and not a > single satellite can be seen indoors. > > The obvious choice would be to put the antenna on > top in the middle of the slanted roof for a perfect > sky view, but this brings a number of problems as > the roof is very hard to reach and quite high. > > I have my 'lab' at the floor where the balcony is, > so I'm considering putting an antenna there and > run about 5-15m of coax cable to the GPS receiver. > The advantage there is that the antenna would be > somewhat protected (it still gets very hot during > summer and very cold during winter, but no rain > and no snow) and easy to reach for maintenance. > > The third alternative would be to put the antenna > somewhere in the garden and have a rather long > cable running to the house and up to my lab. > > > Antennae: > > Looking on eBay and Amazon shows a huge pricerange > for active GPS antennae with and without cable. > > It seems to start at about 10 bucks with rather > small black boxes [1] designed for cars, probably > containing a 25x25 ceramic GPS antenna and an > amplifier, progresses over very interesting out- > door constructions for boats and whatnot [2] in > the 20-100 bucks range and finally tops with high > end devices [3] way above 100 bucks. > > The information about the cheap devices is usually > very scarce, but typically boils down to: > > 1575.42 +/- 5MHz > 24-28dB LNA Gain with 10-25mA at (3-5V) > > 7dB f0 +/- 20MHz > 20dB f0 +/- 50MHz > 30dB f0 +/- 100MHz > > They seem to use RG174 and come with SMA as well > as BNC connectors (and a number of others as well). > > The mid range devices seem to use larger antennae > with smaller tolerances (+/- 1MHz) and larger > voltage ranges for the amplifier (3-13V). > > > Questions: > > - What are the key specifications which need to > be verified before buying a GPS antenna? > > - How can they be compared based on incomplete > specifications? > > - Is a place on the roof or in the garden worth > the trouble over the covered balcony? > > - Are there any typical pit-falls or general > tips and tricks regarding mounting and cable > connection to the receiver? > > Many thanks in advance and my apologies again for > the rather lengthy post. Please feel free to point > me to previous discussion regarding this topic. > > All the best, > Herbert > > > [1] http://www.ebay.com/itm/99-Good-GPS-Antenna-SMA-Screw-Needle-10m-Super-Signal-Navigation-DVD-Antenna-/171802461614 > https://www.amazon.com/Waterproof-Active-Antenna-28dB-Gain/dp/B00LXRQY9A > > [2] http://www.ebay.com/itm/Standard-Horizon-XUCMP0014-GPS-Antenna-f-CP150-CP160-CP170/331364914004 > https://www.amazon.com/Garmin-010-12017-00-GPS-GLONASS-Antenna/dp/B00EVT2HSE > https://www.amazon.com/SUNDELY®-External-Marine-Antenna-connector/dp/B00D8WAVTC > > [3] http://www.ebay.com/itm/NEW-FURUNO-GPA018-Gps-dgps-Antenna-/182223355414 > https://www.amazon.com/Garmin-nmea-2000-orders-over/dp/B0089DU96A > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7690 / Virus Database: 4627/12745 - Release Date: 08/04/16
HP
Herbert Poetzl
Thu, Aug 4, 2016 11:26 PM
On Thu, Aug 04, 2016 at 06:26:28PM -0400, Bob Camp wrote:
Hi
Hey Bob!
Setting:
Antennae:
1575.42 +/- 5MHz
7dB f0 +/- 20MHz
20dB f0 +/- 50MHz
30dB f0 +/- 100MHz
desired signal(s).
Understood!
Hmm, I had to google TNC (Threaded Neill-Concelman).
Is it worth the trouble in the < 2GHz range?
Questions:
use.
Even under somewhat protected conditions like on the
covered balcony?
Makes sense.
    specifications?
Okay, thanks!
That would opt for the balcony, as it faces north
and extends the slanted roof, so basically clear
view from NE to NW down to the horizon.
important.
+12 and want +5.
is what matters.
solution.
Understood! Is there some rule of thumb at what
cable lengths which amplifier gain is best suited?
I did a quick search for SMA/BNC/TNC based surge
protectors and not much did come up, any suggestions
what to use there?
both are required.
Outside definitely, "inside" I'm not sure, but it
won't hurt to have additional protection for the
receiver(s).
Thanks a bunch,
Herbert
Bob
All the best,
Herbert
On Thu, Aug 04, 2016 at 06:26:28PM -0400, Bob Camp wrote: > Hi Hey Bob! >> On Aug 4, 2016, at 5:29 PM, Herbert Poetzl <herbert@13thfloor.at> wrote: >> Dear fellow time-nuts! >> I'm currently investigating my options regarding >> GPS antennae (of course for time related purposes) >> and I'm really confused by the variety they come >> in ... (my apologies in advance for the long post). >> Setting: >> I'm living in a three storey house with a sloped >> roof, a covered balcony and a larger garden with >> huge trees on the Austrian countryside (Europe). >> I've walked around with my smartphone (older one) >> and I get a GPS position fix within 35s in the >> garden (nine satellites shown), within 100s on >> the balcony (also nine satellites), and not a >> single satellite can be seen indoors. >> The obvious choice would be to put the antenna on >> top in the middle of the slanted roof for a perfect >> sky view, but this brings a number of problems as >> the roof is very hard to reach and quite high. >> I have my 'lab' at the floor where the balcony is, >> so I'm considering putting an antenna there and >> run about 5-15m of coax cable to the GPS receiver. >> The advantage there is that the antenna would be >> somewhat protected (it still gets very hot during >> summer and very cold during winter, but no rain >> and no snow) and easy to reach for maintenance. >> The third alternative would be to put the antenna >> somewhere in the garden and have a rather long >> cable running to the house and up to my lab. >> Antennae: >> Looking on eBay and Amazon shows a huge pricerange >> for active GPS antennae with and without cable. >> It seems to start at about 10 bucks with rather >> small black boxes [1] designed for cars, probably >> containing a 25x25 ceramic GPS antenna and an >> amplifier, progresses over very interesting out- >> door constructions for boats and whatnot [2] in >> the 20-100 bucks range and finally tops with high >> end devices [3] way above 100 bucks. >> The information about the cheap devices is usually >> very scarce, but typically boils down to: >> 1575.42 +/- 5MHz >> 24-28dB LNA Gain with 10-25mA at (3-5V) >> 7dB f0 +/- 20MHz >> 20dB f0 +/- 50MHz >> 30dB f0 +/- 100MHz > That’s the spec on the interference rejection filter. > Tighter is better as long as it still passes the > desired signal(s). Understood! >> They seem to use RG174 and come with SMA as well >> as BNC connectors (and a number of others as well). > The better ones will have a TNC connector on them Hmm, I had to google TNC (Threaded Neill-Concelman). Is it worth the trouble in the < 2GHz range? >> The mid range devices seem to use larger antennae >> with smaller tolerances (+/- 1MHz) and larger >> voltage ranges for the amplifier (3-13V). >> Questions: >> - What are the key specifications which need to >> be verified before buying a GPS antenna? > You want one that is designed for permanent outdoor > use. > That eliminates the $10 car mounts. Even under somewhat protected conditions like on the covered balcony? > These days, I’d get one that does both GPS and GLONASS Makes sense. >> - How can they be compared based on incomplete >> specifications? > They can’t. It’s just luck. The ones you see for > about $40 and up that are designed for mast mounting > are usually pretty good. Okay, thanks! >> - Is a place on the roof or in the garden worth >> the trouble over the covered balcony? > The real question is how much of a sky view you get. > Ideally you would like a clear view of the sky from > about NE clear around to NW (270 degrees). That would opt for the balcony, as it faces north and extends the slanted roof, so basically clear view from NE to NW down to the horizon. > You also would like to be able to “see” down to within > 10 degrees of the horizon over that range. > The segment from E to W (180 degrees) is pretty > important. > Being able to see to within 30 degrees of the horizon > is also pretty important. >> - Are there any typical pit-falls or general >> tips and tricks regarding mounting and cable >> connection to the receiver? > Some receivers put out +12V, most antennas don’t like > +12 and want +5. > Some modern antennas will only handle +3.3V. > If you have a long run to the antenna, feed line loss > is what matters. > To some degree you can cope with this by buying an > antenna that has a higher gain amp in it. > They range from about 21 db to about 50 db. > You also don’t want to over drive your receiver so > just getting the 50 db version is not a perfect > solution. Understood! Is there some rule of thumb at what cable lengths which amplifier gain is best suited? > Grounding the antenna is always a good idea. > A surge suppressor in the line could save you some > real cost if there is a lightning strike. I did a quick search for SMA/BNC/TNC based surge protectors and not much did come up, any suggestions what to use there? > I don’t know about Austria, but here in the US, > both are required. Outside definitely, "inside" I'm not sure, but it won't hurt to have additional protection for the receiver(s). Thanks a bunch, Herbert > Bob >> Many thanks in advance and my apologies again for >> the rather lengthy post. Please feel free to point >> me to previous discussion regarding this topic. >> All the best, >> Herbert >> [1] http://www.ebay.com/itm/99-Good-GPS-Antenna-SMA-Screw-Needle-10m-Super-Signal-Navigation-DVD-Antenna-/171802461614 >> https://www.amazon.com/Waterproof-Active-Antenna-28dB-Gain/dp/B00LXRQY9A >> [2] http://www.ebay.com/itm/Standard-Horizon-XUCMP0014-GPS-Antenna-f-CP150-CP160-CP170/331364914004 >> https://www.amazon.com/Garmin-010-12017-00-GPS-GLONASS-Antenna/dp/B00EVT2HSE >> https://www.amazon.com/SUNDELY®-External-Marine-Antenna-connector/dp/B00D8WAVTC >> [3] http://www.ebay.com/itm/NEW-FURUNO-GPA018-Gps-dgps-Antenna-/182223355414 >> https://www.amazon.com/Garmin-nmea-2000-orders-over/dp/B0089DU96A >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there.
BC
Bob Camp
Thu, Aug 4, 2016 11:46 PM
Hi
Hi
Hey Bob!
Setting:
Antennae:
1575.42 +/- 5MHz
7dB f0 +/- 20MHz
20dB f0 +/- 50MHz
30dB f0 +/- 100MHz
desired signal(s).
Understood!
It threads on rather than latches on like a BNC. That makes it
more water tight in the outdoor environment.
Questions:
use.
covered balcony?
You still have fog / condensation / humidity and the other sources
of moisture. So not quite so important, but we rule out the balcony below.
Makes sense.
    specifications?
Okay, thanks!
It needs to face south and have a clear view over a 270 degree arc.
If it faces north …. not going to work very well at all.
important.
+12 and want +5.
is what matters.
solution.
The more money you pay for the cable the lower it’s loss. For $10 a meter you
get a lower loss cable than $1 a meter or $0.10 a meter. Figure that anything over
about a 30 meter run will require either a high gain antenna or some money invested
in LMR-400 cable.
what to use there?
There are a lot of them on eBay. Many of them have N connectors on them.
both are required.
receiver(s).
It is a good bet that the antenna will be outside. I’d plan it that way.
Bob
Hi > On Aug 4, 2016, at 7:26 PM, Herbert Poetzl <herbert@13thfloor.at> wrote: > > On Thu, Aug 04, 2016 at 06:26:28PM -0400, Bob Camp wrote: >> Hi > > Hey Bob! > >>> On Aug 4, 2016, at 5:29 PM, Herbert Poetzl <herbert@13thfloor.at> wrote: > >>> Dear fellow time-nuts! > >>> I'm currently investigating my options regarding >>> GPS antennae (of course for time related purposes) >>> and I'm really confused by the variety they come >>> in ... (my apologies in advance for the long post). > > >>> Setting: > >>> I'm living in a three storey house with a sloped >>> roof, a covered balcony and a larger garden with >>> huge trees on the Austrian countryside (Europe). > >>> I've walked around with my smartphone (older one) >>> and I get a GPS position fix within 35s in the >>> garden (nine satellites shown), within 100s on >>> the balcony (also nine satellites), and not a >>> single satellite can be seen indoors. > >>> The obvious choice would be to put the antenna on >>> top in the middle of the slanted roof for a perfect >>> sky view, but this brings a number of problems as >>> the roof is very hard to reach and quite high. > >>> I have my 'lab' at the floor where the balcony is, >>> so I'm considering putting an antenna there and >>> run about 5-15m of coax cable to the GPS receiver. >>> The advantage there is that the antenna would be >>> somewhat protected (it still gets very hot during >>> summer and very cold during winter, but no rain >>> and no snow) and easy to reach for maintenance. > >>> The third alternative would be to put the antenna >>> somewhere in the garden and have a rather long >>> cable running to the house and up to my lab. > > >>> Antennae: > >>> Looking on eBay and Amazon shows a huge pricerange >>> for active GPS antennae with and without cable. > >>> It seems to start at about 10 bucks with rather >>> small black boxes [1] designed for cars, probably >>> containing a 25x25 ceramic GPS antenna and an >>> amplifier, progresses over very interesting out- >>> door constructions for boats and whatnot [2] in >>> the 20-100 bucks range and finally tops with high >>> end devices [3] way above 100 bucks. > >>> The information about the cheap devices is usually >>> very scarce, but typically boils down to: > >>> 1575.42 +/- 5MHz >>> 24-28dB LNA Gain with 10-25mA at (3-5V) > >>> 7dB f0 +/- 20MHz >>> 20dB f0 +/- 50MHz >>> 30dB f0 +/- 100MHz > >> That’s the spec on the interference rejection filter. >> Tighter is better as long as it still passes the >> desired signal(s). > > Understood! > >>> They seem to use RG174 and come with SMA as well >>> as BNC connectors (and a number of others as well). > >> The better ones will have a TNC connector on them > > Hmm, I had to google TNC (Threaded Neill-Concelman). > Is it worth the trouble in the < 2GHz range? It threads on rather than latches on like a BNC. That makes it more water tight in the outdoor environment. > >>> The mid range devices seem to use larger antennae >>> with smaller tolerances (+/- 1MHz) and larger >>> voltage ranges for the amplifier (3-13V). > > >>> Questions: > >>> - What are the key specifications which need to >>> be verified before buying a GPS antenna? > >> You want one that is designed for permanent outdoor >> use. > >> That eliminates the $10 car mounts. > > Even under somewhat protected conditions like on the > covered balcony? You still have fog / condensation / humidity and the other sources of moisture. So not quite so important, but we rule out the balcony below. > > >> These days, I’d get one that does both GPS and GLONASS > > Makes sense. > > >>> - How can they be compared based on incomplete >>> specifications? > >> They can’t. It’s just luck. The ones you see for >> about $40 and up that are designed for mast mounting >> are usually pretty good. > > Okay, thanks! > >>> - Is a place on the roof or in the garden worth >>> the trouble over the covered balcony? > >> The real question is how much of a sky view you get. > >> Ideally you would like a clear view of the sky from >> about NE clear around to NW (270 degrees). > > That would opt for the balcony, as it faces north > and extends the slanted roof, so basically clear > view from NE to NW down to the horizon. It needs to face south and have a clear view over a 270 degree arc. If it faces north …. not going to work very well at all. > >> You also would like to be able to “see” down to within >> 10 degrees of the horizon over that range. > >> The segment from E to W (180 degrees) is pretty >> important. > >> Being able to see to within 30 degrees of the horizon >> is also pretty important. > > >>> - Are there any typical pit-falls or general >>> tips and tricks regarding mounting and cable >>> connection to the receiver? > >> Some receivers put out +12V, most antennas don’t like >> +12 and want +5. > >> Some modern antennas will only handle +3.3V. > >> If you have a long run to the antenna, feed line loss >> is what matters. > >> To some degree you can cope with this by buying an >> antenna that has a higher gain amp in it. > >> They range from about 21 db to about 50 db. > >> You also don’t want to over drive your receiver so >> just getting the 50 db version is not a perfect >> solution. > > Understood! Is there some rule of thumb at what > cable lengths which amplifier gain is best suited? The more money you pay for the cable the lower it’s loss. For $10 a meter you get a lower loss cable than $1 a meter or $0.10 a meter. Figure that anything over about a 30 meter run will require either a high gain antenna or some money invested in LMR-400 cable. > >> Grounding the antenna is always a good idea. > >> A surge suppressor in the line could save you some >> real cost if there is a lightning strike. > > I did a quick search for SMA/BNC/TNC based surge > protectors and not much did come up, any suggestions > what to use there? There are a *lot* of them on eBay. Many of them have N connectors on them. > >> I don’t know about Austria, but here in the US, >> both are required. > > Outside definitely, "inside" I'm not sure, but it > won't hurt to have additional protection for the > receiver(s). It is a good bet that the antenna will be outside. I’d plan it that way. Bob > > Thanks a bunch, > Herbert > >> Bob > > >>> Many thanks in advance and my apologies again for >>> the rather lengthy post. Please feel free to point >>> me to previous discussion regarding this topic. > >>> All the best, >>> Herbert > > >>> [1] http://www.ebay.com/itm/99-Good-GPS-Antenna-SMA-Screw-Needle-10m-Super-Signal-Navigation-DVD-Antenna-/171802461614 >>> https://www.amazon.com/Waterproof-Active-Antenna-28dB-Gain/dp/B00LXRQY9A > >>> [2] http://www.ebay.com/itm/Standard-Horizon-XUCMP0014-GPS-Antenna-f-CP150-CP160-CP170/331364914004 >>> https://www.amazon.com/Garmin-010-12017-00-GPS-GLONASS-Antenna/dp/B00EVT2HSE >>> https://www.amazon.com/SUNDELY®-External-Marine-Antenna-connector/dp/B00D8WAVTC > >>> [3] http://www.ebay.com/itm/NEW-FURUNO-GPA018-Gps-dgps-Antenna-/182223355414 >>> https://www.amazon.com/Garmin-nmea-2000-orders-over/dp/B0089DU96A > >>> _______________________________________________ >>> time-nuts mailing list -- time-nuts@febo.com >>> To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >>> and follow the instructions there.
CA
Chris Albertson
Fri, Aug 5, 2016 12:37 AM
What matters more than anything else is how good is the view of the sky.
Next You want one that will last basically "forever" outdoors.  The
best kind have a plastic radome over a metal base.  The base has pipe
threads for mounting on a standard 3/4" galvanized plumbing pipe.  The
coax wires goes down this pie and never sees the light of day or rain
water either
The shape of the dome does matter, you want the pointed kind that
birds can not perch on.  If the top is flat od even hemispherical it
will get covered with bird poop.
When I put mine up on the roof most of the work was done in the attic.
I drilled a 1 inch hole and pushed the mast (1" pipe" up through the
hole then secured it with U-straps to a rafter and joist and tugged on
it hard from all directions to make sure it would not move.  Put a
level on it first and check for vertical.  It is no more work to use
a longer pipe than a short one so go up 3 feet above the roof line.
Then while ion top of the roof just flash the hole to prevent a leak
and drop the coax cable down the pip and screw on the antenna to the
mast.
You local building code likely wants you to ground the antenna mast
lust like you would with an old TV antenna.  It is a good idea to
prevent lightening damage to the house.
With the radome typically sealed by o-ring to the base plate and the
lead wire hidden inside a galvanized pipe there is nothing to degrade
over time.  It should be maintenance free for decades or until hit by
lightening
Al the other stuff about what kind of coax to buy and what connectors
are best and so on are "in the noise" the important stuff is (1) view
of the sky and (2) build so you will never in your lifetime have to
fix it
If you must place it near a balcony or window make sure it faces south
as that is where the satellites are, they don't orbit over the poles.
Setting:
Antennae:
1575.42 +/- 5MHz
7dB f0 +/- 20MHz
20dB f0 +/- 50MHz
30dB f0 +/- 100MHz
Questions:
    specifications?
All the best,
Herbert
What matters more than anything else is how good is the view of the sky. Next You want one that will last basically "forever" outdoors. The best kind have a plastic radome over a metal base. The base has pipe threads for mounting on a standard 3/4" galvanized plumbing pipe. The coax wires goes down this pie and never sees the light of day or rain water either The shape of the dome does matter, you want the pointed kind that birds can not perch on. If the top is flat od even hemispherical it will get covered with bird poop. When I put mine up on the roof most of the work was done in the attic. I drilled a 1 inch hole and pushed the mast (1" pipe" up through the hole then secured it with U-straps to a rafter and joist and tugged on it hard from all directions to make sure it would not move. Put a level on it first and check for vertical. It is no more work to use a longer pipe than a short one so go up 3 feet above the roof line. Then while ion top of the roof just flash the hole to prevent a leak and drop the coax cable down the pip and screw on the antenna to the mast. You local building code likely wants you to ground the antenna mast lust like you would with an old TV antenna. It is a good idea to prevent lightening damage to the house. With the radome typically sealed by o-ring to the base plate and the lead wire hidden inside a galvanized pipe there is nothing to degrade over time. It should be maintenance free for decades or until hit by lightening Al the other stuff about what kind of coax to buy and what connectors are best and so on are "in the noise" the important stuff is (1) view of the sky and (2) build so you will never in your lifetime have to fix it If you must place it near a balcony or window make sure it faces south as that is where the satellites are, they don't orbit over the poles. > On Aug 4, 2016, at 2:29 PM, Herbert Poetzl <herbert@13thfloor.at> wrote: > > > Dear fellow time-nuts! > > I'm currently investigating my options regarding > GPS antennae (of course for time related purposes) > and I'm really confused by the variety they come > in ... (my apologies in advance for the long post). > > > Setting: > > I'm living in a three storey house with a sloped > roof, a covered balcony and a larger garden with > huge trees on the Austrian countryside (Europe). > > I've walked around with my smartphone (older one) > and I get a GPS position fix within 35s in the > garden (nine satellites shown), within 100s on > the balcony (also nine satellites), and not a > single satellite can be seen indoors. > > The obvious choice would be to put the antenna on > top in the middle of the slanted roof for a perfect > sky view, but this brings a number of problems as > the roof is very hard to reach and quite high. > > I have my 'lab' at the floor where the balcony is, > so I'm considering putting an antenna there and > run about 5-15m of coax cable to the GPS receiver. > The advantage there is that the antenna would be > somewhat protected (it still gets very hot during > summer and very cold during winter, but no rain > and no snow) and easy to reach for maintenance. > > The third alternative would be to put the antenna > somewhere in the garden and have a rather long > cable running to the house and up to my lab. > > > Antennae: > > Looking on eBay and Amazon shows a huge pricerange > for active GPS antennae with and without cable. > > It seems to start at about 10 bucks with rather > small black boxes [1] designed for cars, probably > containing a 25x25 ceramic GPS antenna and an > amplifier, progresses over very interesting out- > door constructions for boats and whatnot [2] in > the 20-100 bucks range and finally tops with high > end devices [3] way above 100 bucks. > > The information about the cheap devices is usually > very scarce, but typically boils down to: > > 1575.42 +/- 5MHz > 24-28dB LNA Gain with 10-25mA at (3-5V) > > 7dB f0 +/- 20MHz > 20dB f0 +/- 50MHz > 30dB f0 +/- 100MHz > > They seem to use RG174 and come with SMA as well > as BNC connectors (and a number of others as well). > > The mid range devices seem to use larger antennae > with smaller tolerances (+/- 1MHz) and larger > voltage ranges for the amplifier (3-13V). > > > Questions: > > - What are the key specifications which need to > be verified before buying a GPS antenna? > > - How can they be compared based on incomplete > specifications? > > - Is a place on the roof or in the garden worth > the trouble over the covered balcony? > > - Are there any typical pit-falls or general > tips and tricks regarding mounting and cable > connection to the receiver? > > Many thanks in advance and my apologies again for > the rather lengthy post. Please feel free to point > me to previous discussion regarding this topic. > > All the best, > Herbert > > > [1] http://www.ebay.com/itm/99-Good-GPS-Antenna-SMA-Screw-Needle-10m-Super-Signal-Navigation-DVD-Antenna-/171802461614 > https://www.amazon.com/Waterproof-Active-Antenna-28dB-Gain/dp/B00LXRQY9A > > [2] http://www.ebay.com/itm/Standard-Horizon-XUCMP0014-GPS-Antenna-f-CP150-CP160-CP170/331364914004 > https://www.amazon.com/Garmin-010-12017-00-GPS-GLONASS-Antenna/dp/B00EVT2HSE > https://www.amazon.com/SUNDELY®-External-Marine-Antenna-connector/dp/B00D8WAVTC > > [3] http://www.ebay.com/itm/NEW-FURUNO-GPA018-Gps-dgps-Antenna-/182223355414 > https://www.amazon.com/Garmin-nmea-2000-orders-over/dp/B0089DU96A > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
CA
Chris Albertson
Fri, Aug 5, 2016 12:45 AM
I just wrote that the type of cable hardly matters.  I did not think anyone
would try to use RG174.  That is for 1 foot long jumper cables and
oscilloscope probes at most.  If cost is an issue the 75ohm cable TV wire
is cheap and works better then that tiny sized rg175.
There is no need to buy the high priced stuff as you can buy an antenna
with 30db gain and that makes up for the loss in any reasonable cable.
On Thu, Aug 4, 2016 at 3:32 PM, Alex Pummer alex@pcscons.com wrote:
Hi Herbert,
best solution,
73
KJ6UHN
Alex
Setting:
Antennae:
1575.42 +/- 5MHz
7dB f0 +/- 20MHz
20dB f0 +/- 50MHz
30dB f0 +/- 100MHz
Questions:
    specifications?
All the best,
Herbert
dp/B00LXRQY9A
182223355414
Chris Albertson
Redondo Beach, California
I just wrote that the type of cable hardly matters. I did not think anyone would try to use RG174. That is for 1 foot long jumper cables and oscilloscope probes at most. If cost is an issue the 75ohm cable TV wire is cheap and works better then that tiny sized rg175. There is no need to buy the high priced stuff as you can buy an antenna with 30db gain and that makes up for the loss in any *reasonable* cable. On Thu, Aug 4, 2016 at 3:32 PM, Alex Pummer <alex@pcscons.com> wrote: > Hi Herbert, > > just look the loss of the cable at 1500 MHz, and you will start to cry at > 1500MHz tha cable will have cca 30dB for a 30meter long piece....basically > that RG174 looks very nice with that small antenna but that is the only > positive aspect. Meinberg in Germany has one up/down converting system, > which makes it possible to go more than 50 meter. > On the other hand if you could stay on the balcony and use the cable which > came with the antenna, 2m to 3 meter, you could have a good working > system, but with 15m RG174 is asking to much. For 1500 MHz BNC is not the > best solution, > 73 > KJ6UHN > Alex > P.S.: wo ist diese "Austrian countryside" > > > On 8/4/2016 2:29 PM, Herbert Poetzl wrote: > >> Dear fellow time-nuts! >> >> I'm currently investigating my options regarding >> GPS antennae (of course for time related purposes) >> and I'm really confused by the variety they come >> in ... (my apologies in advance for the long post). >> >> >> Setting: >> >> I'm living in a three storey house with a sloped >> roof, a covered balcony and a larger garden with >> huge trees on the Austrian countryside (Europe). >> >> I've walked around with my smartphone (older one) >> and I get a GPS position fix within 35s in the >> garden (nine satellites shown), within 100s on >> the balcony (also nine satellites), and not a >> single satellite can be seen indoors. >> >> The obvious choice would be to put the antenna on >> top in the middle of the slanted roof for a perfect >> sky view, but this brings a number of problems as >> the roof is very hard to reach and quite high. >> >> I have my 'lab' at the floor where the balcony is, >> so I'm considering putting an antenna there and >> run about 5-15m of coax cable to the GPS receiver. >> The advantage there is that the antenna would be >> somewhat protected (it still gets very hot during >> summer and very cold during winter, but no rain >> and no snow) and easy to reach for maintenance. >> >> The third alternative would be to put the antenna >> somewhere in the garden and have a rather long >> cable running to the house and up to my lab. >> >> >> Antennae: >> >> Looking on eBay and Amazon shows a huge pricerange >> for active GPS antennae with and without cable. >> >> It seems to start at about 10 bucks with rather >> small black boxes [1] designed for cars, probably >> containing a 25x25 ceramic GPS antenna and an >> amplifier, progresses over very interesting out- >> door constructions for boats and whatnot [2] in >> the 20-100 bucks range and finally tops with high >> end devices [3] way above 100 bucks. >> >> The information about the cheap devices is usually >> very scarce, but typically boils down to: >> >> 1575.42 +/- 5MHz >> 24-28dB LNA Gain with 10-25mA at (3-5V) >> >> 7dB f0 +/- 20MHz >> 20dB f0 +/- 50MHz >> 30dB f0 +/- 100MHz >> >> They seem to use RG174 and come with SMA as well >> as BNC connectors (and a number of others as well). >> >> The mid range devices seem to use larger antennae >> with smaller tolerances (+/- 1MHz) and larger >> voltage ranges for the amplifier (3-13V). >> >> >> Questions: >> >> - What are the key specifications which need to >> be verified before buying a GPS antenna? >> >> - How can they be compared based on incomplete >> specifications? >> >> - Is a place on the roof or in the garden worth >> the trouble over the covered balcony? >> >> - Are there any typical pit-falls or general >> tips and tricks regarding mounting and cable >> connection to the receiver? >> >> Many thanks in advance and my apologies again for >> the rather lengthy post. Please feel free to point >> me to previous discussion regarding this topic. >> >> All the best, >> Herbert >> >> >> [1] http://www.ebay.com/itm/99-Good-GPS-Antenna-SMA-Screw-Needle >> -10m-Super-Signal-Navigation-DVD-Antenna-/171802461614 >> https://www.amazon.com/Waterproof-Active-Antenna-28dB-Gain/ >> dp/B00LXRQY9A >> >> [2] http://www.ebay.com/itm/Standard-Horizon-XUCMP0014-GPS- >> Antenna-f-CP150-CP160-CP170/331364914004 >> https://www.amazon.com/Garmin-010-12017-00-GPS- >> GLONASS-Antenna/dp/B00EVT2HSE >> https://www.amazon.com/SUNDELY®-External-Marine- >> Antenna-connector/dp/B00D8WAVTC >> >> [3] http://www.ebay.com/itm/NEW-FURUNO-GPA018-Gps-dgps-Antenna-/ >> 182223355414 >> https://www.amazon.com/Garmin-nmea-2000-orders-over/dp/B0089DU96A >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to https://www.febo.com/cgi-bin/m >> ailman/listinfo/time-nuts >> and follow the instructions there. >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> Version: 2016.0.7690 / Virus Database: 4627/12745 - Release Date: 08/04/16 >> > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/m > ailman/listinfo/time-nuts > and follow the instructions there. > -- Chris Albertson Redondo Beach, California
C
cfo
Fri, Aug 5, 2016 6:36 AM
Setting:
(Europe).
I'm using this type (26dB, N Connector) on my balcony (South).
It's mounted on a 1m waterpipe, that is "stripped" to the balcony fence.
I initially bought a 40dB , but had to change to 26dB , due to too much
gain.
www.ebay.com/itm/PCTEL-GPS-TMG-26N-26-dB-Internal-Amplifier-Timing-
Reference-Antenna-/232037804675
www.ebay.com/itm/Lucent-Datum-KS24019L112C-GPS-26dB-5V-Antenna-Telecom-
Timing-N-Conn-Andrews-NEW-/361510967153
I use a Tbolt, that have 75ohm impedance , and am using about 25m quad
shielded 75 ohm , quality sattelite cable from the balcony to the Tbolt.
I'm using a N-->F adapter at the antenna end, that makes it super easy to
make a diy F-->F connector cable.
I now have installed a quad active antenna splitter (50ohm) , using the
same 75ohm cable , and a F-->N adapter at the splitter end. And see no
noticable problems using 75ohm cable there.
CFO
Denmark
On Thu, 04 Aug 2016 23:29:06 +0200, Herbert Poetzl wrote: > Dear fellow time-nuts! > > I'm currently investigating my options regarding GPS antennae (of course > for time related purposes) > and I'm really confused by the variety they come in ... (my apologies in > advance for the long post). > > > Setting: > > I'm living in a three storey house with a sloped roof, a covered balcony > and a larger garden with huge trees on the Austrian countryside > (Europe). I'm using this type (26dB, N Connector) on my balcony (South). It's mounted on a 1m waterpipe, that is "stripped" to the balcony fence. I initially bought a 40dB , but had to change to 26dB , due to too much gain. www.ebay.com/itm/PCTEL-GPS-TMG-26N-26-dB-Internal-Amplifier-Timing- Reference-Antenna-/232037804675 www.ebay.com/itm/Lucent-Datum-KS24019L112C-GPS-26dB-5V-Antenna-Telecom- Timing-N-Conn-Andrews-NEW-/361510967153 I use a Tbolt, that have 75ohm impedance , and am using about 25m quad shielded 75 ohm , quality sattelite cable from the balcony to the Tbolt. I'm using a N-->F adapter at the antenna end, that makes it super easy to make a diy F-->F connector cable. I now have installed a quad active antenna splitter (50ohm) , using the same 75ohm cable , and a F-->N adapter at the splitter end. And see no noticable problems using 75ohm cable there. CFO Denmark
DJ
David J Taylor
Fri, Aug 5, 2016 7:41 AM
All the best,
Herbert
[1]
Herbert,
Based on practical experiences here the antenna [1] on the balcony (outside)
would be more than adequate for a modern receiver.  Receivers from 10-15
years back are less sensitive and may require an antenna more like [2] (but
that has BNC connector).
I would try the cheaper antenna first, and it's no great loss if you have to
abandon it later.
I don't believe that you mentioned what receiver this was for.
Cheers,
David
SatSignal Software - Quality software written to your requirements
Web: http://www.satsignal.eu
Email: david-taylor@blueyonder.co.uk
Twitter: @gm8arv
Dear fellow time-nuts! I'm currently investigating my options regarding GPS antennae (of course for time related purposes) and I'm really confused by the variety they come in ... (my apologies in advance for the long post). [] Many thanks in advance and my apologies again for the rather lengthy post. Please feel free to point me to previous discussion regarding this topic. All the best, Herbert [1] http://www.ebay.com/itm/99-Good-GPS-Antenna-SMA-Screw-Needle-10m-Super-Signal-Navigation-DVD-Antenna-/171802461614 https://www.amazon.com/Waterproof-Active-Antenna-28dB-Gain/dp/B00LXRQY9A ======================= Herbert, Based on practical experiences here the antenna [1] on the balcony (outside) would be more than adequate for a modern receiver. Receivers from 10-15 years back are less sensitive and may require an antenna more like [2] (but that has BNC connector). I would try the cheaper antenna first, and it's no great loss if you have to abandon it later. I don't believe that you mentioned what receiver this was for. Cheers, David -- SatSignal Software - Quality software written to your requirements Web: http://www.satsignal.eu Email: david-taylor@blueyonder.co.uk Twitter: @gm8arv
"G
"Björn Gabrielsson"
Fri, Aug 5, 2016 8:30 AM
Take a look at (yes M$ Silverlight is needed...:( )
 http://www.gnssplanningonline.com/
On "Settings" enter
1) your position (lat, lon, h) - or chose approx position from map.
2) change "cutoff" to 0 deg
3) change "Time span" to max (24h).
On "Satellite library"
1) Disable Glonass, Galileo, BeiDou and QZSS (only GPS remain selected)
Then view "Sky Plot". This is an illustration where the satellites can be
seen by your antenna, with no blocking from house, trees, mountains etc.
The blue outer circle represents the horizon, north up, etc. Circle center
is straigt up into the sky. The fainter grey circles shows 30 and 60 deg
elevation from the horizon.
- Moving the time-ruler (lower-right corner) will show the satellites
move over the selected position.
- While moving the time-ruler around, notice that there is a circle
from north horizon:ish and down (with a latitude of ca N45deg, where
there are never any satellites.
- Where this circle is depends on your latitude.  (check N90deg -north
pole and N0deg (equator) to get a feel of how the priority
directions(azimuth)/elevations are.
You can model your specific obstruction environment at different possible
antenna sites with "Settings" -> "Obstructions".
What is an obstruction? it depends, but first order approx is that
anything that blocks your view will count.
What kind of GPS-receivers will you use? Old receivers (10+years) will
need better installations/locations. Modern high sensitivity receivers
will work decently within many houses. For long cable runs, older receiver
will be more picky, etc.
Good luck!
Björn
>> The real question is how much of a sky view you get. > >> Ideally you would like a clear view of the sky from >> about NE clear around to NW (270 degrees). > > That would opt for the balcony, as it faces north > and extends the slanted roof, so basically clear > view from NE to NW down to the horizon. > Take a look at (yes M$ Silverlight is needed...:( ) http://www.gnssplanningonline.com/ On "Settings" enter 1) your position (lat, lon, h) - or chose approx position from map. 2) change "cutoff" to 0 deg 3) change "Time span" to max (24h). On "Satellite library" 1) Disable Glonass, Galileo, BeiDou and QZSS (only GPS remain selected) Then view "Sky Plot". This is an illustration where the satellites can be seen by your antenna, with no blocking from house, trees, mountains etc. The blue outer circle represents the horizon, north up, etc. Circle center is straigt up into the sky. The fainter grey circles shows 30 and 60 deg elevation from the horizon. - Moving the time-ruler (lower-right corner) will show the satellites move over the selected position. - While moving the time-ruler around, notice that there is a circle from north horizon:ish and down (with a latitude of ca N45deg, where there are never any satellites. - Where this circle is depends on your latitude. (check N90deg -north pole and N0deg (equator) to get a feel of how the priority directions(azimuth)/elevations are. You can model your specific obstruction environment at different possible antenna sites with "Settings" -> "Obstructions". What is an obstruction? it depends, but first order approx is that anything that blocks your view will count. What kind of GPS-receivers will you use? Old receivers (10+years) will need better installations/locations. Modern high sensitivity receivers will work decently within many houses. For long cable runs, older receiver will be more picky, etc. Good luck! -- Björn
ES
Eric Scace
Fri, Aug 5, 2016 2:37 PM
Unfortunately, an antenna, cable, or piece of electronics located indoors is just as susceptible to lightning surges as one that is outdoors.
Lightning-induced surges couple into these systems electromagnetically across a wide range (VLF to SHF) of frequencies. When you think about your home from an electromagnetic viewpoint, just imagine your structure with all non-conductive materials absent. For a typical wood or brick/stone house in North America, what you are left with is:
metal plumbing pipes and fixtures, with their geometry suspended in space
house wiring, CATV, Ethernet, and telephone cabling, and their service drops, all suspended in space
electrical & electronic circuits of every kind (WiFi note, computer, appliances), their power supplies and AC power cords, also suspended in space
metal furniture? That’s hanging out there, suspended in space, too.
any I-beam or other steel structural elements, some random aluminum flashing, door knobs, and other similar metal construction materials used in the home.
That is what an electromagnetic pulse sees as it approaches and sweeps over your home… all hovering over a lossy ground plane (earth) its varying dielectric constant.. Each one of those pieces of metal, hanging in space, is an unintentional antenna that experiences voltage differentials and current flows.
A GPS antenna and its coax line that is installed next to a window is no different from the same antenna/coax installed one meter outside the window… or 10 meters away outside the window. All three installations are effectively “outdoors” from an electromagnetic viewpoint, and all three need effective surge protection from lightning-, cloud-, and precipitation-induced voltage surges.
(N.B.: Snow can be particularly bad for voltage surges. I’ve seen thousands of volts per meter potential differences in moderate-to-heavy snowfall that produced very significant current flows on cables.)
Surge protection for your antenna, its attachment to your receiver(s), AC/DC power supply lines, and any other signal lines of significant length is cheap insurance.
My continuously-operating electronics lives in an enclosed rack cabinet — not too much worse than a proper Faraday cage. Every cable entering the cabinet has surge protection at the point of entry. The cabinet is bonded to earth ground by 2” copper flashing. In the past this system lived 22 years on a mountaintop home, 1200 ft above surrounding terrain. Lots of thunderstorms — zero damage/disruptions during that time… a sample size of one, admittedly, but during the first 18 months at that site I had two lightning-surge damaging events before I got serious about protection.
I have equipment at a coastal site with multiple 130-ft towers. That site had damage events every 2 years or so — even when cables to the “outside” were disconnected, and AC mains power was shut off at the main circuit breaker box. After implementing comprehensive surge protection, we have had zero damage over the last 12 years.
— Eric
what to use there?
both are required.
receiver(s).
Unfortunately, an antenna, cable, or piece of electronics located indoors is just as susceptible to lightning surges as one that is outdoors. Lightning-induced surges couple into these systems electromagnetically across a wide range (VLF to SHF) of frequencies. When you think about your home from an electromagnetic viewpoint, just imagine your structure with all non-conductive materials absent. For a typical wood or brick/stone house in North America, what you are left with is: metal plumbing pipes and fixtures, with their geometry suspended in space house wiring, CATV, Ethernet, and telephone cabling, and their service drops, all suspended in space electrical & electronic circuits of every kind (WiFi note, computer, appliances), their power supplies and AC power cords, also suspended in space metal furniture? That’s hanging out there, suspended in space, too. any I-beam or other steel structural elements, some random aluminum flashing, door knobs, and other similar metal construction materials used in the home. That is what an electromagnetic pulse sees as it approaches and sweeps over your home… all hovering over a lossy ground plane (earth) its varying dielectric constant.. Each one of those pieces of metal, hanging in space, is an unintentional antenna that experiences voltage differentials and current flows. A GPS antenna and its coax line that is installed next to a window is no different from the same antenna/coax installed one meter outside the window… or 10 meters away outside the window. All three installations are effectively “outdoors” from an electromagnetic viewpoint, and all three need effective surge protection from lightning-, cloud-, and precipitation-induced voltage surges. (N.B.: Snow can be particularly bad for voltage surges. I’ve seen thousands of volts per meter potential differences in moderate-to-heavy snowfall that produced very significant current flows on cables.) Surge protection for your antenna, its attachment to your receiver(s), AC/DC power supply lines, and any other signal lines of significant length is cheap insurance. My continuously-operating electronics lives in an enclosed rack cabinet — not too much worse than a proper Faraday cage. Every cable entering the cabinet has surge protection at the point of entry. The cabinet is bonded to earth ground by 2” copper flashing. In the past this system lived 22 years on a mountaintop home, 1200 ft above surrounding terrain. Lots of thunderstorms — zero damage/disruptions during that time… a sample size of one, admittedly, but during the first 18 months at that site I had two lightning-surge damaging events before I got serious about protection. I have equipment at a coastal site with multiple 130-ft towers. That site had damage events every 2 years or so — even when cables to the “outside” were disconnected, and AC mains power was shut off at the main circuit breaker box. After implementing comprehensive surge protection, we have had zero damage over the last 12 years. — Eric > On 2016 Aug 04, at 19:46 , Bob Camp <kb8tq@n1k.org> wrote: > >>> Grounding the antenna is always a good idea. >> >>> A surge suppressor in the line could save you some >>> real cost if there is a lightning strike. >> >> I did a quick search for SMA/BNC/TNC based surge >> protectors and not much did come up, any suggestions >> what to use there? > > There are a *lot* of them on eBay. Many of them have N connectors on them. > >> >>> I don’t know about Austria, but here in the US, >>> both are required. >> >> Outside definitely, "inside" I'm not sure, but it >> won't hurt to have additional protection for the >> receiver(s). > > It is a good bet that the antenna will be outside. I’d plan it that way.
BC
Bob Camp
Fri, Aug 5, 2016 5:45 PM
Hi
A ten foot long antenna cable is no more or less an issue indoors than a ten foot serial cable
to a laptop or a ten foot test lead running off of a DVM. They all will pick up a spike if the field
is strong enough. If you are in a high risk location, then yes you will need to go to extremes
for all of those cables. In some cases the only real answer is an external faraday cage around
the entire structure (plus a lot of other stuff).
Bob
— Eric
what to use there?
both are required.
receiver(s).
Hi A ten foot long antenna cable is no more or less an issue indoors than a ten foot serial cable to a laptop or a ten foot test lead running off of a DVM. They all will pick up a spike if the field is strong enough. If you are in a high risk location, then yes you will need to go to extremes for all of those cables. In some cases the only real answer is an external faraday cage around the entire structure (plus a lot of other stuff). Bob > On Aug 5, 2016, at 10:37 AM, Eric Scace <eric@scace.org> wrote: > > Unfortunately, an antenna, cable, or piece of electronics located indoors is just as susceptible to lightning surges as one that is outdoors. > > Lightning-induced surges couple into these systems electromagnetically across a wide range (VLF to SHF) of frequencies. When you think about your home from an electromagnetic viewpoint, just imagine your structure with all non-conductive materials absent. For a typical wood or brick/stone house in North America, what you are left with is: > metal plumbing pipes and fixtures, with their geometry suspended in space > house wiring, CATV, Ethernet, and telephone cabling, and their service drops, all suspended in space > electrical & electronic circuits of every kind (WiFi note, computer, appliances), their power supplies and AC power cords, also suspended in space > metal furniture? That’s hanging out there, suspended in space, too. > any I-beam or other steel structural elements, some random aluminum flashing, door knobs, and other similar metal construction materials used in the home. > That is what an electromagnetic pulse sees as it approaches and sweeps over your home… all hovering over a lossy ground plane (earth) its varying dielectric constant.. Each one of those pieces of metal, hanging in space, is an unintentional antenna that experiences voltage differentials and current flows. > > A GPS antenna and its coax line that is installed next to a window is no different from the same antenna/coax installed one meter outside the window… or 10 meters away outside the window. All three installations are effectively “outdoors” from an electromagnetic viewpoint, and all three need effective surge protection from lightning-, cloud-, and precipitation-induced voltage surges. > > (N.B.: Snow can be particularly bad for voltage surges. I’ve seen thousands of volts per meter potential differences in moderate-to-heavy snowfall that produced very significant current flows on cables.) > > Surge protection for your antenna, its attachment to your receiver(s), AC/DC power supply lines, and any other signal lines of significant length is cheap insurance. > > My continuously-operating electronics lives in an enclosed rack cabinet — not too much worse than a proper Faraday cage. Every cable entering the cabinet has surge protection at the point of entry. The cabinet is bonded to earth ground by 2” copper flashing. In the past this system lived 22 years on a mountaintop home, 1200 ft above surrounding terrain. Lots of thunderstorms — zero damage/disruptions during that time… a sample size of one, admittedly, but during the first 18 months at that site I had two lightning-surge damaging events before I got serious about protection. > > I have equipment at a coastal site with multiple 130-ft towers. That site had damage events every 2 years or so — even when cables to the “outside” were disconnected, and AC mains power was shut off at the main circuit breaker box. After implementing comprehensive surge protection, we have had zero damage over the last 12 years. > > — Eric > >> On 2016 Aug 04, at 19:46 , Bob Camp <kb8tq@n1k.org> wrote: >> >>>> Grounding the antenna is always a good idea. >>> >>>> A surge suppressor in the line could save you some >>>> real cost if there is a lightning strike. >>> >>> I did a quick search for SMA/BNC/TNC based surge >>> protectors and not much did come up, any suggestions >>> what to use there? >> >> There are a *lot* of them on eBay. Many of them have N connectors on them. >> >>> >>>> I don’t know about Austria, but here in the US, >>>> both are required. >>> >>> Outside definitely, "inside" I'm not sure, but it >>> won't hurt to have additional protection for the >>> receiver(s). >> >> It is a good bet that the antenna will be outside. I’d plan it that way. > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
TV
Tom Van Baak
Fri, Aug 5, 2016 6:44 PM
Yes, lots of variety! See: http://leapsecond.com/museum/gps-ant/
/tvb
Herbert Poetzl wrote: > I'm currently investigating my options regarding > GPS antennae (of course for time related purposes) > and I'm really confused by the variety they come > in ... (my apologies in advance for the long post). Yes, lots of variety! See: http://leapsecond.com/museum/gps-ant/ /tvb
N
new
Fri, Aug 5, 2016 6:57 PM
Flying a plane with a plexiglas windshield through a snowstorm will give
you a lightning show on your windshield.
Willy
— Eric
what to use there?
both are required.
receiver(s).
Flying a plane with a plexiglas windshield through a snowstorm will give you a lightning show on your windshield. Willy On 8/5/2016 10:37 AM, Eric Scace wrote: > Unfortunately, an antenna, cable, or piece of electronics located indoors is just as susceptible to lightning surges as one that is outdoors. > > Lightning-induced surges couple into these systems electromagnetically across a wide range (VLF to SHF) of frequencies. When you think about your home from an electromagnetic viewpoint, just imagine your structure with all non-conductive materials absent. For a typical wood or brick/stone house in North America, what you are left with is: > metal plumbing pipes and fixtures, with their geometry suspended in space > house wiring, CATV, Ethernet, and telephone cabling, and their service drops, all suspended in space > electrical & electronic circuits of every kind (WiFi note, computer, appliances), their power supplies and AC power cords, also suspended in space > metal furniture? That’s hanging out there, suspended in space, too. > any I-beam or other steel structural elements, some random aluminum flashing, door knobs, and other similar metal construction materials used in the home. > That is what an electromagnetic pulse sees as it approaches and sweeps over your home… all hovering over a lossy ground plane (earth) its varying dielectric constant.. Each one of those pieces of metal, hanging in space, is an unintentional antenna that experiences voltage differentials and current flows. > > A GPS antenna and its coax line that is installed next to a window is no different from the same antenna/coax installed one meter outside the window… or 10 meters away outside the window. All three installations are effectively “outdoors” from an electromagnetic viewpoint, and all three need effective surge protection from lightning-, cloud-, and precipitation-induced voltage surges. > > (N.B.: Snow can be particularly bad for voltage surges. I’ve seen thousands of volts per meter potential differences in moderate-to-heavy snowfall that produced very significant current flows on cables.) > > Surge protection for your antenna, its attachment to your receiver(s), AC/DC power supply lines, and any other signal lines of significant length is cheap insurance. > > My continuously-operating electronics lives in an enclosed rack cabinet — not too much worse than a proper Faraday cage. Every cable entering the cabinet has surge protection at the point of entry. The cabinet is bonded to earth ground by 2” copper flashing. In the past this system lived 22 years on a mountaintop home, 1200 ft above surrounding terrain. Lots of thunderstorms — zero damage/disruptions during that time… a sample size of one, admittedly, but during the first 18 months at that site I had two lightning-surge damaging events before I got serious about protection. > > I have equipment at a coastal site with multiple 130-ft towers. That site had damage events every 2 years or so — even when cables to the “outside” were disconnected, and AC mains power was shut off at the main circuit breaker box. After implementing comprehensive surge protection, we have had zero damage over the last 12 years. > > — Eric > >> On 2016 Aug 04, at 19:46 , Bob Camp <kb8tq@n1k.org> wrote: >> >>>> Grounding the antenna is always a good idea. >>>> A surge suppressor in the line could save you some >>>> real cost if there is a lightning strike. >>> I did a quick search for SMA/BNC/TNC based surge >>> protectors and not much did come up, any suggestions >>> what to use there? >> There are a *lot* of them on eBay. Many of them have N connectors on them. >> >>>> I don’t know about Austria, but here in the US, >>>> both are required. >>> Outside definitely, "inside" I'm not sure, but it >>> won't hurt to have additional protection for the >>> receiver(s). >> It is a good bet that the antenna will be outside. I’d plan it that way. > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
IS
Ian Stirling
Fri, Aug 5, 2016 7:43 PM
My outside GPS aerial came with the NTBW50AA that's still available
from RDR Electronics. It is on a plastic pole tied to the corner of my
deck and is about 12 feet above the ground. It works with the Lucent
RFTG-u pair as well. The 70 ohm cable is about 40 feet long and both
GPSDOs lock quickly from cold in my cellar lab/shack.
My first venture with GPS was with my Trimble Flightmate Pro that
I bought in October 1993. I knew GPS was supposed to be a precise time
signal. I had built and programmed a Science of Cambridge SC/MP
(INS8060) based computer that decoded the MSF Rugby (no longer there)
60 kHz signal in 1979, still using it in 1994. Comparing it to the
received GPS time on the Trimble, I was dismayed. My records show
that on 1994 June 23 1700 UTC, GPS, or the Trimble, was a whopping
3 seconds slow,vbehind. 1994 July 03 1538 UTC, zero, seemed to be
synchronous. Same day, 1545, 1/2 a second slow. 1552, 2 seconds slow.
1556 1/2 a second slow. I suspect this was due to Selective Availability
that was not turned off until President Clinton ordered it off
in May 2000.
I have a Navsync CW12-TIM that I bought in 2009. Its diminutive
antenna sticks magnetically to a steel filing cabinet in my office.
I get a good signal and lock there.
 In August 2003, I put my hand out of the back door to test the rain.
A lightning bolt split a tree 60 feet away - my wife called me Thor
for many years. The doorbell rang, the garage door control board was
fried and needed replacing, a router in my upstairs office was
blackened, and in 2003, every television and computer monitor in the
house was a CRT - every one of them had to go through several degaussing
sessions.
Best wishes,
Ian, G4ICV, AB2GR
On 08/05/2016 01:45 PM, Bob Camp wrote: > A ten foot long antenna cable is no more or less an issue indoors than a ten foot serial cable > to a laptop or a ten foot test lead running off of a DVM. They all will pick up a spike if the field > is strong enough. If you are in a high risk location, then yes you will need to go to extremes > for all of those cables. In some cases the only real answer is an external faraday cage around > the entire structure (plus a lot of other stuff). My outside GPS aerial came with the NTBW50AA that's still available from RDR Electronics. It is on a plastic pole tied to the corner of my deck and is about 12 feet above the ground. It works with the Lucent RFTG-u pair as well. The 70 ohm cable is about 40 feet long and both GPSDOs lock quickly from cold in my cellar lab/shack. My first venture with GPS was with my Trimble Flightmate Pro that I bought in October 1993. I knew GPS was supposed to be a precise time signal. I had built and programmed a Science of Cambridge SC/MP (INS8060) based computer that decoded the MSF Rugby (no longer there) 60 kHz signal in 1979, still using it in 1994. Comparing it to the received GPS time on the Trimble, I was dismayed. My records show that on 1994 June 23 1700 UTC, GPS, or the Trimble, was a whopping 3 seconds slow,vbehind. 1994 July 03 1538 UTC, zero, seemed to be synchronous. Same day, 1545, 1/2 a second slow. 1552, 2 seconds slow. 1556 1/2 a second slow. I suspect this was due to Selective Availability that was not turned off until President Clinton ordered it off in May 2000. I have a Navsync CW12-TIM that I bought in 2009. Its diminutive antenna sticks magnetically to a steel filing cabinet in my office. I get a good signal and lock there. In August 2003, I put my hand out of the back door to test the rain. A lightning bolt split a tree 60 feet away - my wife called me Thor for many years. The doorbell rang, the garage door control board was fried and needed replacing, a router in my upstairs office was blackened, and in 2003, every television and computer monitor in the house was a CRT - every one of them had to go through several degaussing sessions. Best wishes, Ian, G4ICV, AB2GR --
AK
Attila Kinali
Fri, Aug 5, 2016 8:51 PM
Hi Eric,
On Fri, 5 Aug 2016 10:37:28 -0400
Please please please do NOT spread dangerous information like this!
While it is true, that an indoor antenna is suceptible to surges like
an outdoor antenna, it is not true that an outdoor antenna is equivalent
to an indoor antenna when it comes to lightning protection.
Because an outdoor antenna can be directly hit by a lightning.
To protect the house and its inhabitants from the lightning strike,
an external antenna needs to be either lower than any lightning rod
and within its 45m ball or needs its own conductor and grounding
to discharge any lightning energy and thus preventing it from following
the antenna cable into the house.
Please be aware that the grounding of the antenna is not to protect
the equipment from surges, but to prevent conduction of the lightning
into the house that could cause electrocution and fires.
		Attila Kinali
Malek's Law:
Any simple idea will be worded in the most complicated way.
Hi Eric, On Fri, 5 Aug 2016 10:37:28 -0400 Eric Scace <eric@scace.org> wrote: > A GPS antenna and its coax line that is installed next to a window is no > different from the same antenna/coax installed one meter outside the window… > or 10 meters away outside the window. All three installations are > effectively “outdoors” from an electromagnetic viewpoint, and all three need > effective surge protection from lightning-, cloud-, and precipitation- > induced voltage surges. Please please please do NOT spread dangerous information like this! While it is true, that an indoor antenna is suceptible to surges like an outdoor antenna, it is not true that an outdoor antenna is equivalent to an indoor antenna when it comes to lightning protection. Because an outdoor antenna can be _directly_ hit by a lightning. To protect the house and its inhabitants from the lightning strike, an external antenna needs to be either lower than any lightning rod and within its 45m ball or needs its own conductor and grounding to discharge any lightning energy and thus preventing it from following the antenna cable into the house. Please be aware that the grounding of the antenna is not to protect the equipment from surges, but to prevent conduction of the lightning into the house that could cause electrocution and fires. Attila Kinali -- Malek's Law: Any simple idea will be worded in the most complicated way.
GE
Gary E. Miller
Fri, Aug 5, 2016 9:47 PM
Yo Attila!
On Fri, 5 Aug 2016 22:51:06 +0200
protection.
I agree there are differences.  But not as mmuch as you think.
And so can an indoor antetnna.  I live it lightning country, and it is
common for a lightning bolt to travel right through an asphalt roof to
hit metal pipes and/or wire inside a house.
I have seen this many times, it has happened to my next door neighbor and
to my son.  If you are lucky your homeowners insurance will cover a lot of
the damage.
A direct hit on an antenna will laugh at your surge protector.  Nothing
at all can protect your electrical system from a direct hit.
I have seen 440V main switchboards exploded from lightning hits.  The
mess is incredible.  The switchboard case looks like a large bomb went off
inside and the cover leaves a dent on the far wall.
The surge protector on your antenna coax will try to limit the static
voltage on the center conductor to about 1,500V.  Now you have turned
your antenna into a passable lightning rod.
If you have any doubt about lightning you need to get some lightning rods
on your roof.  A usually passable solution is to run #8 wire from your
offical building ground directly up to an antenna mast or two on your
roof.  Best if it can be done with zero splices.
The point of the lightning rod is not to dissipate a lightning strike,
nothing can do that.  Instead it bleeds away static before it becomes
a lightning strike.
In the midwest in the winter the humidity in a house can get well below
5% and 1,500V of statis is quite common.  So indoor surge protectors
can also be useful.
RGDS
GARY
Gary E. Miller Rellim 109 NW Wilmington Ave., Suite E, Bend, OR 97703
gem@rellim.com  Tel:+1 541 382 8588
Yo Attila! On Fri, 5 Aug 2016 22:51:06 +0200 Attila Kinali <attila@kinali.ch> wrote: > While it is true, that an indoor antenna is suceptible to surges like > an outdoor antenna, it is not true that an outdoor antenna is > equivalent to an indoor antenna when it comes to lightning > protection. I agree there are differences. But not as mmuch as you think. > Because an outdoor antenna can be _directly_ hit by a lightning. And so can an indoor antetnna. I live it lightning country, and it is common for a lightning bolt to travel right through an asphalt roof to hit metal pipes and/or wire inside a house. I have seen this many times, it has happened to my next door neighbor and to my son. If you are lucky your homeowners insurance will cover a lot of the damage. > Please be aware that the grounding of the antenna is not to protect > the equipment from surges, but to prevent conduction of the lightning > into the house that could cause electrocution and fires. A direct hit on an antenna will laugh at your surge protector. Nothing at all can protect your electrical system from a direct hit. I have seen 440V main switchboards exploded from lightning hits. The mess is incredible. The switchboard case looks like a large bomb went off inside and the cover leaves a dent on the far wall. The surge protector on your antenna coax will try to limit the static voltage on the center conductor to about 1,500V. Now you have turned your antenna into a passable lightning rod. > To protect the house and its inhabitants from the lightning strike, > an external antenna needs to be either lower than any lightning rod > and within its 45m ball or needs its own conductor and grounding > to discharge any lightning energy and thus preventing it from following > the antenna cable into the house. If you have any doubt about lightning you need to get some lightning rods on your roof. A usually passable solution is to run #8 wire from your offical building ground directly up to an antenna mast or two on your roof. Best if it can be done with zero splices. The point of the lightning rod is not to dissipate a lightning strike, nothing can do that. Instead it bleeds away static before it becomes a lightning strike. In the midwest in the winter the humidity in a house can get well below 5% and 1,500V of statis is quite common. So indoor surge protectors can also be useful. RGDS GARY --------------------------------------------------------------------------- Gary E. Miller Rellim 109 NW Wilmington Ave., Suite E, Bend, OR 97703 gem@rellim.com Tel:+1 541 382 8588
AP
Alexander Pummer
Sat, Aug 6, 2016 12:28 AM
lightening protection:
http://www.ul.com/wp-content/uploads/2014/04/LightningProtectionAG.pdf
73
KJ6UHN
Alex
On 8/5/2016 1:51 PM, Attila Kinali wrote:
Hi Eric,
		Attila Kinali
lightening protection: http://www.ul.com/wp-content/uploads/2014/04/LightningProtectionAG.pdf 73 KJ6UHN Alex On 8/5/2016 1:51 PM, Attila Kinali wrote: > Hi Eric, > > On Fri, 5 Aug 2016 10:37:28 -0400 > Eric Scace <eric@scace.org> wrote: > >> A GPS antenna and its coax line that is installed next to a window is no >> different from the same antenna/coax installed one meter outside the window… >> or 10 meters away outside the window. All three installations are >> effectively “outdoors” from an electromagnetic viewpoint, and all three need >> effective surge protection from lightning-, cloud-, and precipitation- >> induced voltage surges. > Please please please do NOT spread dangerous information like this! > > While it is true, that an indoor antenna is suceptible to surges like > an outdoor antenna, it is not true that an outdoor antenna is equivalent > to an indoor antenna when it comes to lightning protection. > > Because an outdoor antenna can be _directly_ hit by a lightning. > > To protect the house and its inhabitants from the lightning strike, > an external antenna needs to be either lower than any lightning rod > and within its 45m ball or needs its own conductor and grounding > to discharge any lightning energy and thus preventing it from following > the antenna cable into the house. > > Please be aware that the grounding of the antenna is not to protect > the equipment from surges, but to prevent conduction of the lightning > into the house that could cause electrocution and fires. > > Attila Kinali >
CA
Chris Albertson
Sat, Aug 6, 2016 1:31 AM
You guys, well some of you are mixing to things
  1. the building code requirement to ground an antenna is for the protection
    of the building.  The building code don't care if you electronics is fried
    or not.  The wire and ground rod keep the antenna mast at earth potential.
  2. Those surge protectors and grounding your electronics to a common point
    an al other advice then grounding the most to a rod by the nearest route
    down the side of the house.  These are different things
So, outdoor antenna are different from indoor antenna in that if you indoor
antenna is struck the house is already pretty much toasted.  You still
might want a surge protector to protect the receiver.
The question is if you need to buy a $40 surge protector for your $8
Motorola Encore receiver?  But no question if you need a group wire in the
mast, even for that $8 gps receiver because that wire protects the house
Part of the equation is where you live.  In many years of living in Redondo
Beach, CA I never hear of anyone or anything being =damaged by lightening.
We don't even get lighting here but twice a year if that.  On the other
hand I had god protection on my sailboat as that 60 for aluminum mast might
be the highest thing around on the ocean for miles.  That mast has a very
solid connection straight to saltwater.  You have to evaluate the risk and
consequence.  You get different answer in Orlando Florida then I get here.
You guys, well some of you are mixing to things 1) the building code requirement to ground an antenna is for the protection of the building. The building code don't care if you electronics is fried or not. The wire and ground rod keep the antenna mast at earth potential. 2) Those surge protectors and grounding your electronics to a common point an al other advice then grounding the most to a rod by the nearest route down the side of the house. These are different things So, outdoor antenna are different from indoor antenna in that if you indoor antenna is struck the house is already pretty much toasted. You still might want a surge protector to protect the receiver. The question is if you need to buy a $40 surge protector for your $8 Motorola Encore receiver? But no question if you need a group wire in the mast, even for that $8 gps receiver because that wire protects the house Part of the equation is where you live. In many years of living in Redondo Beach, CA I never hear of anyone or anything being =damaged by lightening. We don't even get lighting here but twice a year if that. On the other hand I had god protection on my sailboat as that 60 for aluminum mast might be the highest thing around on the ocean for miles. That mast has a very solid connection straight to saltwater. You have to evaluate the risk and consequence. You get different answer in Orlando Florida then I get here.
BC
Bob Camp
Sat, Aug 6, 2016 2:21 AM
Hi
Ummm ….. It’s a lot more fun to focus on the 0.001% case :)
Bob
Hi Ummm ….. It’s a *lot* more fun to focus on the 0.001% case :) Bob > On Aug 5, 2016, at 9:31 PM, Chris Albertson <albertson.chris@gmail.com> wrote: > > You guys, well some of you are mixing to things > > 1) the building code requirement to ground an antenna is for the protection > of the building. The building code don't care if you electronics is fried > or not. The wire and ground rod keep the antenna mast at earth potential. > > > 2) Those surge protectors and grounding your electronics to a common point > an al other advice then grounding the most to a rod by the nearest route > down the side of the house. These are different things > > So, outdoor antenna are different from indoor antenna in that if you indoor > antenna is struck the house is already pretty much toasted. You still > might want a surge protector to protect the receiver. > > The question is if you need to buy a $40 surge protector for your $8 > Motorola Encore receiver? But no question if you need a group wire in the > mast, even for that $8 gps receiver because that wire protects the house > > Part of the equation is where you live. In many years of living in Redondo > Beach, CA I never hear of anyone or anything being =damaged by lightening. > We don't even get lighting here but twice a year if that. On the other > hand I had god protection on my sailboat as that 60 for aluminum mast might > be the highest thing around on the ocean for miles. That mast has a very > solid connection straight to saltwater. You have to evaluate the risk and > consequence. You get different answer in Orlando Florida then I get here. > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
GL
Glenn Little WB4UIV
Sat, Aug 6, 2016 2:46 AM
A very good reference for EMP protection is MIL-HDBK-419.
This is downloadable for a number of web sources.
It is about 600 pages and is in two volumes.
This discusses a number of different sources of EMP such as nuclear and
lightning.
A lot is for protection of military industrial complexes, but, there is
a lot that pertains to us.
I worked for a military complex that assembled nuclear missiles.
The site was built to this handbook specs.
We had no EMP related damage at the site.
Number one rule, bond all grounds together. If something on your
property takes a hit, you want everything on your property to elevate to
the same level and the same rate.
If you have multiple, non bonded grounds, there is a different reference
for each ground. This is a major source for disaster.
I spent seven years in lightning mitigation. I was told by professionals
that I was wrong. The third time that their tower was struck, destroying
all of the lights and attached equipment, they followed my
recommendations. That was ten years ago. The three hits were within four
months of each other. The site has been free of destructive hits since then.
73
Glenn
WB4UIV
— Eric
what to use there?
There are a lot of them on eBay. Many of them have N connectors on them.
both are required.
receiver(s).
Glenn Little                ARRL Technical Specialist  QCWA  LM 28417
Amateur Callsign:  WB4UIV            wb4uiv@arrl.net    AMSAT LM 2178
QTH:  Goose Creek, SC USA (EM92xx)  USSVI LM  NRA LM  SBE ARRL TAPR
"It is not the class of license that the Amateur holds but the class
of the Amateur that holds the license"
A very good reference for EMP protection is MIL-HDBK-419. This is downloadable for a number of web sources. It is about 600 pages and is in two volumes. This discusses a number of different sources of EMP such as nuclear and lightning. A lot is for protection of military industrial complexes, but, there is a lot that pertains to us. I worked for a military complex that assembled nuclear missiles. The site was built to this handbook specs. We had no EMP related damage at the site. Number one rule, bond all grounds together. If something on your property takes a hit, you want everything on your property to elevate to the same level and the same rate. If you have multiple, non bonded grounds, there is a different reference for each ground. This is a major source for disaster. I spent seven years in lightning mitigation. I was told by professionals that I was wrong. The third time that their tower was struck, destroying all of the lights and attached equipment, they followed my recommendations. That was ten years ago. The three hits were within four months of each other. The site has been free of destructive hits since then. 73 Glenn WB4UIV On 8/5/2016 10:37 AM, Eric Scace wrote: > Unfortunately, an antenna, cable, or piece of electronics located indoors is just as susceptible to lightning surges as one that is outdoors. > > Lightning-induced surges couple into these systems electromagnetically across a wide range (VLF to SHF) of frequencies. When you think about your home from an electromagnetic viewpoint, just imagine your structure with all non-conductive materials absent. For a typical wood or brick/stone house in North America, what you are left with is: > metal plumbing pipes and fixtures, with their geometry suspended in space > house wiring, CATV, Ethernet, and telephone cabling, and their service drops, all suspended in space > electrical & electronic circuits of every kind (WiFi note, computer, appliances), their power supplies and AC power cords, also suspended in space > metal furniture? That’s hanging out there, suspended in space, too. > any I-beam or other steel structural elements, some random aluminum flashing, door knobs, and other similar metal construction materials used in the home. > That is what an electromagnetic pulse sees as it approaches and sweeps over your home… all hovering over a lossy ground plane (earth) its varying dielectric constant.. Each one of those pieces of metal, hanging in space, is an unintentional antenna that experiences voltage differentials and current flows. > > A GPS antenna and its coax line that is installed next to a window is no different from the same antenna/coax installed one meter outside the window… or 10 meters away outside the window. All three installations are effectively “outdoors” from an electromagnetic viewpoint, and all three need effective surge protection from lightning-, cloud-, and precipitation-induced voltage surges. > > (N.B.: Snow can be particularly bad for voltage surges. I’ve seen thousands of volts per meter potential differences in moderate-to-heavy snowfall that produced very significant current flows on cables.) > > Surge protection for your antenna, its attachment to your receiver(s), AC/DC power supply lines, and any other signal lines of significant length is cheap insurance. > > My continuously-operating electronics lives in an enclosed rack cabinet — not too much worse than a proper Faraday cage. Every cable entering the cabinet has surge protection at the point of entry. The cabinet is bonded to earth ground by 2” copper flashing. In the past this system lived 22 years on a mountaintop home, 1200 ft above surrounding terrain. Lots of thunderstorms — zero damage/disruptions during that time… a sample size of one, admittedly, but during the first 18 months at that site I had two lightning-surge damaging events before I got serious about protection. > > I have equipment at a coastal site with multiple 130-ft towers. That site had damage events every 2 years or so — even when cables to the “outside” were disconnected, and AC mains power was shut off at the main circuit breaker box. After implementing comprehensive surge protection, we have had zero damage over the last 12 years. > > — Eric > >> On 2016 Aug 04, at 19:46 , Bob Camp <kb8tq@n1k.org> wrote: >> >>>> Grounding the antenna is always a good idea. >>> >>>> A surge suppressor in the line could save you some >>>> real cost if there is a lightning strike. >>> >>> I did a quick search for SMA/BNC/TNC based surge >>> protectors and not much did come up, any suggestions >>> what to use there? >> >> There are a *lot* of them on eBay. Many of them have N connectors on them. >> >>> >>>> I don’t know about Austria, but here in the US, >>>> both are required. >>> >>> Outside definitely, "inside" I'm not sure, but it >>> won't hurt to have additional protection for the >>> receiver(s). >> >> It is a good bet that the antenna will be outside. I’d plan it that way. > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > -- ----------------------------------------------------------------------- Glenn Little ARRL Technical Specialist QCWA LM 28417 Amateur Callsign: WB4UIV wb4uiv@arrl.net AMSAT LM 2178 QTH: Goose Creek, SC USA (EM92xx) USSVI LM NRA LM SBE ARRL TAPR "It is not the class of license that the Amateur holds but the class of the Amateur that holds the license" ---------------------------------------------------------------------------
CS
Charles Steinmetz
Sat, Aug 6, 2016 3:48 AM
Tisha Hayes has a big fat folder full of good stuff relating to
"Grounding Surge and Filtering" at her dropbox site, and another one
full of "Transient Protection Documents."  See:
https://www.dropbox.com/sh/qjnu6cp03ahajpc/AAABcWVmOZdyPWquiz3az58Ha?dl=0
Best regards,
Charles
Glenn wrote: > A very good reference for EMP protection is MIL-HDBK-419. > This is downloadable for a number of web sources. Tisha Hayes has a big fat folder full of good stuff relating to "Grounding Surge and Filtering" at her dropbox site, and another one full of "Transient Protection Documents." See: <https://www.dropbox.com/sh/qjnu6cp03ahajpc/AAABcWVmOZdyPWquiz3az58Ha?dl=0> Best regards, Charles
BH
Bill Hawkins
Mon, Aug 8, 2016 3:06 AM
This thread grows old, so here's one person's summary:
There are two ways to be damaged by lightning:
  1. A direct hit pumps 100 kiloamps of electrons into an ohm or so of
    your local wiring. There is no way to survive a direct hit except to
    implement stuff only the Military can afford. The probability is so low
    (outside of Florida and mountain tops) that your homeowners insurance
    may cover it.
  2. A 100 KA strike goes to ground near you, with two effects:
    a. The ground resistance allows a large range of volts per meter to
    kill cows but not golfers with their feet together.
    b. A mighty electromagnetic pulse (EMP) induces voltages in anything
    inductive that is not shielded or twisted.
Case 'a' argues for a single point earth ground. When the ground voltage
goes up, you want all of your equipment to go up with it, as if it was
on an isolated ground plane. It seems best to use the Electric Power
Company's house ground for that reference point in your home. If you use
a UPS for a set of equipment, everything on it should ground to that UPS
(which should have a high capacity surge arrestor). You are left with
telephone cords, TV cables, and antennas as peripheral connections to
protect with surge arrestors. Marine supply stores sell rolls of 4 inch
wide copper strap for connecting the mast on the wheelhouse cabin with
the keel of fiberglass boats. This is also the ground for all electronic
equipment. The strap is considerably less inductive than a wire.
Case 'b' argues against long wires inside the area that contains the
common ground and the surge arrestors at its periphery.
Surge arrestors have energy ratings that refer to the energy of the EMP
that caused the surge. I have no idea how that relates to lightning EMP
energy so I buy the most capacity I can afford.
I used these principles in a home that had a pair of HP GPS antennas
four feet apart on a twenty foot mast of six inch plastic pipe, using N
connectors and 50 feet of RG-8 to a pair of Z3801A receivers. The
neighbor's tree took a direct hit (was split apart) less than 100 feet
away. He had extensive electrical damage originating at the outdoor
flood light six feet from the tree. I lost the GPS antenna closest to
the tree but nothing else. FWIW, I had wireless G access points
separating the area connected to the antenna from the rest of the house
network. No attempt was made to beef up the grounds.
Regards,
Bill Hawkins
This thread grows old, so here's one person's summary: There are two ways to be damaged by lightning: 1. A direct hit pumps 100 kiloamps of electrons into an ohm or so of your local wiring. There is no way to survive a direct hit except to implement stuff only the Military can afford. The probability is so low (outside of Florida and mountain tops) that your homeowners insurance may cover it. 2. A 100 KA strike goes to ground near you, with two effects: a. The ground resistance allows a large range of volts per meter to kill cows but not golfers with their feet together. b. A mighty electromagnetic pulse (EMP) induces voltages in anything inductive that is not shielded or twisted. Case 'a' argues for a single point earth ground. When the ground voltage goes up, you want all of your equipment to go up with it, as if it was on an isolated ground plane. It seems best to use the Electric Power Company's house ground for that reference point in your home. If you use a UPS for a set of equipment, everything on it should ground to that UPS (which should have a high capacity surge arrestor). You are left with telephone cords, TV cables, and antennas as peripheral connections to protect with surge arrestors. Marine supply stores sell rolls of 4 inch wide copper strap for connecting the mast on the wheelhouse cabin with the keel of fiberglass boats. This is also the ground for all electronic equipment. The strap is considerably less inductive than a wire. Case 'b' argues against long wires inside the area that contains the common ground and the surge arrestors at its periphery. Surge arrestors have energy ratings that refer to the energy of the EMP that caused the surge. I have no idea how that relates to lightning EMP energy so I buy the most capacity I can afford. I used these principles in a home that had a pair of HP GPS antennas four feet apart on a twenty foot mast of six inch plastic pipe, using N connectors and 50 feet of RG-8 to a pair of Z3801A receivers. The neighbor's tree took a direct hit (was split apart) less than 100 feet away. He had extensive electrical damage originating at the outdoor flood light six feet from the tree. I lost the GPS antenna closest to the tree but nothing else. FWIW, I had wireless G access points separating the area connected to the antenna from the rest of the house network. No attempt was made to beef up the grounds. Regards, Bill Hawkins
BS
Bob Stewart
Mon, Aug 8, 2016 5:19 AM
Hi Bill,
A lot of us are hams.  The ARRL handbook has a section on grounds, including the need for bonding additional grounds to the power line ground.  A loop of heavy gauge wire around the house that has periodic 8' ground rods is seen as a good thing as long as it's bonded to the power line ground.  This is something entirely different from "multi-point ground".  It is said to provide a circle of protection around the house, but yea, it's a lot more complicated than that.  Check the handbook, or read whatever grounding documents you have access to and trust.
OK, I've had my say.
Bob - AE6RV
AE6RV.com
GFS GPSDO list:
groups.yahoo.com/neo/groups/GFS-GPSDOs/info
To: 'Discussion of precise time and frequency measurement' time-nuts@febo.com
Sent: Sunday, August 7, 2016 10:06 PM
Subject: Re: [time-nuts] GPS antenna selection - lightning
    may cover it.
Regards,
Bill Hawkins
Hi Bill, A lot of us are hams.  The ARRL handbook has a section on grounds, including the need for bonding additional grounds to the power line ground.  A loop of heavy gauge wire around the house that has periodic 8' ground rods is seen as a good thing as long as it's bonded to the power line ground.  This is something entirely different from "multi-point ground".  It is said to provide a circle of protection around the house, but yea, it's a lot more complicated than that.  Check the handbook, or read whatever grounding documents you have access to and trust. OK, I've had my say. Bob - AE6RV  ----------------------------------------------------------------- AE6RV.com GFS GPSDO list: groups.yahoo.com/neo/groups/GFS-GPSDOs/info From: Bill Hawkins <bill.iaxs@pobox.com> To: 'Discussion of precise time and frequency measurement' <time-nuts@febo.com> Sent: Sunday, August 7, 2016 10:06 PM Subject: Re: [time-nuts] GPS antenna selection - lightning This thread grows old, so here's one person's summary: There are two ways to be damaged by lightning: 1. A direct hit pumps 100 kiloamps of electrons into an ohm or so of your local wiring. There is no way to survive a direct hit except to implement stuff only the Military can afford. The probability is so low (outside of Florida and mountain tops) that your homeowners insurance may cover it. 2. A 100 KA strike goes to ground near you, with two effects:   a. The ground resistance allows a large range of volts per meter to kill cows but not golfers with their feet together.   b. A mighty electromagnetic pulse (EMP) induces voltages in anything inductive that is not shielded or twisted. Case 'a' argues for a single point earth ground. When the ground voltage goes up, you want all of your equipment to go up with it, as if it was on an isolated ground plane. It seems best to use the Electric Power Company's house ground for that reference point in your home. If you use a UPS for a set of equipment, everything on it should ground to that UPS (which should have a high capacity surge arrestor). You are left with telephone cords, TV cables, and antennas as peripheral connections to protect with surge arrestors. Marine supply stores sell rolls of 4 inch wide copper strap for connecting the mast on the wheelhouse cabin with the keel of fiberglass boats. This is also the ground for all electronic equipment. The strap is considerably less inductive than a wire. Case 'b' argues against long wires inside the area that contains the common ground and the surge arrestors at its periphery. Surge arrestors have energy ratings that refer to the energy of the EMP that caused the surge. I have no idea how that relates to lightning EMP energy so I buy the most capacity I can afford. I used these principles in a home that had a pair of HP GPS antennas four feet apart on a twenty foot mast of six inch plastic pipe, using N connectors and 50 feet of RG-8 to a pair of Z3801A receivers. The neighbor's tree took a direct hit (was split apart) less than 100 feet away. He had extensive electrical damage originating at the outdoor flood light six feet from the tree. I lost the GPS antenna closest to the tree but nothing else. FWIW, I had wireless G access points separating the area connected to the antenna from the rest of the house network. No attempt was made to beef up the grounds. Regards, Bill Hawkins _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
J
jimlux
Mon, Aug 8, 2016 2:00 PM
No - strap is about the same inductance as a wire of the same length.
The advantage of strap is a lower RF resistance, which is important if
the strap is part of your antenna system, because it's less resistive
loss than a wire.
For lightning impulses, either conducted or radiated, the inductance
dominates the voltage rise (e.g. Xl is much larger than Rac).
Strap or bar may be easier to make connections to (drill a hole in some
1/8x1" bar, tap it, and hook your lug up)
On 8/7/16 8:06 PM, Bill Hawkins wrote: > This thread grows old, so here's one person's summary: > Marine supply stores sell rolls of 4 inch > wide copper strap for connecting the mast on the wheelhouse cabin with > the keel of fiberglass boats. This is also the ground for all electronic > equipment. The strap is considerably less inductive than a wire. No - strap is about the same inductance as a wire of the same length. The advantage of strap is a lower RF resistance, which is important if the strap is part of your antenna system, because it's less resistive loss than a wire. For lightning impulses, either conducted or radiated, the inductance dominates the voltage rise (e.g. Xl is much larger than Rac). Strap or bar may be easier to make connections to (drill a hole in some 1/8x1" bar, tap it, and hook your lug up)
BC
Bob Camp
Mon, Aug 8, 2016 3:13 PM
Hi
We tend to look at all this lighting / EMP stuff very much as a “get to the ground”
sort of thing. For whatever reason the whole thought process stops once we get
to a coper weld rod driven however far into the dirt.
If you try to operate a vertical antenna against that same rod in the middle of a nice dry
summer.  You will quickly find out that dirt != ground. The same fun and games
that get you a low impedance ground for your antenna also apply to a low impedance
ground for your protection system. Its not an identical process, but it’s the same idea.
You can argue that a good bond of everything to a single point is sufficient. Looking around
my house, there is most certainly not a single point of entry for everything. Various
utilities and other wires / chunks of conductive stuff go off in a variety of directions. Like
most homes in the US, it’s a wood frame structure. There is no nice steel frame to
tie everything to. I suppose the first step would be to tear the house down and re-build
it from scratch …..
Bob
Hi We tend to look at all this lighting / EMP stuff very much as a “get to the ground” sort of thing. For whatever reason the whole thought process stops once we get to a coper weld rod driven however far into the dirt. If you try to operate a vertical antenna against that same rod in the middle of a nice dry summer. You will quickly find out that dirt != ground. The same fun and games that get you a low impedance ground for your antenna also apply to a low impedance ground for your protection system. Its not an identical process, but it’s the same idea. You can argue that a good bond of everything to a single point is sufficient. Looking around my house, there is most certainly *not* a single point of entry for everything. Various utilities and other wires / chunks of conductive stuff go off in a variety of directions. Like most homes in the US, it’s a wood frame structure. There is no nice steel frame to tie everything to. I suppose the first step would be to tear the house down and re-build it from scratch ….. Bob > On Aug 8, 2016, at 10:00 AM, jimlux <jimlux@earthlink.net> wrote: > > On 8/7/16 8:06 PM, Bill Hawkins wrote: >> This thread grows old, so here's one person's summary: >> Marine supply stores sell rolls of 4 inch >> wide copper strap for connecting the mast on the wheelhouse cabin with >> the keel of fiberglass boats. This is also the ground for all electronic >> equipment. The strap is considerably less inductive than a wire. > > No - strap is about the same inductance as a wire of the same length. The advantage of strap is a lower RF resistance, which is important if the strap is part of your antenna system, because it's less resistive loss than a wire. > > For lightning impulses, either conducted or radiated, the inductance dominates the voltage rise (e.g. Xl is much larger than Rac). > > Strap or bar may be easier to make connections to (drill a hole in some 1/8x1" bar, tap it, and hook your lug up) > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
