I too have done gazillions of crimps using a ratchet crimper. It works
great for me. It actually makes two crimps at once, one on the metal wire
ferrule and one on the insulation. I then cover the crimp with adhesive
shrink tube (which doesn't always seal the end). The shrink tube helps
provide strain relief where the wire exits the crimp. After I do each
crimp, I tug it a bit to make sure its secure. Sometimes I crimp it in the
next smaller die to get a firm fit. Anyway I find the ratcheting crimper
easier to use than the inexpensive "plier" type.
For big wire lugs, I use the Ancor "hammer on" crimper. Its inexpensive
and works well. With Ancor lugs, I can use a big pair of pump plier to
sqeeze it rather than hammer on it. The Noble big crimps (e.g. #4 AWG) are
harder to crimp.
Currently I am pulling out and replacing old welding type cable. I've had
experience with the fine strands of welding cable breaking over time due to
vibration. Also I am finding all places where small wires branch off from
bigger wires and fusing them when necessary (less ampacity than the big
wire circuit protection). This is concurrent with replacing two golf cart
batteries with two L-16s. I had to make a battery box (per Calder's book)
when I just barely got inside the engine compartment. After unbolting and
moving over the water heater I think I can drop the batteries down into the
box.
Phil Keys KJ7ET
"Kathy K" Sundowner 30 Tug, hull #3
Port Hadlock, WA 98339
philm@keysfamily.org
harder to crimp.
REPLY
Regarding the "hammer on" crimper.
I have found more than a few inverter installations where this tool caused a
problem. Sometimes it works, but other times the crimp is less than perfect
and there is excess resistance in the connection.
This resistance causes localized heating and excess voltage drops.
For starter cables this is fine, since the high current flow only last a few
seconds but for inverter cables wher the high current is sustained for long
periods of time; any imperfection means excess resistance.
Like the case of a hand plier crimp versus a ratchet crimper, much more
care and experience is needed to use this tool and get consistently good
crimps.
cheers
Arild
<<Regarding the "hammer on" crimper.
crimp is less than perfect>>
Arild,
I find that using the "hammer-on" crimper in my bench
vise is greatly superior to using a hammer. Whenever
possible, I make up my battery cables on the bench,
then install them.
Mark Richter, Winnie the Pooh
Mark's Mobile Marine
Do You Yahoo!?
Yahoo! Health - Feel better, live better
http://health.yahoo.com
then install them.
REPLY
Yes a good improvisation. Essentially using the leverage of the vice screw to
duplicate the leverage we get with the long handles.
Unfortunately, this doesn't work too well if the cables are run in the boat and it
isn't practical to precut and pre terminate the crimps.
The alternative is to run the cables, cut to lenght, remove and then crimp in a
vice then re-install the wires.
I always worry about doing damage to the gelcoat or flooring. And when the
cables are on a vertical bulkhead it gets real interesting. :-(((
Cheers
Arild
vise is greatly superior to using a hammer. >
REPLY
boat and it
Arild
_Now I have another reason for that small anvil that is stored in the
engine room.It's surprising how often I use it.
CCC____________________________________________
