Latency between multiple daughter boards on one USRP X310
Y
YoungC_Park
Mon, Jul 30, 2018 6:34 AM
Hi all,
I hope someone could help me on my situation. I could not find similar cases on the usrp archive.
I have one USRP X310 that has UBX-160(slot A) , LFTX board(slot B) and GPS module installed.
  • my UHD is 3.11.0
  • Using uhd API based on tx_samples from_file.cpp, I can generate dual output bursts from UBX160 and LFTX with 200MHz master clock and 100Msps on USRP X310.
  • However, the second output (ch 1, red in the picture) is lagged from the first one (ch 0, yellow) by about (~10us with +-4us uncertainty)
  • The baseband burst is a sawtooth waveform of two cycles(2000 samples long). and UBX160 modulates it into fc = 1GHz whereas LFTX generates it as is.
  • This lagging is quite constant (10us) even if I change the sampling rate (10,20,50, 100MSps).
  • Tried 'Unknown PPS', 'gpsdo', 'internal',,, but no difference.
  • When I switch the order of channels to (1,0) as opposed to (0,1), then the ch0 lags behind the ch1, which seems that this is related to some sequenced process…
We are seeking for helps on the cause and cure about this lagging…
Thanks,
Young C. Park
Hi all, I hope someone could help me on my situation. I could not find similar cases on the usrp archive. I have one USRP X310 that has UBX-160(slot A) , LFTX board(slot B) and GPS module installed. - my UHD is 3.11.0 - Using uhd API based on tx_samples from_file.cpp, I can generate dual output bursts from UBX160 and LFTX with 200MHz master clock and 100Msps on USRP X310. - However, the second output (ch 1, red in the picture) is lagged from the first one (ch 0, yellow) by about (~10us with +-4us uncertainty) - The baseband burst is a sawtooth waveform of two cycles(2000 samples long). and UBX160 modulates it into fc = 1GHz whereas LFTX generates it as is. - This lagging is quite constant (10us) even if I change the sampling rate (10,20,50, 100MSps). - Tried 'Unknown PPS', 'gpsdo', 'internal',,, but no difference. - When I switch the order of channels to (1,0) as opposed to (0,1), then the ch0 lags behind the ch1, which seems that this is related to some sequenced process… We are seeking for helps on the cause and cure about this lagging… Thanks, Young C. Park
FS
Fabian Schwartau
Mon, Jul 30, 2018 7:08 AM
Hi Young,
I am not an expert, but I have three suggestions:
  1. Using 'Unknown PSS' or any other sync method should not have no
    affect, as this is for syncing two or more USRPs. You have only one FPGA
    and that is in sync with itself ;)
  2. Did you tried using timed commands? (see function set_command_time())
  3. If that does not work, maybe the FPGA can handly only one command at
    a time - even if you tell him to execute two. Then it may be possible to
    start one command timed before the other and extend that sequence of
    samples with the correct amount of zeros.
Best regards,
Fabian
Am 30.07.2018 um 08:34 schrieb YoungC_Park via USRP-users:
Hi all,
  • my UHD is 3.11.0
    on USRP X310.
    as is.
    sequenced process…
Thanks,
Young C. Park
USRP-users mailing list
USRP-users@lists.ettus.com
Hi Young, I am not an expert, but I have three suggestions: 1) Using 'Unknown PSS' or any other sync method should not have no affect, as this is for syncing two or more USRPs. You have only one FPGA and that is in sync with itself ;) 2) Did you tried using timed commands? (see function set_command_time()) 3) If that does not work, maybe the FPGA can handly only one command at a time - even if you tell him to execute two. Then it may be possible to start one command timed before the other and extend that sequence of samples with the correct amount of zeros. Best regards, Fabian Am 30.07.2018 um 08:34 schrieb YoungC_Park via USRP-users: > Hi all, > > I hope someone could help me on my situation. I could not find similar > cases on the usrp archive. > > I have one USRP X310 that has UBX-160(slot A) , LFTX board(slot B) and > GPS module installed. > > - my UHD is 3.11.0 > > - Using uhd API based on tx_samples from_file.cpp, I can generate dual > output bursts from UBX160 and LFTX with 200MHz master clock and 100Msps > on USRP X310. > > - However, the second output (ch 1, red in the picture) is lagged from > the first one (ch 0, yellow) by about (~10us with +-4us uncertainty) > > - The baseband burst is a sawtooth waveform of two cycles(2000 samples > long). and UBX160 modulates it into fc = 1GHz whereas LFTX generates it > as is. > > - This lagging is quite constant (10us) even if I change the sampling > rate (10,20,50, 100MSps). > > - Tried 'Unknown PPS', 'gpsdo', 'internal',,, but no difference. > > - When I switch the order of channels to (1,0) as opposed to (0,1), then > the ch0 lags behind the ch1, which seems that this is related to some > sequenced process… > > We are seeking for helps on the cause and cure about this lagging… > > Thanks, > > Young C. Park > > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >
DK
Derek Kozel
Mon, Jul 30, 2018 3:45 PM
Hello Fabian and Young,
The suggestion about timed commands is on point, I think that is what is
missing. Using unknown PPS will not hurt as there are two radio blocks with
timekeepers and using the unknown PPS setting, or external or gpsdo if
installed, will ensure that they are aligned.
  1. If that does not work, maybe the FPGA can handly only one command at a
Each radio channel has it's own queue for timed commands so it is possible
to schedule all channels simultaneously.
Derek
On Mon, Jul 30, 2018 at 8:08 AM, Fabian Schwartau via USRP-users <
Hi Young,
  1. Using 'Unknown PSS' or any other sync method should not have no affect,
  3. If that does not work, maybe the FPGA can handly only one command at a
Best regards,
Fabian
Hi all,
  • my UHD is 3.11.0
    USRP X310.
    is.
    sequenced process…
Thanks,
Young C. Park
Hello Fabian and Young, The suggestion about timed commands is on point, I think that is what is missing. Using unknown PPS will not hurt as there are two radio blocks with timekeepers and using the unknown PPS setting, or external or gpsdo if installed, will ensure that they are aligned. > 3) If that does not work, maybe the FPGA can handly only one command at a time - even if you tell him to execute two. Then it may be possible to start one command timed before the other and extend that sequence of samples with the correct amount of zeros. Each radio channel has it's own queue for timed commands so it is possible to schedule all channels simultaneously. Derek On Mon, Jul 30, 2018 at 8:08 AM, Fabian Schwartau via USRP-users < usrp-users@lists.ettus.com> wrote: > Hi Young, > > I am not an expert, but I have three suggestions: > 1) Using 'Unknown PSS' or any other sync method should not have no affect, > as this is for syncing two or more USRPs. You have only one FPGA and that > is in sync with itself ;) > 2) Did you tried using timed commands? (see function set_command_time()) > 3) If that does not work, maybe the FPGA can handly only one command at a > time - even if you tell him to execute two. Then it may be possible to > start one command timed before the other and extend that sequence of > samples with the correct amount of zeros. > > Best regards, > Fabian > > Am 30.07.2018 um 08:34 schrieb YoungC_Park via USRP-users: > >> Hi all, >> >> I hope someone could help me on my situation. I could not find similar >> cases on the usrp archive. >> >> I have one USRP X310 that has UBX-160(slot A) , LFTX board(slot B) and >> GPS module installed. >> >> - my UHD is 3.11.0 >> >> - Using uhd API based on tx_samples from_file.cpp, I can generate dual >> output bursts from UBX160 and LFTX with 200MHz master clock and 100Msps on >> USRP X310. >> >> - However, the second output (ch 1, red in the picture) is lagged from >> the first one (ch 0, yellow) by about (~10us with +-4us uncertainty) >> >> - The baseband burst is a sawtooth waveform of two cycles(2000 samples >> long). and UBX160 modulates it into fc = 1GHz whereas LFTX generates it as >> is. >> >> - This lagging is quite constant (10us) even if I change the sampling >> rate (10,20,50, 100MSps). >> >> - Tried 'Unknown PPS', 'gpsdo', 'internal',,, but no difference. >> >> - When I switch the order of channels to (1,0) as opposed to (0,1), then >> the ch0 lags behind the ch1, which seems that this is related to some >> sequenced process… >> >> We are seeking for helps on the cause and cure about this lagging… >> >> Thanks, >> >> Young C. Park >> >> >> >> _______________________________________________ >> USRP-users mailing list >> USRP-users@lists.ettus.com >> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >> >> > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >
YC
Young C. Park
Tue, Jul 31, 2018 6:58 AM
Fabian and Derek,
Thanks for your comments,
Yesterday I realized that 10GbE could not support my 100MSymps, complex
dual channel output.
That's why I've seen underflow messages. I actually have got around this
underflow by putting (ms) delay between bursts.
However, it seems like that there's something going on even if I dont see
any underflow message after the delay..
So I'd like to know what happens how the buffers are managed especially in
2 channel case..
Q1 : In 2 channel case, does the tx buffer divided into half size ?
Q2 : Do the two tx buffers are filled up simultaneously or one after
another?
Q3 : when underflow happens, does the kernel wait until the 2 channel
buffers are filled up ? or it just starts to output as soon as the first
channel buffer is filled while the second is being filled?
If I got answers about these questions, the delayed output on the dual
channel can be explained more clearly...
Thanks,
Young C. Park
On Tue, Jul 31, 2018 at 12:45 AM, Derek Kozel via USRP-users <
Derek
Hi Young,
Best regards,
Fabian
Hi all,
  • my UHD is 3.11.0
    USRP X310.
    is.
    sequenced process…
Thanks,
Young C. Park
Youngcheol Park
ycpark.gt@gmail.com
Fabian and Derek, Thanks for your comments, Yesterday I realized that 10GbE could not support my 100MSymps, complex dual channel output. That's why I've seen underflow messages. I actually have got around this underflow by putting (ms) delay between bursts. However, it seems like that there's something going on even if I dont see any underflow message after the delay.. So I'd like to know what happens how the buffers are managed especially in 2 channel case.. Q1 : In 2 channel case, does the tx buffer divided into half size ? Q2 : Do the two tx buffers are filled up simultaneously or one after another? Q3 : when underflow happens, does the kernel wait until the 2 channel buffers are filled up ? or it just starts to output as soon as the first channel buffer is filled while the second is being filled? If I got answers about these questions, the delayed output on the dual channel can be explained more clearly... Thanks, Young C. Park On Tue, Jul 31, 2018 at 12:45 AM, Derek Kozel via USRP-users < usrp-users@lists.ettus.com> wrote: > Hello Fabian and Young, > > The suggestion about timed commands is on point, I think that is what is > missing. Using unknown PPS will not hurt as there are two radio blocks with > timekeepers and using the unknown PPS setting, or external or gpsdo if > installed, will ensure that they are aligned. > > > 3) If that does not work, maybe the FPGA can handly only one command at > a time - even if you tell him to execute two. Then it may be possible to > start one command timed before the other and extend that sequence of > samples with the correct amount of zeros. > > Each radio channel has it's own queue for timed commands so it is possible > to schedule all channels simultaneously. > > Derek > > On Mon, Jul 30, 2018 at 8:08 AM, Fabian Schwartau via USRP-users < > usrp-users@lists.ettus.com> wrote: > >> Hi Young, >> >> I am not an expert, but I have three suggestions: >> 1) Using 'Unknown PSS' or any other sync method should not have no >> affect, as this is for syncing two or more USRPs. You have only one FPGA >> and that is in sync with itself ;) >> 2) Did you tried using timed commands? (see function set_command_time()) >> 3) If that does not work, maybe the FPGA can handly only one command at a >> time - even if you tell him to execute two. Then it may be possible to >> start one command timed before the other and extend that sequence of >> samples with the correct amount of zeros. >> >> Best regards, >> Fabian >> >> Am 30.07.2018 um 08:34 schrieb YoungC_Park via USRP-users: >> >>> Hi all, >>> >>> I hope someone could help me on my situation. I could not find similar >>> cases on the usrp archive. >>> >>> I have one USRP X310 that has UBX-160(slot A) , LFTX board(slot B) and >>> GPS module installed. >>> >>> - my UHD is 3.11.0 >>> >>> - Using uhd API based on tx_samples from_file.cpp, I can generate dual >>> output bursts from UBX160 and LFTX with 200MHz master clock and 100Msps on >>> USRP X310. >>> >>> - However, the second output (ch 1, red in the picture) is lagged from >>> the first one (ch 0, yellow) by about (~10us with +-4us uncertainty) >>> >>> - The baseband burst is a sawtooth waveform of two cycles(2000 samples >>> long). and UBX160 modulates it into fc = 1GHz whereas LFTX generates it as >>> is. >>> >>> - This lagging is quite constant (10us) even if I change the sampling >>> rate (10,20,50, 100MSps). >>> >>> - Tried 'Unknown PPS', 'gpsdo', 'internal',,, but no difference. >>> >>> - When I switch the order of channels to (1,0) as opposed to (0,1), then >>> the ch0 lags behind the ch1, which seems that this is related to some >>> sequenced process… >>> >>> We are seeking for helps on the cause and cure about this lagging… >>> >>> Thanks, >>> >>> Young C. Park >>> >>> >>> >>> _______________________________________________ >>> USRP-users mailing list >>> USRP-users@lists.ettus.com >>> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >>> >>> >> _______________________________________________ >> USRP-users mailing list >> USRP-users@lists.ettus.com >> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >> > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com > > -- ------------------------ Youngcheol Park ycpark.gt@gmail.com
