View all threadsHi Jason/folks,
Do you know how to generate an FPGA image from Vivado GUI that includes an OOT block created using rfnocmodtool?
I created an OOT block using rfnocmodtool, run a testbench to verify that it was ok, then generated a bit file with the uhd_image_builder.py script and programmed it onto the USRP successfully: I could see the custom block listed among the RFNoC blocks.
However, when trying to create the same image from Vivado modifying the rfnoc_ce_auto_inst_x300.v file by including my own block and adding the dependent Verilog files to the design, even though I can run the synthesis/implementation and generate a bit file, after loading it to the URSP I can’t see any block.
Do you know whether I have to modify some extra files apart from the rfnoc_ce_auto_inst_x300.v? The purpose behind this is to build images of new OTT blocks using exclusively Vivado GUI.
Best,
Luis
Von: Jason Matusiak jason@gardettoengineering.com
Datum: Freitag, 18. August 2017 um 18:42
An: "Torres Figueroa, Luis Angel" luis.torres.figueroa@rwth-aachen.de, "usrp-users@lists.ettus.com" usrp-users@lists.ettus.com
Betreff: Re: [USRP-users] Building FPGA image
I'm glad you got it working. There are a lot of critical warnings and things of that ilk that scroll by, but as long as you don't get any errors and your project meets timing, I wouldn't worry too much about them.
Happy FPGAing.
On 08/18/2017 09:26 AM, Torres Figueroa, Luis Angel wrote:
Hi Jason,
It worked. I downloaded the source files from rfnoc-devel branch in the repository again and build it without choosing the option you mentioned.
I have still some critical warnings, but the image has been correctly generated and I could use it in the URSP. Also, all the timing constraints were now met. Thanks for the advice!
ImplementationDesign Initialization
[Designutils 20-1280] Could not find module 'fifo_4k_2clk'. The XDC file /home/rfnoc-devel/source/uhd/fpga-src/usrp3/top/x300/build-ip/xc7k410tffg900-2/fifo_4k_2clk/fifo_4k_2clk/fifo_4k_2clk.xdc will not be read for any cell of this module.
[Designutils 20-1280] Could not find module 'axi_hb31'. The XDC file /home/rfnoc-devel/source/uhd/fpga-src/usrp3/top/x300/build-ip/xc7k410tffg900-2/axi_hb31/fir_compiler_v7_2_5/constraints/fir_compiler_v7_2.xdc will not be read for any cell of this module.
[Designutils 20-1280] Could not find module 'fifo_4k_2clk'. The XDC file /home/rfnoc-devel/source/uhd/fpga-src/usrp3/top/x300/build-ip/xc7k410tffg900-2/fifo_4k_2clk/fifo_4k_2clk/fifo_4k_2clk_clocks.xdc will not be read for any cell of this module.
[Common 17-55] 'set_property' expects at least one object. ["/home/rfnoc-devel/source/uhd/fpga-src/usrp3/top/x300/timing.xdc":293]
[Common 17-55] 'set_property' expects at least one object. ["/home/rfnoc-devel/source/uhd/fpga-src/usrp3/top/x300/timing.xdc":294]
[Common 17-55] 'set_property' expects at least one object. ["/home/rfnoc-devel/source/uhd/fpga-src/usrp3/top/x300/timing.xdc":295]
Best,
Luis
Von: Jason Matusiak jason@gardettoengineering.commailto:jason@gardettoengineering.com
Datum: Mittwoch, 16. August 2017 um 17:09
An: "Torres Figueroa, Luis Angel" luis.torres.figueroa@rwth-aachen.demailto:luis.torres.figueroa@rwth-aachen.de, "usrp-users@lists.ettus.com"mailto:usrp-users@lists.ettus.com usrp-users@lists.ettus.commailto:usrp-users@lists.ettus.com
I've done it many times. When you open it and you do a save-as of the project, make sure that you don't check the option box to copy the files over, you want to leave them in their current location.
On 08/16/2017 10:15 AM, Torres Figueroa, Luis Angel via USRP-users wrote:
Hi folks,
Has someone of you loaded the whole usrp_x310_fpga_RFNOC_HG design into Vivado 2015.4 and created the FPGA image using its graphical Interface? I am still unable to do so.
I want to create a standard FPGA image using Vivado GUI.
I have first run the command “make X310_RFNOC_HG GUI=1”, saved the whole RTS design and reopened it as project mode, and then tried to create the bitstream from the GUI itself but it doesn’t work.
I have also tried adding the x300.v file, the constraints and all its dependent files into the design, and then done the synthesis, implementation and generated the bitstream, but when I loaded it onto the USRP I can’t recognize any block using the command uhd_usrp_probe. This is the error I get:
[ERROR] [UHD] Exception caught in safe-call.
in virtual ctrl_iface_impl::~ctrl_iface_impl()
at ~/uhd/host/lib/rfnoc/ctrl_iface.cpp:76
this->peek32(0); -> EnvironmentError: IOError: Block ctrl (CE_04_Port_70) no response packet - AssertionError: bool(buff)
in uint64_t ctrl_iface_impl::wait_for_ack(bool)
at ~/uhd/host/lib/rfnoc/ctrl_iface.cpp:197
Best,
Luis A. Torres
USRP-users mailing list
USRP-users@lists.ettus.commailto:USRP-users@lists.ettus.com
Hello Luis Angel,
The uhd_image_builder was written in order to ease this process. Seeing
that you used it successfully, it makes me wonder: is there a reason that
you mind sharing with us on why do you want to go around the script? I ask
in order to, maybe, identify a need that could added into the script and we
have been overseeing it.
So, you modified the rfnoc_ce_auto_inst_x300.v, which is the way to go.
But, how did you afterwards start the synthesis? This step might be the
reason why you did not see the any blocks. Actually, "not seeing any block"
is certainly something that is not supposed to happen (I would dare to say
that it is something that just won't happen, becaused of the way the
synth/build system works). Maybe you mean that you saw blocks but not the
ones that you expected? If this is the case, which blocks did you see? This
could also indicate what kind of image you synthesized/build.
Another thing: in earlier emails you mentioned that you were using the X310
device. Keep in mind that rfnoc_ce_auto_inst_x300.v and
rfnoc_ce_auto_inst_x310.v are two different files. If you modified the
x300.v version and then built the X310_RFNOC target, that would explain
why you are not seeing your block.
You have to modify the rfnoc_ce_auto_inst_x300.v (or the *_x310 version,
depending on your device) and have all your custom files being accesible by
the build system by adding them to the Makefile.OOT.inc. After that, just
build the target with:
$ make X300_RFNOC_HG
or the X310 version of the target, or the other HLS/XG version. If you only
want to have the FPGA image, you don't need the Vivado GUI. If you need the
Vibado GUI for any other reason, just add "GUI=1" to the make command.
Or you can use the image_builder, or its GUI version, to help you around a
bit on this.
Regards,
Best,
Luis
*Von: *Jason Matusiak jason@gardettoengineering.com
*Datum: *Freitag, 18. August 2017 um 18:42
*An: *"Torres Figueroa, Luis Angel" luis.torres.figueroa@rwth-aachen.de,
*Betreff: *Re: [USRP-users] Building FPGA image
Happy FPGAing.
Hi Jason,
module.
Best,
Luis
*Datum: *Mittwoch, 16. August 2017 um 17:09
Hi folks,
the error I get:
Best,
Luis A. Torres
