John,
The advice from listees has been good: Check top RPMS to see they are in the
2300 RPM range, check with a pro, etc. Perhaps ask a pro to check your
engine..Check with any commercial guys in your area with dry stacks... see what they
say. If your engine does not turn up max rpm, maybe its control linkage
limitations.
8V71's come in various forms from about 310 to 350 HP....with smaller HP
often in commercial or continuous applications. With a natural, 1500 RPM to 1800
RPM regular running (at normal operating temps) will result in an engine life
that will probably exceed yours. Smaller injectors/reduced HP further extend
engine life...at 350HP those engines run 10K even 15K hours if run
frequently....
Three very easy tests to eliminate a lot of problem areas: ("peace of mind")
With engine cold or warm (not hot) remove the radiator cap and insert a
finger to the under side of the top of the heat exchanger....is there black oily
residue?? (not good)
Get an infrared thermometer (see many T&T posts on the subject, Radio shack
has them) and check each cyclinder exhaust into the exhaust manifolds for
temp...under load, normal crusing speed, normal operating temp....If one is colder
than the others, you are likely getting incomplete combustion in that
cylinder....I'd say they should all be within about ten degrees of one another...Takes
only ten minutes once underway with somebody else at the helm..
Listen to the exhaust for a "miss"...mis fire in a cylinder....not always
easy to detect, but a pro will know immediately...
Finally: If your prop is East Asian, it's possible you'll get better prop
performance from a US manufactured prop....I just heard that again yesterday from
a trawler friend...But be sure the engine is running as expected before
fussing with the prop...
Good luck,
Let us know what you determine....
Rob Brueckner
Hatteras Yachtfisherman
yesterday from a trawler friend...
How does the water know? Can it read the "Made in Taiwan" stamping and say
"Yuck, I'm not letting that sucker move efficiently through me."
As long as the prop is properly shaped, what possible difference could
there be that makes a US prop better than a foreign one. This kind of thing
probably gets started by somebody with a dinged up bent prop that
originally came with his offshore trawler replacing it with a nice new
Michigan prop and noticing how much smoother it was and how he gets more
speed for the same rpm.
I'm not a prop expert, other than the fact that I can count the blades, so
maybe somebody on list can shed some light on this.
Jim McCorison
Starfish Marine
(619) 337-5370
http://www.starfish-marine.com
