Hi,
Could any one please tell me whether we can build a SIP client which
supports both audio and video, using the PJSIP sip stack or PJSUA Highlevel
API.
I analyzed a OK packet sent by the PJSUA sample application and that
indicates video port as 0. Does that mean PJSIP sip stack does not support
video?
Please do reply if you are aware of that.
Thank you.
regards,
Hasini.
you need to implement video sending and receiving part. its not implemented
in pjsua. there is few discussions on this forum adding video support using
h323 or vlc codec. you could refer them.
On Tue, Nov 18, 2008 at 4:14 PM, Hasini Gunasinghe hasi7786@gmail.comwrote:
Hi,
API.
video?
Thank you.
regards,
Hasini.
Visit our blog: http://blog.pjsip.org
pjsip mailing list
pjsip@lists.pjsip.org
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Thank you.
I looked in to that and went through the code and tried to identify where
the adding video should be done. It seems complicated. I have implemented
capturing and rendering of video and audio seperately using directshow SDK.
So the midea stream capturing and rendering part of the soft phone I am
developing is ready.
Now what I need is to make the sip negociation done with the relavant
audio/video codecs and then use the ports agreed in the negociation to
assign for the filters of the graph. ( In other words, integrating the SIP
part to the media handling part which I have implemented seperately)
If any one has tried that already or can suggest a way to try that please do
reply.
Thank you.
regards,
Hasini.
Hi,
API.
video?
Thank you.
regards,
Hasini.
pjsip mailing list
pjsip mailing list
