This was published in the 22 May 2020 issue of Science (AAAS journal). For AAAS members, the direct link is:
https://science.sciencemag.org/content/368/6493/889
They make use of a fiber-based OFC (optical frequency comb) and state-of-the-art photodetectors to transfer optical clock stability to a 10 GHz microwave signal. This downconversion from optical to microwave was done with an error of no more than 10-19 (1 x 10 ^-19). The best available optical clock stability is around 10-18 (1 x 10^-18) at a couple of hundred seconds averaging time.
This specific experiment compared two independent Yb (Ytterbium) optical lattice clocks running at about 259 THz. One Yb clock drove a 208 MHz comb generator, while the other Yb clock drove a 156 MHz comb generator. Then:
208 MHz x 48th harmonic = 9.984 GHz
156 MHz x 64th harmonic = 9.984 GHz
The phase between these 9.984 GHz signals was compared in a mixer phase detector. The fractional frequency instability observed was 10-16 (1 x 10^-16) over a 1 second interval. The frequencies I listed above are approximate -- they actually measured a 1.5 MHz beat note between the ~10 GHz signals. This allowed them to achieve a relative timing error of 900 attoseconds (rms).
The optical phase measurements between the two Yb clocks at 259 THz indicated a frequency offset (Yb1 - Yb2) of 0.0000064 Hz, and the microwave ~10 GHz comparison was consistent with that offset (2.5 +/- 0.6) x 10-20 (10^-20).
The abstract is:
Optical atomic clocks are poised to redefine the Système International (SI) second, thanks to stability
and accuracy more than 100 times better than the current microwave atomic clock standard. However,
the best optical clocks have not seen their performance transferred to the electronic domain, where
radar, navigation, communications, and fundamental research rely on less stable microwave sources.
By comparing two independent optical-to-electronic signal generators, we demonstrate a 10-gigahertz
microwave signal with phase that exactly tracks that of the optical clock phase from which it is derived,
yielding an absolute fractional frequency instability of 1 × 10−18 in the electronic domain. Such faithful
reproduction of the optical clock phase expands the opportunities for optical clocks both technologically
and scientifically for time dissemination, navigation, and long-baseline interferometric imaging.
I have a Science subscription and can read this paper, but I can't distribute it here.
You can also see discussion of this achievement by NIST (with assistance by the University of Virginia) at Physics World:
https://physicsworld.com/a/microwave-timing-signals-get-hundredfold-boost-in-stability/
You may need to request a free account at Physics World to read this article.
Bill Byrom N5BB
https://tf.nist.gov/general/pdf/3093.pdf
is likely more accessible than the sciencemag link
Bruce
The abstract is:
Bill Byrom N5BB
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
Bill N5BB
Bruce
The abstract is:
Bill Byrom N5BB
https://tf.nist.gov/general/pdf/2995.pdf
may be also of some interest.
Its about optimising the linearity of high speed photodiodes.
These are used (amongst other applications )as mixers for converting optical combs to microwave signals.
Bruce
On 05 June 2020 at 11:35 Bill Byrom time@radio.sent.com wrote:
Bill N5BB
Bruce
The abstract is:
Bill Byrom N5BB
