Re: [pjsip] also APS issue on S60 on N95
KR
Krishna Radha
Fri, Dec 26, 2008 10:08 AM
Hi Kevin,
that's all fine for me, since karthik is sure about the Publisher ID , so
let us try that also, but needs to spend 200US$ for it. so let's take the
chance and do it .
here is the link of getting the Publisher ID
For gaining restricted capabilities like CommDD , DiskAdmin, NetworkControl,
MultimediaDD, there is a need for publisher ID. Currently, for APS to work
on the handset and the sound to come to the ear piece, we need MultiMediaDD.
The cost of this ID is 200 USD and is valid for a year; the link to this
site is *http://www.trustcenter.de/order/publisherid/dev. *Once you get the
publisher ID, the application can be installed on 100 devices(IMEIs); the
developer certificate can then be requested with the use of publisher ID for
the requested capablities which will allow us to install on 100 devices.
Good Luck  :)
Krishna.
On Fri, Dec 26, 2008 at 3:35 PM, Kevin Gong Kevin.Gong@morodo.org wrote:
Hi Krishna,
      The sample project work well on mobile phone, but I haven't try to
route sound to headset. So I can't give you answer now.
From: Krishna Radha [mailto:symbianvoip.pjsip@gmail.com]
Sent: Friday, December 26, 2008 5:40 PM
To: Kevin Gong
Cc: pjsip list
Subject: Re: [pjsip] also APS issue on S60 on N95
Hi Kevin,
are you able to run succesfullly with the sample project  from Nokia ? is
that working ? are you able to hear the sound on headset not on speaker ?
& second thing is that,  i have done the same changes in PJsip, but no
luck, but in some forums says that, we need a PublisherID and a developer
certificate to make it use of APS, i havent tried getting the Publisher ID,
since it cost 200US$  & i am not sure, after that, will it work or not ?
Regards,
Krishna.
On Fri, Dec 26, 2008 at 2:52 PM, Kevin Gong Kevin.Gong@morodo.org wrote:
Hi Krishna,
      Yes, I have installed the APSserver.sis file , and also, I can run
the sample APSoverRTPExample downloaded from Nokia website, it use APS and
RTP of symbian.
      The steps to use pjsip with aps are easy, just:
      1. build pjsip with #define SND_USE_APS       1 in bld.inf
      2.add symbian_audio_aps.lib and MultimediaDD   to my mmp files,
add others like symbian_ua_gui.mmp
      3.build my application
      I also try to use the project APSoverRTPExample's UID, but also
can't run.
      Another problem I have found that: when application exit, I invoke
pjsua_destroy(), there is a UserPanic E32USER-CBase 46, panic at Active
Object, do you have meet this problem?
      Thanks.
Best Regards
Kevin
Sent: Friday, December 26, 2008 5:06 PM
To: pjsip list
Cc: Kevin Gong
Hi Kevin
i am also facing the same issue since 20 Days, and i had already Logged the
same query more then 10 times, but i donno, why benny is not looking into
this . it looks like a global problem in Pjsip and all of the developers are
strugling on it.
any ways,
let me know, what are all the steps you have followed.
have you installed the APServer.sis file before apps ?
Regards
Kirshna
On Fri, Dec 26, 2008 at 1:51 PM, Kevin Gong Kevin.Gong@morodo.org wrote:
Hi all,
      I also meet the APS problem on N95. When a phone call set up
succeed, the application crash.
      Is there any one has fixed it?
      Many thanks.
Kevin.
Visit our blog: http://blog.pjsip.org
pjsip mailing list
pjsip@lists.pjsip.org
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Hi Kevin, that's all fine for me, since karthik is sure about the Publisher ID , so let us try that also, but needs to spend 200US$ for it. so let's take the chance and do it . here is the link of getting the Publisher ID For gaining restricted capabilities like CommDD , DiskAdmin, NetworkControl, MultimediaDD, there is a need for *publisher ID*. Currently, for APS to work on the handset and the sound to come to the ear piece, we need MultiMediaDD. The cost of this ID is 200 USD and is valid for a year; the link to this site is *http://www.trustcenter.de/order/publisherid/dev. *Once you get the publisher ID, the application can be installed on 100 devices(IMEIs); the developer certificate can then be requested with the use of publisher ID for the requested capablities which will allow us to install on 100 devices. Good Luck :) Krishna. On Fri, Dec 26, 2008 at 3:35 PM, Kevin Gong <Kevin.Gong@morodo.org> wrote: > Hi Krishna, > > > > The sample project work well on mobile phone, but I haven't try to > route sound to headset. So I can't give you answer now. > > > ------------------------------ > > *From:* Krishna Radha [mailto:symbianvoip.pjsip@gmail.com] > *Sent:* Friday, December 26, 2008 5:40 PM > *To:* Kevin Gong > *Cc:* pjsip list > > *Subject:* Re: [pjsip] also APS issue on S60 on N95 > > > > Hi Kevin, > > are you able to run succesfullly with the sample project from Nokia ? is > that working ? are you able to hear the sound on headset not on speaker ? > > > > & second thing is that, i have done the same changes in PJsip, but no > luck, but in some forums says that, we need a PublisherID and a developer > certificate to make it use of APS, i havent tried getting the Publisher ID, > since it cost 200US$ & i am not sure, after that, will it work or not ? > > > > Regards, > > Krishna. > > > > > > On Fri, Dec 26, 2008 at 2:52 PM, Kevin Gong <Kevin.Gong@morodo.org> wrote: > > Hi Krishna, > > > > Yes, I have installed the APSserver.sis file , and also, I can run > the sample APSoverRTPExample downloaded from Nokia website, it use APS and > RTP of symbian. > > > > The steps to use pjsip with aps are easy, just: > > 1. build pjsip with #define SND_USE_APS 1 in bld.inf > > 2.add symbian_audio_aps.lib and MultimediaDD to my mmp files, > add others like symbian_ua_gui.mmp > > 3.build my application > > > > I also try to use the project APSoverRTPExample's UID, but also > can't run. > > > > Another problem I have found that: when application exit, I invoke > pjsua_destroy(), there is a UserPanic E32USER-CBase 46, panic at Active > Object, do you have meet this problem? > > > > Thanks. > > > > Best Regards > > Kevin > > > ------------------------------ > > *From:* Krishna Radha [mailto:symbianvoip.pjsip@gmail.com] > *Sent:* Friday, December 26, 2008 5:06 PM > *To:* pjsip list > *Cc:* Kevin Gong > *Subject:* Re: [pjsip] also APS issue on S60 on N95 > > > > Hi Kevin > > i am also facing the same issue since 20 Days, and i had already Logged the > same query more then 10 times, but i donno, why benny is not looking into > this . it looks like a global problem in Pjsip and all of the developers are > strugling on it. > > > > any ways, > > let me know, what are all the steps you have followed. > > > > have you installed the APServer.sis file before apps ? > > > > > > Regards > Kirshna > > On Fri, Dec 26, 2008 at 1:51 PM, Kevin Gong <Kevin.Gong@morodo.org> wrote: > > Hi all, > > > > I also meet the APS problem on N95. When a phone call set up > succeed, the application crash. > > Is there any one has fixed it? > > Many thanks. > > > > Kevin. > > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > > > > >
MW
Michael Wilson
Fri, Dec 26, 2008 10:32 AM
Hi there,
Just as a side note, if you update the Symbian certificate request
tool, you should be able to add 1,000 devices, rather than 100 which
it was previously limited to (http://developer.sonyericsson.com/site/global/techsupport/symbiansigned/overview/p_overview.jsp
michael
On 26 Dec 2008, at 10:08, Krishna Radha wrote:
Hi Kevin,
NetworkControl, MultimediaDD, there is a need for publisher ID.
and is valid for a year; the link to this site is http://www.trustcenter.de/order/publisherid/dev
. Once you get the publisher ID, the application can be installed on
Good Luck  :)
Krishna.
wrote:
Hi Krishna,
try to route sound to headset. So I can't give you answer now.
To: Kevin Gong
Cc: pjsip list
Hi Kevin,
Nokia ? is that working ? are you able to hear the sound on headset
not on speaker ?
no luck, but in some forums says that, we need a PublisherID and a
developer certificate to make it use of APS, i havent tried getting
the Publisher ID, since it cost 200US$  & i am not sure, after that,
Regards,
Krishna.
wrote:
Hi Krishna,
can run the sample APSoverRTPExample downloaded from Nokia website,
it use APS and RTP of symbian.
files,  add others like symbian_ua_gui.mmp
also can't run.
invoke pjsua_destroy(), there is a UserPanic E32USER-CBase 46, panic
at Active Object, do you have meet this problem?
      Thanks.
Best Regards
Kevin
To: pjsip list
Cc: Kevin Gong
Hi Kevin
Logged the same query more then 10 times, but i donno, why benny is
not looking into this . it looks like a global problem in Pjsip and
all of the developers are strugling on it.
any ways,
Regards
Kirshna
wrote:
Hi all,
up succeed, the application crash.
      Many thanks.
Kevin.
pjsip mailing list
pjsip mailing list
Hi there, Just as a side note, if you update the Symbian certificate request tool, you should be able to add 1,000 devices, rather than 100 which it was previously limited to (http://developer.sonyericsson.com/site/global/techsupport/symbiansigned/overview/p_overview.jsp ). michael On 26 Dec 2008, at 10:08, Krishna Radha wrote: > Hi Kevin, > that's all fine for me, since karthik is sure about the Publisher > ID , so let us try that also, but needs to spend 200US$ for it. so > let's take the chance and do it . > here is the link of getting the Publisher ID > > For gaining restricted capabilities like CommDD , DiskAdmin, > NetworkControl, MultimediaDD, there is a need for publisher ID. > Currently, for APS to work on the handset and the sound to come to > the ear piece, we need MultiMediaDD. The cost of this ID is 200 USD > and is valid for a year; the link to this site is http://www.trustcenter.de/order/publisherid/dev > . Once you get the publisher ID, the application can be installed on > 100 devices(IMEIs); the developer certificate can then be requested > with the use of publisher ID for the requested capablities which > will allow us to install on 100 devices. > > Good Luck :) > Krishna. > > > > On Fri, Dec 26, 2008 at 3:35 PM, Kevin Gong <Kevin.Gong@morodo.org> > wrote: > Hi Krishna, > > > The sample project work well on mobile phone, but I haven't > try to route sound to headset. So I can't give you answer now. > > > From: Krishna Radha [mailto:symbianvoip.pjsip@gmail.com] > Sent: Friday, December 26, 2008 5:40 PM > To: Kevin Gong > Cc: pjsip list > > Subject: Re: [pjsip] also APS issue on S60 on N95 > > > > > Hi Kevin, > > are you able to run succesfullly with the sample project from > Nokia ? is that working ? are you able to hear the sound on headset > not on speaker ? > > > & second thing is that, i have done the same changes in PJsip, but > no luck, but in some forums says that, we need a PublisherID and a > developer certificate to make it use of APS, i havent tried getting > the Publisher ID, since it cost 200US$ & i am not sure, after that, > will it work or not ? > > > Regards, > > Krishna. > > > > > > On Fri, Dec 26, 2008 at 2:52 PM, Kevin Gong <Kevin.Gong@morodo.org> > wrote: > > Hi Krishna, > > > Yes, I have installed the APSserver.sis file , and also, I > can run the sample APSoverRTPExample downloaded from Nokia website, > it use APS and RTP of symbian. > > > The steps to use pjsip with aps are easy, just: > > 1. build pjsip with #define SND_USE_APS 1 in bld.inf > > 2.add symbian_audio_aps.lib and MultimediaDD to my mmp > files, add others like symbian_ua_gui.mmp > > 3.build my application > > > I also try to use the project APSoverRTPExample's UID, but > also can't run. > > > Another problem I have found that: when application exit, I > invoke pjsua_destroy(), there is a UserPanic E32USER-CBase 46, panic > at Active Object, do you have meet this problem? > > > Thanks. > > > Best Regards > > Kevin > > > From: Krishna Radha [mailto:symbianvoip.pjsip@gmail.com] > Sent: Friday, December 26, 2008 5:06 PM > To: pjsip list > Cc: Kevin Gong > Subject: Re: [pjsip] also APS issue on S60 on N95 > > > Hi Kevin > > i am also facing the same issue since 20 Days, and i had already > Logged the same query more then 10 times, but i donno, why benny is > not looking into this . it looks like a global problem in Pjsip and > all of the developers are strugling on it. > > > any ways, > > let me know, what are all the steps you have followed. > > > have you installed the APServer.sis file before apps ? > > > > Regards > Kirshna > > On Fri, Dec 26, 2008 at 1:51 PM, Kevin Gong <Kevin.Gong@morodo.org> > wrote: > > Hi all, > > > I also meet the APS problem on N95. When a phone call set > up succeed, the application crash. > > Is there any one has fixed it? > > Many thanks. > > > Kevin. > > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > > > > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
KR
Krishna Radha
Fri, Dec 26, 2008 10:40 AM
Thanks Michael,
thanks for the update.
Regards,
Krishna.
On Fri, Dec 26, 2008 at 4:02 PM, Michael Wilson
michael.wilson1@gmail.comwrote:
Hi there,
michael
Hi Kevin,
chance and do it .
Good Luck  :)
Krishna.
Hi Krishna,
To: Kevin Gong
Cc: pjsip list
Hi Kevin,
Regards,
Krishna.
wrote:
Hi Krishna,
run the sample APSoverRTPExample downloaded from Nokia website, it use APS
and RTP of symbian.
can't run.
invoke pjsua_destroy(), there is a UserPanic E32USER-CBase 46, panic at
      Thanks.
Best Regards
Kevin
To: pjsip list
Cc: Kevin Gong
Hi Kevin
the same query more then 10 times, but i donno, why benny is not looking
into this . it looks like a global problem in Pjsip and all of the
any ways,
Regards
Kirshna
wrote:
Hi all,
      Many thanks.
Kevin.
pjsip mailing list
Thanks Michael, thanks for the update. Regards, Krishna. On Fri, Dec 26, 2008 at 4:02 PM, Michael Wilson <michael.wilson1@gmail.com>wrote: > > Hi there, > > Just as a side note, if you update the Symbian certificate request tool, > you should be able to add 1,000 devices, rather than 100 which it was > previously limited to ( > http://developer.sonyericsson.com/site/global/techsupport/symbiansigned/overview/p_overview.jsp > ). > > michael > > > > On 26 Dec 2008, at 10:08, Krishna Radha wrote: > > Hi Kevin, > that's all fine for me, since karthik is sure about the Publisher ID , so > let us try that also, but needs to spend 200US$ for it. so let's take the > chance and do it . > here is the link of getting the Publisher ID > > For gaining restricted capabilities like CommDD , DiskAdmin, > NetworkControl, MultimediaDD, there is a need for *publisher ID*. > Currently, for APS to work on the handset and the sound to come to the ear > piece, we need MultiMediaDD. The cost of this ID is 200 USD and is valid for > a year; the link to this site is * > http://www.trustcenter.de/order/publisherid/dev. *Once you get the > publisher ID, the application can be installed on 100 devices(IMEIs); the > developer certificate can then be requested with the use of publisher ID for > the requested capablities which will allow us to install on 100 devices. > > Good Luck :) > Krishna. > > > > On Fri, Dec 26, 2008 at 3:35 PM, Kevin Gong <Kevin.Gong@morodo.org> wrote: > >> Hi Krishna, >> >> >> The sample project work well on mobile phone, but I haven't try >> to route sound to headset. So I can't give you answer now. >> >> ------------------------------ >> >> *From:* Krishna Radha [mailto:symbianvoip.pjsip@gmail.com] >> *Sent:* Friday, December 26, 2008 5:40 PM >> *To:* Kevin Gong >> *Cc:* pjsip list >> >> *Subject:* Re: [pjsip] also APS issue on S60 on N95 >> >> >> >> >> >> Hi Kevin, >> >> are you able to run succesfullly with the sample project from Nokia ? is >> that working ? are you able to hear the sound on headset not on speaker ? >> >> >> & second thing is that, i have done the same changes in PJsip, but no >> luck, but in some forums says that, we need a PublisherID and a developer >> certificate to make it use of APS, i havent tried getting the Publisher ID, >> since it cost 200US$ & i am not sure, after that, will it work or not ? >> >> >> Regards, >> >> Krishna. >> >> >> >> >> >> On Fri, Dec 26, 2008 at 2:52 PM, Kevin Gong <Kevin.Gong@morodo.org> >> wrote: >> >> Hi Krishna, >> >> >> Yes, I have installed the APSserver.sis file , and also, I can >> run the sample APSoverRTPExample downloaded from Nokia website, it use APS >> and RTP of symbian. >> >> >> The steps to use pjsip with aps are easy, just: >> >> 1. build pjsip with #define SND_USE_APS 1 in bld.inf >> >> 2.add symbian_audio_aps.lib and MultimediaDD to my mmp files, >> add others like symbian_ua_gui.mmp >> >> 3.build my application >> >> >> I also try to use the project APSoverRTPExample's UID, but also >> can't run. >> >> >> Another problem I have found that: when application exit, I >> invoke pjsua_destroy(), there is a UserPanic E32USER-CBase 46, panic at >> Active Object, do you have meet this problem? >> >> >> Thanks. >> >> >> Best Regards >> >> Kevin >> >> ------------------------------ >> >> *From:* Krishna Radha [mailto:symbianvoip.pjsip@gmail.com] >> *Sent:* Friday, December 26, 2008 5:06 PM >> *To:* pjsip list >> *Cc:* Kevin Gong >> *Subject:* Re: [pjsip] also APS issue on S60 on N95 >> >> >> Hi Kevin >> >> i am also facing the same issue since 20 Days, and i had already Logged >> the same query more then 10 times, but i donno, why benny is not looking >> into this . it looks like a global problem in Pjsip and all of the >> developers are strugling on it. >> >> >> any ways, >> >> let me know, what are all the steps you have followed. >> >> >> have you installed the APServer.sis file before apps ? >> >> >> >> Regards >> Kirshna >> >> On Fri, Dec 26, 2008 at 1:51 PM, Kevin Gong <Kevin.Gong@morodo.org> >> wrote: >> >> Hi all, >> >> >> I also meet the APS problem on N95. When a phone call set up >> succeed, the application crash. >> >> Is there any one has fixed it? >> >> Many thanks. >> >> >> Kevin. >> >> >> _______________________________________________ >> Visit our blog: http://blog.pjsip.org >> >> pjsip mailing list >> pjsip@lists.pjsip.org >> http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org >> >> >> > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > > > > _______________________________________________ > Visit our blog: http://blog.pjsip.org > > pjsip mailing list > pjsip@lists.pjsip.org > http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org > >
