The FT-243 holders I revamped in the 1950s and 60s did have the aforementioned spring. However a close look at the electrode plates that contacted the quartz resonator had, in every case, a raised boss at each corner that spaced the center of the electrode a few mills above the center of the quartz. So the center part of the quartz was not restrained from moving. And it was not compressed by the spring.
As I recall the stack up was lower electrode, quartz resonator (square in the case of the FT-243) upper electrode, edge seal with hole for the spring, the spring, and then the cover.
I reworked quite a few of these at 8 MHz for use on the 2 meter band by multiplying by 18X. 8 x 18 = 144 MHz. Tooth paste moved them up and a small scratch with a bit of solder moved them down.
Re: optically excite a quartz crystal? (Bob Camp)
As for Bliley - go to the web site and if you look around, you can find a fascinating history of the company. It included details of the invention of the etch process and also of the "rubber rock" technique to vary the frequency of a crystal.
They still make some of the best resonators for custom designed oscillators around. I used them last in a synthesizer design for a FAA customer VHF/UHF receiver only about 6 years ago.
-73 john k6iql
-----Original Message-----
To: time-nuts time-nuts@febo.com
Sent: Mon, Apr 21, 2014 11:00 am
Subject: time-nuts Digest, Vol 117, Issue 80
Send time-nuts mailing list submissions to
time-nuts@febo.com
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
time-nuts-request@febo.com
You can reach the person managing the list at
time-nuts-owner@febo.com
When replying, please edit your Subject line so it is more specific
than "Re: Contents of time-nuts digest..."
Today's Topics:
Message: 1
Date: Mon, 21 Apr 2014 11:24:43 -0400
To: Poul-Henning Kamp phk@phk.freebsd.dk
Cc: Discussion of precise time and frequency measurement
time-nuts@febo.com
Subject: Re: [time-nuts] optically excite a quartz crystal?
Message-ID: 402DEC2B-2405-493A-9866-31CC2CA8896F@rtty.us
Content-Type: text/plain; charset=windows-1252
Hi
As with all ?good stories? there are many versions told by many people. I?ve
heard far to many mutually contradictory versions to have any real idea what?s
true. You are correct that etching was a known process in the 1930?s and that it
had been used by various people at various times. Since it added time (and
complexity) to the process, it got dropped by most people to speed up production
Bob
On Apr 21, 2014, at 10:51 AM, Poul-Henning Kamp phk@phk.freebsd.dk wrote:
In message A5032606-D7D7-4231-B1BD-434670274532@rtty.us, Bob Camp writes:
Early in the WWII era, quartz blanks were not commonly etched after
begin ground / polished to frequency. This left debris on the surface
of the blank. The net result was that the resonators failed after
a period of time in the field, especially under damp conditions.
The problem got so bad that it actually threatened the ability to
communicate in 1942. A fairly high level team looked into the issue
and etching of blanks (and a few other mods) were made a mandatory
part of all crystals suppled to the government.
The story is slightly more interesting than that:
Blileys crystals were almost totally without these problems, but
they wouldn't tell why that might be.
In the end the government put a lot of pressure on Bliley to squeeze
out the manufacturing secret.
The secret was etching.
To keep it secret, Bliley had called it something along the lines
of "X-Grind" and not applied for a patent.
The Government forced Bliley to share the etching secret without
giving any compensation, and the Blileys were bitter about that for
the rest of their lifes.
Poul-Henning Kamp | UNIX since Zilog Zeus 3.20
phk@FreeBSD.ORG | TCP/IP since RFC 956
FreeBSD committer | BSD since 4.3-tahoe
Never attribute to malice what can adequately be explained by incompetence.
Message: 2
Date: Mon, 21 Apr 2014 11:26:16 -0400
To: jfor@quikus.com, Discussion of precise time and frequency
measurement time-nuts@febo.com
Message-ID: 6B374045-7B1F-4706-8B38-609B4366BAE5@rtty.us
Hi
Well I can name at least one post war ham (me at age 14) who did not understand
the need for etch after grinding?
Bob
On Apr 21, 2014, at 11:21 AM, J. Forster jfor@quikus.com wrote:
The etching referred to was by post-war hams,
-John
Hi
Early in the WWII era, quartz blanks were not commonly etched after begin
ground / polished to frequency. This left debris on the surface of the
blank. The net result was that the resonators failed after a period of
time in the field, especially under damp conditions. The problem got so
bad that it actually threatened the ability to communicate in 1942. A
fairly high level team looked into the issue and etching of blanks (and a
few other mods) were made a mandatory part of all crystals suppled to the
government. Ammonium bi-flouride and water was the most common etchant in
that era. There are a number of papers about the whole deal in the FCS,
and many stories told by those who were part of the changes.
Bob
On Apr 21, 2014, at 10:10 AM, J. Forster jfor@quikus.com wrote:
No. There is just a little rectangular quartz wafer. No plating.
In fact, post WWII, when many ham transmitters were 'rock bound' (ie:
crystal conteolled) it was common pratice to regrind mil surplus rystals
to move them into the ham banda.
Apparently, some were also etched using a cleanser called Whink, which
contains a flourine compound.
Also, some advocated applying graphite from a pencil lead was used to
decrease the frequency.
If the crystal ativity was low, they were taken appart and cleaned.
-John
I'm puzzling over this statement. The FT-243's I have seen have a
spring
that squishes the quartz blank between the electrodes. They aren't
plated
onto the quartz, but they are still in intimate mechanical and
electrical
contact.
-Chuck Harris
Bob Camp wrote:
Hi
The WWII era FT-243 is one example of a crystal that has the active
portion of the
electrodes separated from the resonator by an air gap. There are lots
of
similar
holders from that era that do pretty much the same thing.
Non-contacting
electrodes are not very new.
Bob
To unsubscribe, go to
time-nuts@febo.com
End of time-nuts Digest, Vol 117, Issue 80
Hi
Yup, little high spots on the corners of the metal plates. Put the plates in “upside down” and the crystal stopped working ….
If you want to dig into the WWII stuff Virgil Bottom was always happy to talk about his role in saving the world by fixing the crystal process. There are a variety of stories told, some similar to his, some quite different. Yes beer was often involved during the story telling. Who knows what really happened …..
Bob
-73 john k6iql
time-nuts@febo.com
Today's Topics:
Message: 1
time-nuts@febo.com
Hi
Bob
Message: 2
Hi
Bob
-John
Hi
Bob
-John
spring
plated
electrical
contact.
-Chuck Harris
Bob Camp wrote:
Hi
portion of the
of
similar
Non-contacting
Bob
time-nuts@febo.com
