discuss@lists.openscad.org
OpenSCAD general discussion Mailing-list
Cylinder_array (count, distance, rows)
D
Droidene
Sun, Jun 25, 2017 12:36 PM
Hello everyone, im new to this forum and new to OpenSCAD program.
Awsome program.
First, i tried this:
cylinder_array(21,5) cylinder(r=2, h=10);
module cylinder_array( count, distance ){
for ( i = [0:1:count-1] ){
translate([distance*i,0,0])
children();
Then i wanted to copy that row into serveal rows.
I didn't had a clue and i did like this:
translate ([-0,0,0]) cylinder_array(21,5) cylinder(r=2, h=10);
translate ([-0,5,0]) cylinder_array(21,5) cylinder(r=2, h=10);
translate ([-0,10,0]) cylinder_array(21,5) cylinder(r=2, h=10);
translate ([-0,15,0]) cylinder_array(21,5) cylinder(r=2, h=10);
translate ([-0,20,0]) cylinder_array(21,5) cylinder(r=2, h=10);
translate ([-0,25,0]) cylinder_array(21,5) cylinder(r=2, h=10);
translate ([-0,30,0]) cylinder_array(21,5) cylinder(r=2, h=10);
translate ([-0,35,0]) cylinder_array(21,5) cylinder(r=2, h=10);
children();
Cool i was thinking, but knew there a better way of doing this. If im gonna
make serveal of these the code will be long and messy. Not good.
Then i was thinking, hmm how?
I tried this:
cylinder_array(21,5,25) cylinder(r=2, h=10);
module cylinder_array( count, distance, rows ){
for ( h = [0:1:rows-1]){
translate([0,distancei,0])
translate([rows+distance
h,0,0])
children();
Wow, i almost can taste it, much much less code but i dont think this is
enterily correct either.
I see the whole thing moved away from origin: 0,0 .. why?
I know iv done something wrong here.
Anyone out there can help me a little on the road?
View this message in context: http://forum.openscad.org/Cylinder-array-count-distance-rows-tp21740.html
Sent from the OpenSCAD mailing list archive at Nabble.com.
Hello everyone, im new to this forum and new to OpenSCAD program. Awsome program. First, i tried this: cylinder_array(21,5) cylinder(r=2, h=10); module cylinder_array( count, distance ){ for ( i = [0:1:count-1] ){ translate([distance*i,0,0]) children(); } } Then i wanted to copy that row into serveal rows. I didn't had a clue and i did like this: translate ([-0,0,0]) cylinder_array(21,5) cylinder(r=2, h=10); translate ([-0,5,0]) cylinder_array(21,5) cylinder(r=2, h=10); translate ([-0,10,0]) cylinder_array(21,5) cylinder(r=2, h=10); translate ([-0,15,0]) cylinder_array(21,5) cylinder(r=2, h=10); translate ([-0,20,0]) cylinder_array(21,5) cylinder(r=2, h=10); translate ([-0,25,0]) cylinder_array(21,5) cylinder(r=2, h=10); translate ([-0,30,0]) cylinder_array(21,5) cylinder(r=2, h=10); translate ([-0,35,0]) cylinder_array(21,5) cylinder(r=2, h=10); module cylinder_array( count, distance ){ for ( i = [0:1:count-1] ){ translate([distance*i,0,0]) children(); } } Cool i was thinking, but knew there a better way of doing this. If im gonna make serveal of these the code will be long and messy. Not good. Then i was thinking, hmm how? I tried this: cylinder_array(21,5,25) cylinder(r=2, h=10); module cylinder_array( count, distance, rows ){ for ( i = [0:1:count-1] ){ for ( h = [0:1:rows-1]){ translate([0,distance*i,0]) translate([rows+distance*h,0,0]) children(); } } } Wow, i almost can taste it, much much less code but i dont think this is enterily correct either. I see the whole thing moved away from origin: 0,0 .. why? I know iv done something wrong here. Anyone out there can help me a little on the road? -- View this message in context: http://forum.openscad.org/Cylinder-array-count-distance-rows-tp21740.html Sent from the OpenSCAD mailing list archive at Nabble.com.
NH
nop head
Sun, Jun 25, 2017 12:48 PM
It is translated from the origin because you added rows to distance * h.
Here is a corrected version with even less code:
for (i = [0 : count - 1], h = [0 : rows-1])
translate([distance * h, distance * i, 0])
children();
Awsome program.
children();
children();
I tried this:
h,0,0])
children();
Discuss@lists.openscad.org
http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
It is translated from the origin because you added rows to distance * h. Here is a corrected version with even less code: cylinder_array(21,5,25) cylinder(r=2, h=10); module cylinder_array( count, distance, rows ) for (i = [0 : count - 1], h = [0 : rows-1]) translate([distance * h, distance * i, 0]) children(); On 25 June 2017 at 13:36, Droidene <koford@gmail.com> wrote: > Hello everyone, im new to this forum and new to OpenSCAD program. > Awsome program. > > First, i tried this: > > cylinder_array(21,5) cylinder(r=2, h=10); > > module cylinder_array( count, distance ){ > for ( i = [0:1:count-1] ){ > translate([distance*i,0,0]) > children(); > } > } > > Then i wanted to copy that row into serveal rows. > I didn't had a clue and i did like this: > > translate ([-0,0,0]) cylinder_array(21,5) cylinder(r=2, h=10); > translate ([-0,5,0]) cylinder_array(21,5) cylinder(r=2, h=10); > translate ([-0,10,0]) cylinder_array(21,5) cylinder(r=2, h=10); > translate ([-0,15,0]) cylinder_array(21,5) cylinder(r=2, h=10); > translate ([-0,20,0]) cylinder_array(21,5) cylinder(r=2, h=10); > translate ([-0,25,0]) cylinder_array(21,5) cylinder(r=2, h=10); > translate ([-0,30,0]) cylinder_array(21,5) cylinder(r=2, h=10); > translate ([-0,35,0]) cylinder_array(21,5) cylinder(r=2, h=10); > > module cylinder_array( count, distance ){ > for ( i = [0:1:count-1] ){ > translate([distance*i,0,0]) > children(); > } > } > > Cool i was thinking, but knew there a better way of doing this. If im gonna > make serveal of these the code will be long and messy. Not good. > > Then i was thinking, hmm how? > I tried this: > > cylinder_array(21,5,25) cylinder(r=2, h=10); > > module cylinder_array( count, distance, rows ){ > for ( i = [0:1:count-1] ){ > for ( h = [0:1:rows-1]){ > translate([0,distance*i,0]) > translate([rows+distance*h,0,0]) > children(); > } > } > } > > Wow, i almost can taste it, much much less code but i dont think this is > enterily correct either. > I see the whole thing moved away from origin: 0,0 .. why? > I know iv done something wrong here. > > Anyone out there can help me a little on the road? > > > > -- > View this message in context: http://forum.openscad.org/ > Cylinder-array-count-distance-rows-tp21740.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
D
Droidene
Sun, Jun 25, 2017 1:16 PM
Ahh of course, thank you.
It make all sense, awsome.
View this message in context: http://forum.openscad.org/Cylinder-array-count-distance-rows-tp21740p21742.html
Ahh of course, thank you. It make all sense, awsome. -- View this message in context: http://forum.openscad.org/Cylinder-array-count-distance-rows-tp21740p21742.html Sent from the OpenSCAD mailing list archive at Nabble.com.
