One meaning is simply: "take every nth sample and discard the others without
regard to possible aliasing".
The other meaning is: "take every nth sample, but first prefilter as
appropriate to (sensibly) eliminate aliasing".
Which is it?
Unless you are doing something tricky, it doesn't make sense to decimate
without the filter.
I'll phrase your two cases differently. The first is a box that just takes
every Nth sample. Some other box did the filtering. The second box includes
the filter because that is such a common case. The "box" can be software or
hardware.
Sometimes the aliasing is a feature. If you start with a 100 MHz signal, run
it through a band pass filter, now you can decimate and your signal will get
aliased down into baseband. But that's not aliasing bad stuff on top of your
signal. It's aliasing your signal on top of emptyness.
These are my opinions. I hate spam.
Hi
If you take a look at how ADEV has been traditionally done for many
decades, they do indeed “decimate without the filter”. There is no
re-filtering process as you go from 1 to 2 to 10,000 second tau.
Bob
On Feb 25, 2020, at 10:33 AM, Hal Murray via time-nuts time-nuts@lists.febo.com wrote:
Which is it?
without the filter.
hardware.
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
