Support with setting usrp sampling rate to 150MSPS
SK
Snehasish Kar
Tue, Aug 22, 2017 3:15 PM
Hello
I am trying to receive gsm 1800 band using NI USRP 2954R, but when I am trying to set the sampling rate of uhd_source in gnuradio to 150 MSPS, it's giving an error message saying hardware does not support sampling rate above 100MSPS.
Please help!
BR
Snehasish
Hello I am trying to receive gsm 1800 band using NI USRP 2954R, but when I am trying to set the sampling rate of uhd_source in gnuradio to 150 MSPS, it's giving an error message saying hardware does not support sampling rate above 100MSPS. Please help! BR Snehasish
DK
Derek Kozel
Tue, Aug 22, 2017 3:20 PM
Try 200MS/s. The FPGA can only decimate integer amounts from the ADC rate,
which is 200MS/s.
On Tue, Aug 22, 2017 at 5:15 PM, Snehasish Kar via USRP-users <
Hello
above 100MSPS.
Please help!
BR
Snehasish
USRP-users mailing list
USRP-users@lists.ettus.com
Try 200MS/s. The FPGA can only decimate integer amounts from the ADC rate, which is 200MS/s. On Tue, Aug 22, 2017 at 5:15 PM, Snehasish Kar via USRP-users < usrp-users@lists.ettus.com> wrote: > Hello > I am trying to receive gsm 1800 band using NI USRP 2954R, but when I am > trying to set the sampling rate of uhd_source in gnuradio to 150 MSPS, it's > giving an error message saying hardware does not support sampling rate > above 100MSPS. > > Please help! > > BR > Snehasish > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com >
SK
Snehasish Kar
Tue, Aug 22, 2017 3:44 PM
Ok I will try that.
BR
Snehasish
On 22-Aug-2017, at 8:51 PM, Derek Kozel <derek.kozel@ettus.commailto:derek.kozel@ettus.com> wrote:
On Tue, Aug 22, 2017 at 5:15 PM, Snehasish Kar via USRP-users <usrp-users@lists.ettus.commailto:usrp-users@lists.ettus.com> wrote:
Hello
Please help!
BR
Snehasish
USRP-users@lists.ettus.commailto:USRP-users@lists.ettus.com
Ok I will try that. BR Snehasish On 22-Aug-2017, at 8:51 PM, Derek Kozel <derek.kozel@ettus.com<mailto:derek.kozel@ettus.com>> wrote: Try 200MS/s. The FPGA can only decimate integer amounts from the ADC rate, which is 200MS/s. On Tue, Aug 22, 2017 at 5:15 PM, Snehasish Kar via USRP-users <usrp-users@lists.ettus.com<mailto:usrp-users@lists.ettus.com>> wrote: Hello I am trying to receive gsm 1800 band using NI USRP 2954R, but when I am trying to set the sampling rate of uhd_source in gnuradio to 150 MSPS, it's giving an error message saying hardware does not support sampling rate above 100MSPS. Please help! BR Snehasish _______________________________________________ USRP-users mailing list USRP-users@lists.ettus.com<mailto:USRP-users@lists.ettus.com> http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
