trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Wheel hard to turn
E
Ed
Fri, May 28, 2010 10:45 AM
I have an Edson steering system on my S@!lboat. I went to an Edson
presentation last winter at a boat show. The Edson tech guy said the
cable sheath should be replaced every 7 years. Mine is likely original
from 1985. It is stiff in the same way the OP has described. I can
move the rudder by hand when disconnected but with cables connected, I
cannot budge it.
The cable sheaths have zerks mid way so I've been pumping in grease
with no appreciable change. I may try squirting light oil at the top
of the sheath. I have not looked into the top of the pedestal yet
where the gear & sprocket are located. Lots to disassemble.
Thanks for the ideas...
I have an Edson steering system on my S@!lboat. I went to an Edson presentation last winter at a boat show. The Edson tech guy said the cable sheath should be replaced every 7 years. Mine is likely original from 1985. It is stiff in the same way the OP has described. I can move the rudder by hand when disconnected but with cables connected, I cannot budge it. The cable sheaths have zerks mid way so I've been pumping in grease with no appreciable change. I may try squirting light oil at the top of the sheath. I have not looked into the top of the pedestal yet where the gear & sprocket are located. Lots to disassemble. Thanks for the ideas...
