Re: [pjsip] Latency tweaks for Windows Mobile 6 (Jerry Monteiro)
JL
Johan Lantz
Mon, Jan 11, 2010 8:54 AM
Hi Jerry
I have only done measurments with ptime 80 and 100 and these are ok.
One thing that caused me a lot of problems was that some of my phones was not able to produce frames fast enough when
PJMEDIA_SND_DEFAULT_REC_LATENCY
was 100 i.e. the old setting. I think Benny changed this to a higher value later on but I still have 200 on some old devices like HTC 3600 while more powerful devices like Motorola Symbol can handle 100.
I have never played with the
PJMEDIA_CODEC_MAX_SILENCE_PERIOD
/Johan
Jerry wrote:
Hi all
I am hoping someone could advise some of the optimal settings you have found
to work well for windows mobile 6 and above.
Reading through the mailing lists, I have found some people that have used
the settings below, but would like if you could post the Values you have
used and perhaps other settings apart from the ones below.
#define PJMEDIA_SND_DEFAULT_REC_LATENCY  = ?
#define PJMEDIA_SND_DEFAULT_PLAY_LATENCY = ?
PJMEDIA_CODEC_MAX_SILENCE_PERIOD = ?
frame ptime = ?
Hi Jerry I have only done measurments with ptime 80 and 100 and these are ok. One thing that caused me a lot of problems was that some of my phones was not able to produce frames fast enough when PJMEDIA_SND_DEFAULT_REC_LATENCY was 100 i.e. the old setting. I think Benny changed this to a higher value later on but I still have 200 on some old devices like HTC 3600 while more powerful devices like Motorola Symbol can handle 100. I have never played with the PJMEDIA_CODEC_MAX_SILENCE_PERIOD /Johan Jerry wrote: Hi all I am hoping someone could advise some of the optimal settings you have found to work well for windows mobile 6 and above. Reading through the mailing lists, I have found some people that have used the settings below, but would like if you could post the Values you have used and perhaps other settings apart from the ones below. #define PJMEDIA_SND_DEFAULT_REC_LATENCY = ? #define PJMEDIA_SND_DEFAULT_PLAY_LATENCY = ? PJMEDIA_CODEC_MAX_SILENCE_PERIOD = ? frame ptime = ?
BP
Benny Prijono
Mon, Jan 11, 2010 4:22 PM
Thanks for the info, Johan.
Actually I changed PJMEDIA_SND_DEFAULT_PLAY_LATENCY (i.e. not REC)
from 100ms to 160ms for WM and to 140 on Win32, on release 1.5 (see
ticket #983).
Cheers
Benny
On Mon, Jan 11, 2010 at 8:54 AM, Johan Lantz johan.lantz@genaker.net wrote:
Hi Jerry
/Johan
Thanks for the info, Johan. Actually I changed PJMEDIA_SND_DEFAULT_PLAY_LATENCY (i.e. not REC) from 100ms to 160ms for WM and to 140 on Win32, on release 1.5 (see ticket #983). Cheers Benny On Mon, Jan 11, 2010 at 8:54 AM, Johan Lantz <johan.lantz@genaker.net> wrote: > Hi Jerry > > I have only done measurments with ptime 80 and 100 and these are ok. > > One thing that caused me a lot of problems was that some of my phones was > not able to produce frames fast enough when PJMEDIA_SND_DEFAULT_REC_LATENCY > was 100 i.e. the old setting. I think Benny changed this to a higher value > later on but I still have 200 on some old devices like HTC 3600 while more > powerful devices like Motorola Symbol can handle 100. > > I have never played with the PJMEDIA_CODEC_MAX_SILENCE_PERIOD > > > /Johan >
