trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
Re: T&T: Tank monitoring system
LL
Lee Licata
Fri, Sep 30, 2005 11:16 AM
To the list,
Sorry for the delay but I just got to this.
I had this system on my last boat.
Nothing but problems starting year 3. Electrical problems and tank
level indicating problems. Erratic, no indication, full when known to
be empty, etc.
I found the wires to be too small to splice and too hard to rewire. My
electrical / electronic repair service had some experience and said it
would cost me too much to repair, but that replacement was cheaper, and
easier.
Fireboy was willing to sell me a new system at a discount, but that was
all. (Only 1 year warranty, as I remember!)
in discussions with the manufacturer, his staff had told me they had
many complaints and that as a result, they had a new system of a
regular pickup tube with a nema gauge. The key difference was that they
had plumbed a water wash-down for the pickup tube with the SUGGESTION
that it be used once per month whether you were having problems or not.
Installation was a snap, relatively speaking, and did the required
wash-down as suggested.
System worked without fail for the next 3+ years, and the admiral
regained confidence that we could use the tank to about 3/4 full before
having to look for a pump out station.
Of course, YMMV.
Lee
Date: Mon, 19 Sep 2005 01:08:46 -0400
Subject: Re: T&T: Tank monitoring system
To: trawlers-and-trawlering@lists.samurai.com
Message-ID: 004d01c5bcd8$37b45490$6701a8c0@mea78123ef6ea0
Content-Type: text/plain; charset="us-ascii"
Fireboy Xintex LM-2 (I believe) makes quantity gauges for water fuel and
holding tank systems. I got the two-system gauge ( potable water and
holding
tank) and installed first the water system. Very easy. Works like a
charm. In
tank rod with no moving parts. Holding tank was a little more of a
challenge.
I have, like you, a fiberglass tank with very rough sides so snake
River was
out of the question. There was a funny system in there before, made by a
company no longer in existance. The rods were attached to a 3 1/2 " PVC
plug.
I removed the rods from the plug and drilled a hole the size of the
Xintex
flanged sender. Put everything back together and connected the 2 wires.
Works
like a charm. A little pricey, but it's for a boat!!! Go to their
website.
Call them. They are very easy to talk to. And they are helpful and
patient.
No connections, just a happy customer.
P.S. Looking forward to seeing a lot of listees at the Solomons
Trawlerfest.
We will have a get-together there. It is in the works. We are missing
the
super organizer Dennis Bruckel and Esther to do this tradition!
To the list, Sorry for the delay but I just got to this. I had this system on my last boat. Nothing but problems starting year 3. Electrical problems and tank level indicating problems. Erratic, no indication, full when known to be empty, etc. I found the wires to be too small to splice and too hard to rewire. My electrical / electronic repair service had some experience and said it would cost me too much to repair, but that replacement was cheaper, and easier. Fireboy was willing to sell me a new system at a discount, but that was all. (Only 1 year warranty, as I remember!) in discussions with the manufacturer, his staff had told me they had many complaints and that as a result, they had a new system of a regular pickup tube with a nema gauge. The key difference was that they had plumbed a water wash-down for the pickup tube with the SUGGESTION that it be used once per month whether you were having problems or not. Installation was a snap, relatively speaking, and did the required wash-down as suggested. System worked without fail for the next 3+ years, and the admiral regained confidence that we could use the tank to about 3/4 full before having to look for a pump out station. Of course, YMMV. Lee Date: Mon, 19 Sep 2005 01:08:46 -0400 From: "hans" <danskviking@comcast.net> Subject: Re: T&T: Tank monitoring system To: <trawlers-and-trawlering@lists.samurai.com> Message-ID: <004d01c5bcd8$37b45490$6701a8c0@mea78123ef6ea0> Content-Type: text/plain; charset="us-ascii" Fireboy Xintex LM-2 (I believe) makes quantity gauges for water fuel and holding tank systems. I got the two-system gauge ( potable water and holding tank) and installed first the water system. Very easy. Works like a charm. In tank rod with no moving parts. Holding tank was a little more of a challenge. I have, like you, a fiberglass tank with very rough sides so snake River was out of the question. There was a funny system in there before, made by a company no longer in existance. The rods were attached to a 3 1/2 " PVC plug. I removed the rods from the plug and drilled a hole the size of the Xintex flanged sender. Put everything back together and connected the 2 wires. Works like a charm. A little pricey, but it's for a boat!!! Go to their website. Call them. They are very easy to talk to. And they are helpful and patient. No connections, just a happy customer. P.S. Looking forward to seeing a lot of listees at the Solomons Trawlerfest. We will have a get-together there. It is in the works. We are missing the super organizer Dennis Bruckel and Esther to do this tradition!
