time-nuts@lists.febo.com
Maintaining boatanchors (was Capacitor Failures)
MS
Mark Sims
Sat, Oct 23, 2010 3:19 PM
I make backup images of all my EPROMs and even bipolar devices.  I even built a device for reverse engineering secured PALs.  I have a fully configured Data I/O Unisite for programming.  This machine with all the device adapters, etc cost somebody well over $100,000
The Unisite is probably the most capable, robust, and expensive programmer ever built (and quite a boat anchor, itself).  It's a real shame they stopped adding new devices last year.  The 2900 and 3900's are smaller but don't do a few parts (mostly odd bipolar proms).  External interface is a standard RS232 terminal.  They do boot off of floppies (720kbfor the Unisite, 1.44Mb for the others).  There are also units with internal hard drives.  The floppy images can be burned from a CD  (all my computers still have floppy drives,  some 5 1/4",  one has 8 inch).  The last software release spans 9 diskettes.
I have accumulated a few spare machines when I bought some units just to get some oddball package adapter that I did not have.  Email me if interested...
I make backup images of all my EPROMs and even bipolar devices.  I even built a device for reverse engineering secured PALs.  I have a fully configured Data I/O Unisite for programming.  This machine with all the device adapters, etc cost somebody well over $100,000 The Unisite is probably the most capable, robust, and expensive programmer ever built (and quite a boat anchor, itself).  It's a real shame they stopped adding new devices last year.  The 2900 and 3900's are smaller but don't do a few parts (mostly odd bipolar proms).  External interface is a standard RS232 terminal.  They do boot off of floppies (720kbfor the Unisite, 1.44Mb for the others).  There are also units with internal hard drives.  The floppy images can be burned from a CD  (all my computers still have floppy drives,  some 5 1/4",  one has 8 inch).  The last software release spans 9 diskettes. I have accumulated a few spare machines when I bought some units just to get some oddball package adapter that I did not have.  Email me if interested...
Z
Ziggy
Sat, Oct 23, 2010 7:05 PM
I don't know if embedded images will make it through to the list, but
can someone explain the behavior indicated in this graph? This is from
an auction and it doesn't look at all like other graphs that I've seen.
It's only for a 12 min span, but others with a short span aren't similar.
If the included graph doesn't make it to the list, please take a look at
the auction (150508234942). I'd like to understand more of what I am am
seeing there.
Thanks!
Ziggy
Please wait
Image not available
I don't know if embedded images will make it through to the list, but can someone explain the behavior indicated in this graph? This is from an auction and it doesn't look at all like other graphs that I've seen. It's only for a 12 min span, but others with a short span aren't similar. If the included graph doesn't make it to the list, please take a look at the auction (150508234942). I'd like to understand more of what I am am seeing there. Thanks! Ziggy Please wait Image not available
MD
Magnus Danielson
Sat, Oct 23, 2010 7:28 PM
Hi Ziggy,
seeing there.
I assume you refer to the yellow curve...
Isn't that the average from the temp-sensor, being the modern
coarse-stepped variant as things heats up it looks like the
step-response of a one pole low-pass filter.
Cheers,
Magnus
Hi Ziggy, On 10/23/2010 09:05 PM, Ziggy wrote: > I don't know if embedded images will make it through to the list, but > can someone explain the behavior indicated in this graph? This is from > an auction and it doesn't look at all like other graphs that I've seen. > It's only for a 12 min span, but others with a short span aren't similar. > > If the included graph doesn't make it to the list, please take a look at > the auction (150508234942). I'd like to understand more of what I am am > seeing there. I assume you refer to the yellow curve... Isn't that the average from the temp-sensor, being the modern coarse-stepped variant as things heats up it looks like the step-response of a one pole low-pass filter. Cheers, Magnus
BC
Bob Camp
Sat, Oct 23, 2010 7:31 PM
Hi
If you look at the fine print on the yellow graph, it's running right at the limit of the "bad" temp sensor. What you are seeing is normal stepping / averaging on the low resolution sensor.
Bob
On Oct 23, 2010, at 3:28 PM, Magnus Danielson wrote:
Hi Ziggy,
seeing there.
Cheers,
Magnus
Hi If you look at the fine print on the yellow graph, it's running right at the limit of the "bad" temp sensor. What you are seeing is normal stepping / averaging on the low resolution sensor. Bob On Oct 23, 2010, at 3:28 PM, Magnus Danielson wrote: > Hi Ziggy, > > On 10/23/2010 09:05 PM, Ziggy wrote: >> I don't know if embedded images will make it through to the list, but >> can someone explain the behavior indicated in this graph? This is from >> an auction and it doesn't look at all like other graphs that I've seen. >> It's only for a 12 min span, but others with a short span aren't similar. >> >> If the included graph doesn't make it to the list, please take a look at >> the auction (150508234942). I'd like to understand more of what I am am >> seeing there. > > I assume you refer to the yellow curve... > > Isn't that the average from the temp-sensor, being the modern coarse-stepped variant as things heats up it looks like the step-response of a one pole low-pass filter. > > Cheers, > Magnus > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
H
Heathkid
Sat, Oct 23, 2010 8:30 PM
Backup images are fine... but has anyone considered or tried to contact the
original programmers to get the actual code used?  I'm sure there wouldn't
be any reason someone would still consider 30+ year old code a "trade
secret" and if one had the original code... could reasonably replicate an
old programmed chip with a newer one.  Just a thought.
----- Original Message -----
To: time-nuts@febo.com
Sent: Saturday, October 23, 2010 11:19 AM
Subject: [time-nuts] Maintaining boatanchors (was Capacitor Failures)
Backup images are fine... but has anyone considered or tried to contact the original programmers to get the actual code used? I'm sure there wouldn't be any reason someone would still consider 30+ year old code a "trade secret" and if one had the original code... could reasonably replicate an old programmed chip with a newer one. Just a thought. ----- Original Message ----- From: "Mark Sims" <holrum@hotmail.com> To: <time-nuts@febo.com> Sent: Saturday, October 23, 2010 11:19 AM Subject: [time-nuts] Maintaining boatanchors (was Capacitor Failures) I make backup images of all my EPROMs and even bipolar devices. I even built a device for reverse engineering secured PALs. I have a fully configured Data I/O Unisite for programming. This machine with all the device adapters, etc cost somebody well over $100,000 The Unisite is probably the most capable, robust, and expensive programmer ever built (and quite a boat anchor, itself). It's a real shame they stopped adding new devices last year. The 2900 and 3900's are smaller but don't do a few parts (mostly odd bipolar proms). External interface is a standard RS232 terminal. They do boot off of floppies (720kbfor the Unisite, 1.44Mb for the others). There are also units with internal hard drives. The floppy images can be burned from a CD (all my computers still have floppy drives, some 5 1/4", one has 8 inch). The last software release spans 9 diskettes. I have accumulated a few spare machines when I bought some units just to get some oddball package adapter that I did not have. Email me if interested... _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
BC
Bob Camp
Sat, Oct 23, 2010 8:58 PM
Hi
I've been down that road a couple of times. You get to a point where everyone involved does indeed agree that "it's not a secret" anymore. Going the final step and actually getting permission to hand out the code is often impossible. You get into a "nobody has the authority to approve that" hassle.
Bob
----- Original Message ----- From: "Mark Sims" holrum@hotmail.com
Hi I've been down that road a couple of times. You get to a point where everyone involved does indeed agree that "it's not a secret" anymore. Going the final step and actually getting permission to hand out the code is often impossible. You get into a "nobody has the authority to approve that" hassle. Bob On Oct 23, 2010, at 4:30 PM, Heathkid wrote: > Backup images are fine... but has anyone considered or tried to contact the original programmers to get the actual code used? I'm sure there wouldn't be any reason someone would still consider 30+ year old code a "trade secret" and if one had the original code... could reasonably replicate an old programmed chip with a newer one. Just a thought. > > ----- Original Message ----- From: "Mark Sims" <holrum@hotmail.com> > To: <time-nuts@febo.com> > Sent: Saturday, October 23, 2010 11:19 AM > Subject: [time-nuts] Maintaining boatanchors (was Capacitor Failures) > > > > I make backup images of all my EPROMs and even bipolar devices. I even built a device for reverse engineering secured PALs. I have a fully configured Data I/O Unisite for programming. This machine with all the device adapters, etc cost somebody well over $100,000 > > The Unisite is probably the most capable, robust, and expensive programmer ever built (and quite a boat anchor, itself). It's a real shame they stopped adding new devices last year. The 2900 and 3900's are smaller but don't do a few parts (mostly odd bipolar proms). External interface is a standard RS232 terminal. They do boot off of floppies (720kbfor the Unisite, 1.44Mb for the others). There are also units with internal hard drives. The floppy images can be burned from a CD (all my computers still have floppy drives, some 5 1/4", one has 8 inch). The last software release spans 9 diskettes. > > I have accumulated a few spare machines when I bought some units just to get some oddball package adapter that I did not have. Email me if interested... > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
CP
Charles P. Steinmetz
Sat, Oct 23, 2010 9:29 PM
Approve it?  I bet most manufacturers can't even FIND the code for
equipment designed more than 25 years ago.  Note that HP has had to
rely on the kindness of strangers for copies of its older manuals.
Best regards,
Charles
Bob wrote: >I've been down that road a couple of times. You get to a point where >everyone involved does indeed agree that "it's not a secret" >anymore. Going the final step and actually getting permission to >hand out the code is often impossible. You get into a "nobody has >the authority to approve that" hassle. Approve it? I bet most manufacturers can't even FIND the code for equipment designed more than 25 years ago. Note that HP has had to rely on the kindness of strangers for copies of its older manuals. Best regards, Charles
J
jimlux
Sat, Oct 23, 2010 9:32 PM
more likely, nobody still working there knows what the original code is,
and they threw it away 10 years ago.
I work in the spacecraft electronics business, and we're positively
compulsive about documentation, but there's plenty of stuff that just
gets lost.  "Oh yeah, we were cleaning out Dave's office after he died,
and we just pitched all those printouts and databooks with the notes on
the pages. Everything is online now, right?"
Or, it's somewhere in the archives, in one of several hundred boxes
labeled "miscellaneous documentation from 1981-1985" and it would cost
literally hundreds of dollars to retrieve the boxes and have someone
hunt through it for something that might or might not be there.
Or, in a cost cutting thing "We have all these boxes of stuff from 1980
that we're paying for storage on.  Do you have a charge number for the
storage fees?  No? Ok, into the trash it goes"
Heathkid wrote: > Backup images are fine... but has anyone considered or tried to contact > the original programmers to get the actual code used? I'm sure there > wouldn't be any reason someone would still consider 30+ year old code a > "trade secret" and if one had the original code... could reasonably > replicate an old programmed chip with a newer one. Just a thought. > > more likely, nobody still working there knows what the original code is, and they threw it away 10 years ago. I work in the spacecraft electronics business, and we're positively compulsive about documentation, but there's plenty of stuff that just gets lost. "Oh yeah, we were cleaning out Dave's office after he died, and we just pitched all those printouts and databooks with the notes on the pages. Everything is online now, right?" Or, it's somewhere in the archives, in one of several hundred boxes labeled "miscellaneous documentation from 1981-1985" and it would cost literally hundreds of dollars to retrieve the boxes and have someone hunt through it for something that might or might not be there. Or, in a cost cutting thing "We have all these boxes of stuff from 1980 that we're paying for storage on. Do you have a charge number for the storage fees? No? Ok, into the trash it goes"
JF
J. Forster
Sat, Oct 23, 2010 9:44 PM
Very true, except it's more like 5-10 years.
-John
Best regards,
Charles
Very true, except it's more like 5-10 years. -John ============== > Bob wrote: > >>I've been down that road a couple of times. You get to a point where >>everyone involved does indeed agree that "it's not a secret" >>anymore. Going the final step and actually getting permission to >>hand out the code is often impossible. You get into a "nobody has >>the authority to approve that" hassle. > > Approve it? I bet most manufacturers can't even FIND the code for > equipment designed more than 25 years ago. Note that HP has had to > rely on the kindness of strangers for copies of its older manuals. > > Best regards, > > Charles > > > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > >
JF
J. Forster
Sat, Oct 23, 2010 9:47 PM
True.
I've been in warehouses with hundreds of rows of shelves of Bankers Boxes
filled with records. I doubt the stuff is even indexed.
-John
True. I've been in warehouses with hundreds of rows of shelves of Bankers Boxes filled with records. I doubt the stuff is even indexed. -John ============== > Heathkid wrote: >> Backup images are fine... but has anyone considered or tried to contact >> the original programmers to get the actual code used? I'm sure there >> wouldn't be any reason someone would still consider 30+ year old code a >> "trade secret" and if one had the original code... could reasonably >> replicate an old programmed chip with a newer one. Just a thought. >> >> > more likely, nobody still working there knows what the original code is, > and they threw it away 10 years ago. > > I work in the spacecraft electronics business, and we're positively > compulsive about documentation, but there's plenty of stuff that just > gets lost. "Oh yeah, we were cleaning out Dave's office after he died, > and we just pitched all those printouts and databooks with the notes on > the pages. Everything is online now, right?" > > Or, it's somewhere in the archives, in one of several hundred boxes > labeled "miscellaneous documentation from 1981-1985" and it would cost > literally hundreds of dollars to retrieve the boxes and have someone > hunt through it for something that might or might not be there. > > Or, in a cost cutting thing "We have all these boxes of stuff from 1980 > that we're paying for storage on. Do you have a charge number for the > storage fees? No? Ok, into the trash it goes" > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > >
Z
Ziggy
Sat, Oct 23, 2010 9:59 PM
I did note that it was the temp sensor, but the  behavior was clearly
different. I guess my earlier search terms weren't good enough to reveal
this info about the sensor differences in the T'bolts. I've done some
further digging and now have the scoop on these DS1620 changes, etc.
Other than pretty graphs, it looks like the difference between units
using one vs. the other is a (relatively) minor difference in pps
jitter. Also that for those interested enough, there have been plenty of
folks that have swapped the sensor. Thanks!
Ziggy
On 10/23/2010 3:31 PM, Bob Camp wrote:
Hi
Bob
Hi Ziggy,
seeing there.
Cheers,
Magnus
I did note that it was the temp sensor, but the behavior was clearly different. I guess my earlier search terms weren't good enough to reveal this info about the sensor differences in the T'bolts. I've done some further digging and now have the scoop on these DS1620 changes, etc. Other than pretty graphs, it looks like the difference between units using one vs. the other is a (relatively) minor difference in pps jitter. Also that for those interested enough, there have been plenty of folks that have swapped the sensor. Thanks! Ziggy On 10/23/2010 3:31 PM, Bob Camp wrote: > Hi > > If you look at the fine print on the yellow graph, it's running right at the limit of the "bad" temp sensor. What you are seeing is normal stepping / averaging on the low resolution sensor. > > Bob > > > On Oct 23, 2010, at 3:28 PM, Magnus Danielson wrote: > >> Hi Ziggy, >> >> On 10/23/2010 09:05 PM, Ziggy wrote: >>> I don't know if embedded images will make it through to the list, but >>> can someone explain the behavior indicated in this graph? This is from >>> an auction and it doesn't look at all like other graphs that I've seen. >>> It's only for a 12 min span, but others with a short span aren't similar. >>> >>> If the included graph doesn't make it to the list, please take a look at >>> the auction (150508234942). I'd like to understand more of what I am am >>> seeing there. >> I assume you refer to the yellow curve... >> >> Isn't that the average from the temp-sensor, being the modern coarse-stepped variant as things heats up it looks like the step-response of a one pole low-pass filter. >> >> Cheers, >> Magnus >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
J
jimlux
Sat, Oct 23, 2010 10:04 PM
J. Forster wrote:
True.
Yep.. You get to the end of your phase of the project. You've got file
cabinets and shelves full of stuff, most junk, but some useful, as do
your co-workers. The managers are anxious to "get those people off the
charge number" and besides YOU want to get working on the next project.
So, into the boxes it goes, "Miscellaneous documentation, Box 1 of
50", "Miscellaneous documentation, Box 2 of 50".
If something goes wrong, and you need to do it, you ask for a big
conference room and have them bring back all 50 boxes, and THEN go
hunting through it for the stuff you need.
We all start out saying, "This time, we're going to archive things in an
orderly way, and do it as we go along, and it's going to be a exemplary
situation" and pretty soon, as schedules get tight and budgets tighter,
that good intention goes by the wayside.
(And besides, nobody ever gets an award or merit pay increase for "good
filing".. you get it for "delivering the product on time", or worse yet
"for finding that nugget in the 100 boxes of documentation")
J. Forster wrote: > True. > > I've been in warehouses with hundreds of rows of shelves of Bankers Boxes > filled with records. I doubt the stuff is even indexed. > Yep.. You get to the end of your phase of the project. You've got file cabinets and shelves full of stuff, most junk, but some useful, as do your co-workers. The managers are anxious to "get those people off the charge number" and besides YOU want to get working on the next project. So, into the boxes it goes, "Miscellaneous documentation, Box 1 of 50", "Miscellaneous documentation, Box 2 of 50". If something goes wrong, and you need to do it, you ask for a big conference room and have them bring back all 50 boxes, and THEN go hunting through it for the stuff you need. We all start out saying, "This time, we're going to archive things in an orderly way, and do it as we go along, and it's going to be a exemplary situation" and pretty soon, as schedules get tight and budgets tighter, that good intention goes by the wayside. (And besides, nobody ever gets an award or merit pay increase for "good filing".. you get it for "delivering the product on time", or worse yet "for finding that nugget in the 100 boxes of documentation")
S
shalimr9@gmail.com
Sun, Oct 24, 2010 1:21 AM
They are required to keep it by law, and they will get paid to look for stuff, if anyone (most likely the government of a court) wants them to, so I am not sure why they should spend their own money to make that task easy...
Didier
Sent from my Verizon Wireless BlackBerry
-----Original Message-----
Sender: time-nuts-bounces@febo.com
Date: Sat, 23 Oct 2010 14:47:33
To: Discussion of precise time and frequency measurementtime-nuts@febo.com
Reply-To: jfor@quik.com, Discussion of precise time and frequency measurement
time-nuts@febo.com
Subject: Re: [time-nuts] Maintaining boatanchors (was Capacitor Failures)
True.
-John
They are required to keep it by law, and they will get paid to look for stuff, if anyone (most likely the government of a court) wants them to, so I am not sure why they should spend their own money to make that task easy... Didier Sent from my Verizon Wireless BlackBerry -----Original Message----- From: "J. Forster" <jfor@quik.com> Sender: time-nuts-bounces@febo.com Date: Sat, 23 Oct 2010 14:47:33 To: Discussion of precise time and frequency measurement<time-nuts@febo.com> Reply-To: jfor@quik.com, Discussion of precise time and frequency measurement <time-nuts@febo.com> Subject: Re: [time-nuts] Maintaining boatanchors (was Capacitor Failures) True. I've been in warehouses with hundreds of rows of shelves of Bankers Boxes filled with records. I doubt the stuff is even indexed. -John ============== > Heathkid wrote: >> Backup images are fine... but has anyone considered or tried to contact >> the original programmers to get the actual code used? I'm sure there >> wouldn't be any reason someone would still consider 30+ year old code a >> "trade secret" and if one had the original code... could reasonably >> replicate an old programmed chip with a newer one. Just a thought. >> >> > more likely, nobody still working there knows what the original code is, > and they threw it away 10 years ago. > > I work in the spacecraft electronics business, and we're positively > compulsive about documentation, but there's plenty of stuff that just > gets lost. "Oh yeah, we were cleaning out Dave's office after he died, > and we just pitched all those printouts and databooks with the notes on > the pages. Everything is online now, right?" > > Or, it's somewhere in the archives, in one of several hundred boxes > labeled "miscellaneous documentation from 1981-1985" and it would cost > literally hundreds of dollars to retrieve the boxes and have someone > hunt through it for something that might or might not be there. > > Or, in a cost cutting thing "We have all these boxes of stuff from 1980 > that we're paying for storage on. Do you have a charge number for the > storage fees? No? Ok, into the trash it goes" > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > > _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
J
jimlux
Sun, Oct 24, 2010 2:34 AM
Didier
Bankers Box is a brand name for a cardboard file storage box.
Of late, banks and businesses store most records electronically.  Except
in cases like a home mortgage, where there are legal requirements to
keep the originals on file.
Most businesses these days are pretty vigorous on document retention
policies, not saving anything they don't have to, particularly if it
might ever come up as discovery in a lawsuit.  Remember the Enron VP's
comment to her staff "Make sure you're following the retention and
disposal policy"..
I've seen some very nifty machines that will take a box full of paper
documents and with almost no human intervention, take the documents out
of the folders, scan both sides, etc. at amazingly high speeds.
But that doesn't mean that there aren't warehouses full of boxes and
crates of miscellanea out there, ready to be studied by "top men,
top..." should the need arise.
time-nuts@febo.com
True.
-John
shalimr9@gmail.com wrote: > They are required to keep it by law, and they will get paid to look for stuff, if anyone (most likely the government of a court) wants them to, so I am not sure why they should spend their own money to make that task easy... > > Didier > Bankers Box is a brand name for a cardboard file storage box. Of late, banks and businesses store most records electronically. Except in cases like a home mortgage, where there are legal requirements to keep the originals on file. Most businesses these days are pretty vigorous on document retention policies, not saving anything they don't have to, particularly if it might *ever* come up as discovery in a lawsuit. Remember the Enron VP's comment to her staff "Make sure you're following the retention and disposal policy".. I've seen some very nifty machines that will take a box full of paper documents and with almost no human intervention, take the documents out of the folders, scan both sides, etc. at amazingly high speeds. But that doesn't mean that there aren't warehouses full of boxes and crates of miscellanea out there, ready to be studied by "top men, top..." should the need arise. > Sent from my Verizon Wireless BlackBerry > > -----Original Message----- > From: "J. Forster" <jfor@quik.com> > Sender: time-nuts-bounces@febo.com > Date: Sat, 23 Oct 2010 14:47:33 > To: Discussion of precise time and frequency measurement<time-nuts@febo.com> > Reply-To: jfor@quik.com, Discussion of precise time and frequency measurement > <time-nuts@febo.com> > Subject: Re: [time-nuts] Maintaining boatanchors (was Capacitor Failures) > > True. > > I've been in warehouses with hundreds of rows of shelves of Bankers Boxes > filled with records. I doubt the stuff is even indexed. > > -John >
DI
David I. Emery
Sun, Oct 24, 2010 3:21 AM
These days John is absolutely right... likely none of the
developers, none of the equipment, perhaps not even the corporate
shell of the division or department that designed the product and
wrote the software survives.  Probably the source code was thrown
out with the old servers that were sold for scrap... or just carted off
to be shredded with all the other paper and electronic records...
Horror stories abound about organizations that need to make some
minor patch or change to source code of a popular product for some
important customer even just a few years after its release and nobody
can find the right source code or the right build environment
(compilers, libraries, OS etc and the hardware they ran on) or if they
can be found it takes many many hours of expensive time and talent to
reconstruct the right stuff to actually make a code image that matches
what is shipping.
Dave Emery N1PRE/AE, die@dieconsulting.com  DIE Consulting, Weston, Mass 02493
"An empty zombie mind with a forlorn barely readable weatherbeaten
'For Rent' sign still vainly flapping outside on the weed encrusted pole - in
celebration of what could have been, but wasn't and is not to be now either."
On Sat, Oct 23, 2010 at 02:44:51PM -0700, J. Forster wrote: > Very true, except it's more like 5-10 years. These days John is absolutely right... likely none of the developers, none of the equipment, perhaps not even the corporate shell of the division or department that designed the product and wrote the software survives. Probably the source code was thrown out with the old servers that were sold for scrap... or just carted off to be shredded with all the other paper and electronic records... Horror stories abound about organizations that need to make some minor patch or change to source code of a popular product for some important customer even just a few years after its release and nobody can find the right source code or the right build environment (compilers, libraries, OS etc and the hardware they ran on) or if they can be found it takes many many hours of expensive time and talent to reconstruct the right stuff to actually make a code image that matches what is shipping. -- Dave Emery N1PRE/AE, die@dieconsulting.com DIE Consulting, Weston, Mass 02493 "An empty zombie mind with a forlorn barely readable weatherbeaten 'For Rent' sign still vainly flapping outside on the weed encrusted pole - in celebration of what could have been, but wasn't and is not to be now either."
DC
David C. Partridge
Sun, Oct 24, 2010 10:56 AM
Or it's just been lost between the cracks in reality ...
Regards,
David Partridge
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of Bob Camp
Sent: 23 October 2010 21:59
Hi
Bob
Or it's just been lost between the cracks in reality ... Regards, David Partridge -----Original Message----- From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of Bob Camp Sent: 23 October 2010 21:59 To: Discussion of precise time and frequency measurement Subject: Re: [time-nuts] Maintaining boatanchors (was Capacitor Failures) Hi I've been down that road a couple of times. You get to a point where everyone involved does indeed agree that "it's not a secret" anymore. Going the final step and actually getting permission to hand out the code is often impossible. You get into a "nobody has the authority to approve that" hassle. Bob
DC
David C. Partridge
Sun, Oct 24, 2010 11:10 AM
Oh how true - an organisation I worked for some years back had the source code matching a custom package that was running at a certain customer, but not the build environment (that machine with that precise operating system patch level, compiler patch level etc.).
When the customer said thay'd pay for the source to look after if themselves, rather than continue to pay maintenance, they insisted that a new build be run to prove that exact byte for byte identical binaries to what they were running could be re-created  - a wise move indeed - it took 8 man months to re-create that build environment (and that was only possible because I insisted we archive all the patches to the system, compilers and libraries).
Regards,
David Partridge
From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of David I. Emery
Sent: 24 October 2010 04:22
To: jfor@quik.com; Discussion of precise time and frequency measurement
Oh how true - an organisation I worked for some years back had the source code matching a custom package that was running at a certain customer, but not the build environment (that machine with that precise operating system patch level, compiler patch level etc.). When the customer said thay'd pay for the source to look after if themselves, rather than continue to pay maintenance, they insisted that a new build be run to prove that exact byte for byte identical binaries to what they were running could be re-created - a wise move indeed - it took 8 man months to re-create that build environment (and that was only possible because I insisted we archive all the patches to the system, compilers and libraries). Regards, David Partridge -----Original Message----- From: time-nuts-bounces@febo.com [mailto:time-nuts-bounces@febo.com] On Behalf Of David I. Emery Sent: 24 October 2010 04:22 To: jfor@quik.com; Discussion of precise time and frequency measurement Subject: Re: [time-nuts] Maintaining boatanchors Horror stories abound about organizations that need to make some minor patch or change to source code of a popular product for some important customer even just a few years after its release and nobody can find the right source code or the right build environment (compilers, libraries, OS etc and the hardware they ran on) or if they can be found it takes many many hours of expensive time and talent to reconstruct the right stuff to actually make a code image that matches what is shipping. -- Dave Emery N1PRE/AE, die@dieconsulting.com DIE Consulting, Weston, Mass 02493 "An empty zombie mind with a forlorn barely readable weatherbeaten 'For Rent' sign still vainly flapping outside on the weed encrusted pole - in celebration of what could have been, but wasn't and is not to be now either." _______________________________________________ time-nuts mailing list -- time-nuts@febo.com To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts and follow the instructions there.
MD
Magnus Danielson
Sun, Oct 24, 2010 11:30 AM
Very true, exncept it's more like 5-10 years.
what is shipping.
Even if you have the source code, you need to keep the compiling
environment in a runable state. This may be problematic since things
like licensees may have gone out (nobody payed for them and you can't
get a new one), the machines setup for running it has dropped out of
service. Maybe some manual work was never automated so some of the magic
is in the hands of someone that doesn't work there anymore... or recall it.
Keeping the source is one thing, being able to actually use it is another.
The RTOS manuals and support files may have been tossed for instance...
With all this... I still want the source thought. Alongside with other
internal documentation. I have never seen any of that surfaced for
boatanchors of any kind.
Cheers,
Magnus
On 10/24/2010 05:21 AM, David I. Emery wrote: > On Sat, Oct 23, 2010 at 02:44:51PM -0700, J. Forster wrote: >> Very true, exncept it's more like 5-10 years. > > These days John is absolutely right... likely none of the > developers, none of the equipment, perhaps not even the corporate > shell of the division or department that designed the product and > wrote the software survives. Probably the source code was thrown > out with the old servers that were sold for scrap... or just carted off > to be shredded with all the other paper and electronic records... > > Horror stories abound about organizations that need to make some > minor patch or change to source code of a popular product for some > important customer even just a few years after its release and nobody > can find the right source code or the right build environment > (compilers, libraries, OS etc and the hardware they ran on) or if they > can be found it takes many many hours of expensive time and talent to > reconstruct the right stuff to actually make a code image that matches > what is shipping. > > Even if you have the source code, you need to keep the compiling environment in a runable state. This may be problematic since things like licensees may have gone out (nobody payed for them and you can't get a new one), the machines setup for running it has dropped out of service. Maybe some manual work was never automated so some of the magic is in the hands of someone that doesn't work there anymore... or recall it. Keeping the source is one thing, being able to actually use it is another. The RTOS manuals and support files may have been tossed for instance... With all this... I still want the source thought. Alongside with other internal documentation. I have never seen any of that surfaced for boatanchors of any kind. Cheers, Magnus
RK
Rick Karlquist
Sun, Oct 24, 2010 12:04 PM
It is even worse than you think.  When I was developing
the HP 5334B counter, the plan was to use the firmware
from the 5334A counter (currently in production) and use
the same legacy microprocessors.  However, we wanted to
replace the expensive HP made divide by 10 prescaler with
an off the shelf divide by 64 (or some power of two, I
don't remember).  At that point in time, we had already,
while still building the 5334A, reached the point described
below.  No source code, and no development system.  Also,
the whole thing had been shoehorned into 2k of memory, with
little or no extra space.
Fortunately, the original software engineer still worked
for the company and I talked him into tweaking the machine
code to change the prescale modulus.  Miraculously, he
was able to pull it off, and the rest is history.
Speaking of important customers, the military wanted some
feature called "MATE" which meant something like Military
Automatic Test Equipment.  It involved translating commands
from HP-IB.  What they had to do to add this was add a board
with its own microprocessor that did the translation and wire
it between the HP-IB hardware and the measurement controller,
because they could not modify the measurement controller for
the reasons given below, and other reasons.
Rick Karlquist N6RK
what is shipping.
it.
Cheers,
Magnus
It is even worse than you think. When I was developing the HP 5334B counter, the plan was to use the firmware from the 5334A counter (currently in production) and use the same legacy microprocessors. However, we wanted to replace the expensive HP made divide by 10 prescaler with an off the shelf divide by 64 (or some power of two, I don't remember). At that point in time, we had already, while still building the 5334A, reached the point described below. No source code, and no development system. Also, the whole thing had been shoehorned into 2k of memory, with little or no extra space. Fortunately, the original software engineer still worked for the company and I talked him into tweaking the machine code to change the prescale modulus. Miraculously, he was able to pull it off, and the rest is history. Speaking of important customers, the military wanted some feature called "MATE" which meant something like Military Automatic Test Equipment. It involved translating commands from HP-IB. What they had to do to add this was add a board with its own microprocessor that did the translation and wire it between the HP-IB hardware and the measurement controller, because they could not modify the measurement controller for the reasons given below, and other reasons. Rick Karlquist N6RK Magnus Danielson wrote: > On 10/24/2010 05:21 AM, David I. Emery wrote: >> On Sat, Oct 23, 2010 at 02:44:51PM -0700, J. Forster wrote: >>> Very true, exncept it's more like 5-10 years. >> >> These days John is absolutely right... likely none of the >> developers, none of the equipment, perhaps not even the corporate >> shell of the division or department that designed the product and >> wrote the software survives. Probably the source code was thrown >> out with the old servers that were sold for scrap... or just carted off >> to be shredded with all the other paper and electronic records... >> >> Horror stories abound about organizations that need to make some >> minor patch or change to source code of a popular product for some >> important customer even just a few years after its release and nobody >> can find the right source code or the right build environment >> (compilers, libraries, OS etc and the hardware they ran on) or if they >> can be found it takes many many hours of expensive time and talent to >> reconstruct the right stuff to actually make a code image that matches >> what is shipping. >> >> > > Even if you have the source code, you need to keep the compiling > environment in a runable state. This may be problematic since things > like licensees may have gone out (nobody payed for them and you can't > get a new one), the machines setup for running it has dropped out of > service. Maybe some manual work was never automated so some of the magic > is in the hands of someone that doesn't work there anymore... or recall > it. > > Keeping the source is one thing, being able to actually use it is another. > > The RTOS manuals and support files may have been tossed for instance... > > With all this... I still want the source thought. Alongside with other > internal documentation. I have never seen any of that surfaced for > boatanchors of any kind. > > Cheers, > Magnus > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > >
RK
Rick Karlquist
Sun, Oct 24, 2010 3:13 PM
In the old days, the manuals were typeset by some outside service,
and they maintained the manual.  There was nothing maintained at
HP, so when the product was discontinued, the outside service no
longer received orders for manuals, and they threw away their
stuff.  The only documentation at HP itself were actual copies of
manuals, that had to be purchased from the outside service.  It
was no one's job to save obsolete manuals, even at the division
that wrote them.  Some HP libraries collected whatever manuals
were donated and tried to archive them.  But there was no guarantee
any particular manual would get donated.  And then the libraries
ran low on space and had to purge.  Etc.
Rick Karlquist N6RK
Charles P. Steinmetz wrote: > Approve it? I bet most manufacturers can't even FIND the code for > equipment designed more than 25 years ago. Note that HP has had to > rely on the kindness of strangers for copies of its older manuals. In the old days, the manuals were typeset by some outside service, and they maintained the manual. There was nothing maintained at HP, so when the product was discontinued, the outside service no longer received orders for manuals, and they threw away their stuff. The only documentation at HP itself were actual copies of manuals, that had to be purchased from the outside service. It was no one's job to save obsolete manuals, even at the division that wrote them. Some HP libraries collected whatever manuals were donated and tried to archive them. But there was no guarantee any particular manual would get donated. And then the libraries ran low on space and had to purge. Etc. Rick Karlquist N6RK
JF
J. Forster
Sun, Oct 24, 2010 4:02 PM
I buy a lot of 10-20 year old test and other gear. When I try to get info
on some things the reaction is usually, "Oh, we havn't made that thing for
AGES now. It turns out "ages" is anything over about 3 months. "We now
have the xxxx model which is SOO much better than that old POS, and it's
only $25,000 more w/o options".
At that point I ask to speak to the oldest engineer or srevice tech.
SIGH!!!
BTW, I have started and joined a number of Yahoo Groups because sharing
and pooling info is now easy electronically, and in many cases is the only
source of information, other than suppliers of scanned or copied manuals,
like Artek Media.
FWIW,
-John
what is shipping.
02493
in
either."
I buy a lot of 10-20 year old test and other gear. When I try to get info on some things the reaction is usually, "Oh, we havn't made that thing for AGES now. It turns out "ages" is anything over about 3 months. "We now have the xxxx model which is SOO much better than that old POS, and it's only $25,000 more w/o options". At that point I ask to speak to the oldest engineer or srevice tech. SIGH!!! BTW, I have started and joined a number of Yahoo Groups because sharing and pooling info is now easy electronically, and in many cases is the only source of information, other than suppliers of scanned or copied manuals, like Artek Media. FWIW, -John ================ > On Sat, Oct 23, 2010 at 02:44:51PM -0700, J. Forster wrote: >> Very true, except it's more like 5-10 years. > > These days John is absolutely right... likely none of the > developers, none of the equipment, perhaps not even the corporate > shell of the division or department that designed the product and > wrote the software survives. Probably the source code was thrown > out with the old servers that were sold for scrap... or just carted off > to be shredded with all the other paper and electronic records... > > Horror stories abound about organizations that need to make some > minor patch or change to source code of a popular product for some > important customer even just a few years after its release and nobody > can find the right source code or the right build environment > (compilers, libraries, OS etc and the hardware they ran on) or if they > can be found it takes many many hours of expensive time and talent to > reconstruct the right stuff to actually make a code image that matches > what is shipping. > > > -- > Dave Emery N1PRE/AE, die@dieconsulting.com DIE Consulting, Weston, Mass > 02493 > "An empty zombie mind with a forlorn barely readable weatherbeaten > 'For Rent' sign still vainly flapping outside on the weed encrusted pole - > in > celebration of what could have been, but wasn't and is not to be now > either." > >
MD
Magnus Danielson
Sun, Oct 24, 2010 4:19 PM
SIGH!!!
There is an issue of fatigue that adds to the situation. Now that they
FINALY have done away with that old box somebody comes and ask for it,
and for meager motivation in money...
Cheers,
Magnus
On 10/24/2010 06:02 PM, J. Forster wrote: > I buy a lot of 10-20 year old test and other gear. When I try to get info > on some things the reaction is usually, "Oh, we havn't made that thing for > AGES now. It turns out "ages" is anything over about 3 months. "We now > have the xxxx model which is SOO much better than that old POS, and it's > only $25,000 more w/o options". > > At that point I ask to speak to the oldest engineer or srevice tech. > > SIGH!!! There is an issue of fatigue that adds to the situation. Now that they *FINALY* have done away with that old box somebody comes and ask for it, and for meager motivation in money... Cheers, Magnus
JF
J. Forster
Sun, Oct 24, 2010 4:48 PM
It was my impression that many HP (and Tek, PAR and others) Field Offices
had full manual sets for everythng they supported. I got a hardware fiche
manual for an HP total station from the Boston office.
Best,
-John
Rick Karlquist N6RK
It was my impression that many HP (and Tek, PAR and others) Field Offices had full manual sets for everythng they supported. I got a hardware fiche manual for an HP total station from the Boston office. Best, -John ============== > Charles P. Steinmetz wrote: > >> Approve it? I bet most manufacturers can't even FIND the code for >> equipment designed more than 25 years ago. Note that HP has had to >> rely on the kindness of strangers for copies of its older manuals. > > In the old days, the manuals were typeset by some outside service, > and they maintained the manual. There was nothing maintained at > HP, so when the product was discontinued, the outside service no > longer received orders for manuals, and they threw away their > stuff. The only documentation at HP itself were actual copies of > manuals, that had to be purchased from the outside service. It > was no one's job to save obsolete manuals, even at the division > that wrote them. Some HP libraries collected whatever manuals > were donated and tried to archive them. But there was no guarantee > any particular manual would get donated. And then the libraries > ran low on space and had to purge. Etc. > > Rick Karlquist N6RK > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > >
JF
J. Forster
Sun, Oct 24, 2010 4:51 PM
Actually, I've found that some old timers are delighted to chat about
older gear with somebody who still appreciates it.
The newbies are usually far less than helpful.
-John
info
for
SIGH!!!
Cheers,
Magnus
Actually, I've found that some old timers are delighted to chat about older gear with somebody who still appreciates it. The newbies are usually far less than helpful. -John =============== > On 10/24/2010 06:02 PM, J. Forster wrote: >> I buy a lot of 10-20 year old test and other gear. When I try to get >> info >> on some things the reaction is usually, "Oh, we havn't made that thing >> for >> AGES now. It turns out "ages" is anything over about 3 months. "We now >> have the xxxx model which is SOO much better than that old POS, and it's >> only $25,000 more w/o options". >> >> At that point I ask to speak to the oldest engineer or srevice tech. >> >> SIGH!!! > > There is an issue of fatigue that adds to the situation. Now that they > *FINALY* have done away with that old box somebody comes and ask for it, > and for meager motivation in money... > > Cheers, > Magnus > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > >
BC
Bob Camp
Sun, Oct 24, 2010 5:03 PM
Hi
At least for us the process goes like:
  1. Customer wants more than what's in the card file on in the electronic record system
  2. Decision is made about how bad they want it
  3. Engineer (not a tech) is assigned to dig the paper data up
  4. A guess is made about which of many thousands of boxes might have the info in it
  5. A request is put in to retrieve the most likely dozen boxes from off site storage
  6. The boxes are gone through looking for the information
  7. loop through steps 4,5,6 how ever many times needed
  8. The data is re-formated so it's readable and rational
  9. Out it goes
The whole process runs 1 to 4 weeks depending ...
Bob
SIGH!!!
like Artek Media.
FWIW,
-John
what is shipping.
02493
in
either."
Hi At least for us the process goes like: 1) Customer wants more than what's in the card file on in the electronic record system 2) Decision is made about how bad they want it 3) Engineer (not a tech) is assigned to dig the paper data up 4) A *guess* is made about which of many thousands of boxes *might* have the info in it 5) A request is put in to retrieve the most likely dozen boxes from off site storage 6) The boxes are gone through looking for the information 7) loop through steps 4,5,6 how ever many times needed 8) The data is re-formated so it's readable and rational 9) Out it goes The whole process runs 1 to 4 weeks depending ... Bob On Oct 24, 2010, at 12:02 PM, J. Forster wrote: > I buy a lot of 10-20 year old test and other gear. When I try to get info > on some things the reaction is usually, "Oh, we havn't made that thing for > AGES now. It turns out "ages" is anything over about 3 months. "We now > have the xxxx model which is SOO much better than that old POS, and it's > only $25,000 more w/o options". > > At that point I ask to speak to the oldest engineer or srevice tech. > > SIGH!!! > > BTW, I have started and joined a number of Yahoo Groups because sharing > and pooling info is now easy electronically, and in many cases is the only > source of information, other than suppliers of scanned or copied manuals, > like Artek Media. > > FWIW, > > -John > > ================ > >> On Sat, Oct 23, 2010 at 02:44:51PM -0700, J. Forster wrote: >>> Very true, except it's more like 5-10 years. >> >> These days John is absolutely right... likely none of the >> developers, none of the equipment, perhaps not even the corporate >> shell of the division or department that designed the product and >> wrote the software survives. Probably the source code was thrown >> out with the old servers that were sold for scrap... or just carted off >> to be shredded with all the other paper and electronic records... >> >> Horror stories abound about organizations that need to make some >> minor patch or change to source code of a popular product for some >> important customer even just a few years after its release and nobody >> can find the right source code or the right build environment >> (compilers, libraries, OS etc and the hardware they ran on) or if they >> can be found it takes many many hours of expensive time and talent to >> reconstruct the right stuff to actually make a code image that matches >> what is shipping. >> >> >> -- >> Dave Emery N1PRE/AE, die@dieconsulting.com DIE Consulting, Weston, Mass >> 02493 >> "An empty zombie mind with a forlorn barely readable weatherbeaten >> 'For Rent' sign still vainly flapping outside on the weed encrusted pole - >> in >> celebration of what could have been, but wasn't and is not to be now >> either." >> >> > > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
JF
J. Forster
Sun, Oct 24, 2010 5:21 PM
I've found engineers tend to be squirrels. A number of times they've said
to me "I'll look in my files". They will often either scan it for me or
let me borrow the original informally so I can Xerox it locally.
IMO, going through Sales or making an "official" request costs a bunch and
ir rarely successful. It's also worth asking "do you remember any major
customers of this unit?>"
-John
Hi
    record system
    the info in it
    site storage
  9. Out it goes
Bob
info
for
SIGH!!!
only
manuals,
like Artek Media.
FWIW,
-John
what is shipping.
Mass
02493
pole -
in
either."
I've found engineers tend to be squirrels. A number of times they've said to me "I'll look in my files". They will often either scan it for me or let me borrow the original informally so I can Xerox it locally. IMO, going through Sales or making an "official" request costs a bunch and ir rarely successful. It's also worth asking "do you remember any major customers of this unit?>" -John =============== > Hi > > At least for us the process goes like: > > 1) Customer wants more than what's in the card file on in the electronic > record system > 2) Decision is made about how bad they want it > 3) Engineer (not a tech) is assigned to dig the paper data up > 4) A *guess* is made about which of many thousands of boxes *might* have > the info in it > 5) A request is put in to retrieve the most likely dozen boxes from off > site storage > 6) The boxes are gone through looking for the information > 7) loop through steps 4,5,6 how ever many times needed > 8) The data is re-formated so it's readable and rational > 9) Out it goes > > The whole process runs 1 to 4 weeks depending ... > > Bob > > > On Oct 24, 2010, at 12:02 PM, J. Forster wrote: > >> I buy a lot of 10-20 year old test and other gear. When I try to get >> info >> on some things the reaction is usually, "Oh, we havn't made that thing >> for >> AGES now. It turns out "ages" is anything over about 3 months. "We now >> have the xxxx model which is SOO much better than that old POS, and it's >> only $25,000 more w/o options". >> >> At that point I ask to speak to the oldest engineer or srevice tech. >> >> SIGH!!! >> >> BTW, I have started and joined a number of Yahoo Groups because sharing >> and pooling info is now easy electronically, and in many cases is the >> only >> source of information, other than suppliers of scanned or copied >> manuals, >> like Artek Media. >> >> FWIW, >> >> -John >> >> ================ >> >>> On Sat, Oct 23, 2010 at 02:44:51PM -0700, J. Forster wrote: >>>> Very true, except it's more like 5-10 years. >>> >>> These days John is absolutely right... likely none of the >>> developers, none of the equipment, perhaps not even the corporate >>> shell of the division or department that designed the product and >>> wrote the software survives. Probably the source code was thrown >>> out with the old servers that were sold for scrap... or just carted off >>> to be shredded with all the other paper and electronic records... >>> >>> Horror stories abound about organizations that need to make some >>> minor patch or change to source code of a popular product for some >>> important customer even just a few years after its release and nobody >>> can find the right source code or the right build environment >>> (compilers, libraries, OS etc and the hardware they ran on) or if they >>> can be found it takes many many hours of expensive time and talent to >>> reconstruct the right stuff to actually make a code image that matches >>> what is shipping. >>> >>> >>> -- >>> Dave Emery N1PRE/AE, die@dieconsulting.com DIE Consulting, Weston, >>> Mass >>> 02493 >>> "An empty zombie mind with a forlorn barely readable weatherbeaten >>> 'For Rent' sign still vainly flapping outside on the weed encrusted >>> pole - >>> in >>> celebration of what could have been, but wasn't and is not to be now >>> either." >>> >>> >> >> >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. > > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. > >
B
bownes
Sun, Oct 24, 2010 5:38 PM
This makes me re-think arguing with my wife about tossing the 15 linear feet of three ring binders full of systems documentation sitting in the basement.
But not for long. I'll keep what I don't have electronically I guess, but the SunOS 2.2 manual set can totally go in the trash.
The field engineering manuals on the other hand, all stay. I actually used one from the early 80's a few weeks ago to build a discrete stepper motor controller rather than order the newfangled ic.
This makes me re-think arguing with my wife about tossing the 15 linear feet of three ring binders full of systems documentation sitting in the basement. But not for long. I'll keep what I don't have electronically I guess, but the SunOS 2.2 manual set can totally go in the trash. The field engineering manuals on the other hand, all stay. I actually used one from the early 80's a few weeks ago to build a discrete stepper motor controller rather than order the newfangled ic. On Oct 24, 2010, at 1:03 PM, Bob Camp <lists@rtty.us> wrote: >> ask to speak to the oldest engineer or srevice tech. >>
CP
Mon, Oct 25, 2010 1:48 AM
I've encountered an HP5345A (prefix 2040A) that was apparently
originally part of an HP5390A frequency stability analyzer (prefix
2036A).  It has a factory label (No. 05345-80023) indicating that it
has a "modified front end."  I have not seen anything in the 5345A or
5390A documentation to suggest what might have been changed in the
front end.  Does anyone here know?
So far, the 5345A appears to work normally, but I have not
characterized its sensitivity or triggering performance.  The 10811
oscillator does seem to be a cut above the others I have in terms of
stability -- I don't know if this was intentional or accidental.
Thank you,
Charles
I've encountered an HP5345A (prefix 2040A) that was apparently originally part of an HP5390A frequency stability analyzer (prefix 2036A). It has a factory label (No. 05345-80023) indicating that it has a "modified front end." I have not seen anything in the 5345A or 5390A documentation to suggest what might have been changed in the front end. Does anyone here know? So far, the 5345A appears to work normally, but I have not characterized its sensitivity or triggering performance. The 10811 oscillator does seem to be a cut above the others I have in terms of stability -- I don't know if this was intentional or accidental. Thank you, Charles
