time-nuts@lists.febo.com
EG&G RFS-10-7 output selection
C
cdelect@juno.com
Fri, Nov 8, 2013 8:27 PM
Hi,
I used to have notes on how to select which output frequency the EG&G
RFS-10-7 provides but I can't find them!
It can be 5 or 10 Mhz.
Does anybody know where the selection is made?
Thanks,
Corby Dawson
Hi, I used to have notes on how to select which output frequency the EG&G RFS-10-7 provides but I can't find them! It can be 5 or 10 Mhz. Does anybody know where the selection is made? Thanks, Corby Dawson
PS
paul swed
Sat, Nov 9, 2013 5:19 PM
Corby
I have 2 EG&G RBs and would need to look at the model.
They are putting out 10 Mhz as I recall. Would be happy to look if they are
the same units to see whatever clues we could get.
Question I have always had. Do they need to be attached to a heat sink?
It looks like they may want that yet there is no heat sink compound or any
clue.
They look to be quite nice RBs, but at least on the units I have no
technical info can be found.
Regards
Paul
WB8TSL
On Fri, Nov 8, 2013 at 3:27 PM, cdelect@juno.com wrote:
Hi,
Thanks,
Corby Dawson
To unsubscribe, go to
Corby I have 2 EG&G RBs and would need to look at the model. They are putting out 10 Mhz as I recall. Would be happy to look if they are the same units to see whatever clues we could get. Question I have always had. Do they need to be attached to a heat sink? It looks like they may want that yet there is no heat sink compound or any clue. They look to be quite nice RBs, but at least on the units I have no technical info can be found. Regards Paul WB8TSL On Fri, Nov 8, 2013 at 3:27 PM, <cdelect@juno.com> wrote: > Hi, > > I used to have notes on how to select which output frequency the EG&G > RFS-10-7 provides but I can't find them! > > It can be 5 or 10 Mhz. > > Does anybody know where the selection is made? > > Thanks, > > Corby Dawson > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
BC
Bob Camp
Sat, Nov 9, 2013 7:39 PM
Hi
Pretty much all Rb’s want to have a heat sink. Often they got used with some sort of pad rather than heat sink grease. It’s much less messy that way. The rack mount Rb’s are about the only exception to the heat sink rule.
Bob
On Nov 9, 2013, at 12:19 PM, paul swed paulswedb@gmail.com wrote:
Corby
clue.
Regards
Paul
WB8TSL
Hi,
Thanks,
Corby Dawson
Hi Pretty much all Rb’s want to have a heat sink. Often they got used with some sort of pad rather than heat sink grease. It’s much less messy that way. The rack mount Rb’s are about the only exception to the heat sink rule. Bob On Nov 9, 2013, at 12:19 PM, paul swed <paulswedb@gmail.com> wrote: > Corby > I have 2 EG&G RBs and would need to look at the model. > They are putting out 10 Mhz as I recall. Would be happy to look if they are > the same units to see whatever clues we could get. > Question I have always had. Do they need to be attached to a heat sink? > It looks like they may want that yet there is no heat sink compound or any > clue. > They look to be quite nice RBs, but at least on the units I have no > technical info can be found. > Regards > Paul > WB8TSL > > > On Fri, Nov 8, 2013 at 3:27 PM, <cdelect@juno.com> wrote: > >> Hi, >> >> I used to have notes on how to select which output frequency the EG&G >> RFS-10-7 provides but I can't find them! >> >> It can be 5 or 10 Mhz. >> >> Does anybody know where the selection is made? >> >> Thanks, >> >> Corby Dawson >> >> _______________________________________________ >> time-nuts mailing list -- time-nuts@febo.com >> To unsubscribe, go to >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts >> and follow the instructions there. >> > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there.
PS
paul swed
Sat, Nov 9, 2013 11:35 PM
Looked at my egg and its a TS-RFS circa 1999
One end does appear that it would have been bolted to something.
But it could as easily be the chassis mount as anything no real clue.
But easy enough to leverage the 5 holes to attach to an aluminium
plate/rack panel.
Sorry its not the same model Bob.
Regards
Paul
WB8TSL
On Sat, Nov 9, 2013 at 2:39 PM, Bob Camp lists@rtty.us wrote:
Hi
Bob
Corby
are
any
clue.
Regards
Paul
WB8TSL
Hi,
Thanks,
Corby Dawson
Looked at my egg and its a TS-RFS circa 1999 One end does appear that it would have been bolted to something. But it could as easily be the chassis mount as anything no real clue. But easy enough to leverage the 5 holes to attach to an aluminium plate/rack panel. Sorry its not the same model Bob. Regards Paul WB8TSL On Sat, Nov 9, 2013 at 2:39 PM, Bob Camp <lists@rtty.us> wrote: > Hi > > Pretty much all Rb’s want to have a heat sink. Often they got used with > some sort of pad rather than heat sink grease. It’s much less messy that > way. The rack mount Rb’s are about the only exception to the heat sink rule. > > Bob > > On Nov 9, 2013, at 12:19 PM, paul swed <paulswedb@gmail.com> wrote: > > > Corby > > I have 2 EG&G RBs and would need to look at the model. > > They are putting out 10 Mhz as I recall. Would be happy to look if they > are > > the same units to see whatever clues we could get. > > Question I have always had. Do they need to be attached to a heat sink? > > It looks like they may want that yet there is no heat sink compound or > any > > clue. > > They look to be quite nice RBs, but at least on the units I have no > > technical info can be found. > > Regards > > Paul > > WB8TSL > > > > > > On Fri, Nov 8, 2013 at 3:27 PM, <cdelect@juno.com> wrote: > > > >> Hi, > >> > >> I used to have notes on how to select which output frequency the EG&G > >> RFS-10-7 provides but I can't find them! > >> > >> It can be 5 or 10 Mhz. > >> > >> Does anybody know where the selection is made? > >> > >> Thanks, > >> > >> Corby Dawson > >> > >> _______________________________________________ > >> time-nuts mailing list -- time-nuts@febo.com > >> To unsubscribe, go to > >> https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > >> and follow the instructions there. > >> > > _______________________________________________ > > time-nuts mailing list -- time-nuts@febo.com > > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > > and follow the instructions there. > > _______________________________________________ > time-nuts mailing list -- time-nuts@febo.com > To unsubscribe, go to > https://www.febo.com/cgi-bin/mailman/listinfo/time-nuts > and follow the instructions there. >
