Hi,
I tryied to cross compile pjsip 2.0 with video support for embedded ARM. But
when I run application, or pjsua, I`m getting this error.
20:55:17.983 ffmpeg_codecs. ...The H263-1998 decoder is using base codec
(H263)
20:55:17.983 ffmpeg_codecs. ...The XVID codec is using base codec (MP4V)
20:55:17.984 colorbar_dev.c ...Colorbar video src initialized with 1
device(s):
20:55:17.985 colorbar_dev.c ... 0: Colorbar generator
20:55:17.989 sdl_dev.c !Failed initializing SDL
SimpleBrowser: ../src/pjmedia-videodev/sdl_dev.c:523: sdl_factory_destroy:
Assertion `pj_list_empty(&sf->streams)' failed.
What do you think can be a problem? This are my configures for SDL, ffmpeg
and pjsip Thank you very much.
SDL:
./configure --prefix=/home/matuga/pjsip/compiled/
--exec-prefix=/home/matuga/pjsip/compiled/ --host=arm-linux --disable-shared
--enable-static --disable-video-x11 --disable-video-cocoa
--enable-video-directfb --disable-directx --disable-video-opengl
--disable-video-opengles
Ffmpeg:
./configure --prefix=/home/matuga/pjsip/compiled/ --enable-cross-compile
--enable-shared --disable-static --enable-memalign-hack --arch=arm
--target-os=linux --cross-prefix=arm-linux-
Pjsip:
./configure --host="arm-linux" --prefix="/home/matuga/pjsip/compiled"
--disable-large-filter --disable-speex-aec --disable-l16-codec
--disable-g7221-codec --disable-speex-codec --disable-ilbc-codec
--disable-speex-aec CFLAGS="-I/home/matuga/pjsip/compiled/include/"
LDFLAGS="-L/home/matuga/pjsip/compiled/lib/"
Allright, found the problem.
After extending error message with SDL_GetError() I found, that SDL failed
to initialize because of no video device.
Than I made investigation about this problem, and I found, that driver fbcon
was removed in SDL 1.3. I don`t see source for this driver in src/video
either.
Question is, how to make some kind of workaround to make it work.
From: pjsip-bounces@lists.pjsip.org [mailto:pjsip-bounces@lists.pjsip.org]
On Behalf Of Michal Matuga
Sent: Thursday, March 15, 2012 4:35 PM
To: pjsip@lists.pjsip.org
Subject: [pjsip] Failed to initialize SDL
Hi,
(H263)
device(s):
SDL:
Ffmpeg:
Pjsip:
Hi,
Am too getting the same error when I try to build PJSIP with SDL on
my ubuntu 12.04 machine. Meanwhile I did see a FAQ regarding this at
http://wiki.libsdl.org/moin.cgi/FAQLinux . Any work around for this issue?
On Thu, Mar 15, 2012 at 9:56 PM, Michal Matuga matuga@microstep.sk wrote:
Allright, found the problem.****
failed to initialize because of no video device.****
fbcon was removed in SDL 1.3. I don`t see source for this driver in
src/video either.****
Question is, how to make some kind of workaround to make it work.****
pjsip-bounces@lists.pjsip.org] On Behalf Of Michal Matuga
Subject: [pjsip] Failed to initialize SDL**
Hi,****
But when I run application, or pjsua, I`m getting this error.****
(H263)****
20:55:17.983 ffmpeg_codecs. ...The XVID codec is using base codec (MP4V)*
device(s):****
20:55:17.985 colorbar_dev.c ... 0: Colorbar generator****
20:55:17.989 sdl_dev.c !Failed initializing SDL****
Assertion `pj_list_empty(&sf->streams)' failed.****
and pjsip Thank you very much.****
SDL:****
--disable-shared --enable-static --disable-video-x11 --disable-video-cocoa
--disable-video-opengles****
Ffmpeg:****
--target-os=linux --cross-prefix=arm-linux-****
Pjsip:****
LDFLAGS="-L/home/matuga/pjsip/compiled/lib/"****
Visit our blog: http://blog.pjsip.org
pjsip mailing list
http://lists.pjsip.org/mailman/listinfo/pjsip_lists.pjsip.org
Hi,
This issue got resolved for me.My mercurial copy of SDL is in fact up
to date. I updated my svn copy of PJSIP today after about a week and now
everything seems to work fine.
On Mon, Jul 2, 2012 at 3:48 PM, Sandeep Karanth sandeepk.kdp@gmail.comwrote:
Hi,
Hi,****
(H263)****
device(s):****
sdl_factory_destroy: Assertion `pj_list_empty(&sf->streams)' failed.****
ffmpeg and pjsip Thank you very much.****
SDL:****
Ffmpeg:****
Pjsip:****
pjsip mailing list
Regards,
Sandeep Karanth
