Hello,
I was inspiring by PHK's post of his open-source GPIB monitoring system to mention
that I'm working on remote monitoring and control of my newly acquired PRS-10.
I've read the posts in the lists archive about how the discipline against a
GPS external PPS is not optimal.
I've been working on a C program to display the parameters from my PRS-10 and present its state
in logical blocks with conversion of raw values to real-world voltages and frequencies.
That's inspired by Brooke's screenshots of his LabView program. However, since I want to
do remote monitoring, I'm using ncurses to layout the full-screen display so I can monitor
with ssh to my monitoring system. When I get done with that, I'll post it as open-source
to my git repository at http://git.b9.com.
However, the monitoring is only a portion of what I want the program to do.
I'd also want to add reading from a M12+T's sawtooth correction to get
better short-term stability of the PRS-10's PPS signal.
Does anyone have a code sample or general thoughts about what to monitor on the PRS-10
and the GPS PPS signal and how to get better short-term stability out of the PRS-10's
PPS signal that using the PRS-10's firmware alone?
Thanks,
Kevin
