Am I missing something or shouldn't I expect the filter to be hung from
the fitting making clean oil changes easy and the potential for the
filter not holding oil when the engine isn't running nearly impossible.
Oil filters, at least most of them, have anti-drainback valves in them
for this very reason. So the oil does not drain out of the filter when
the engine is not running.
Keep in mind that most marine diesels are marinized automotive or
industrial diesels. A consideration the folks who design the
marinization system have to keep in mind is how engines are mounted in
boats. There is usually not several feet of clear space under the
engine. Instead, there are big stringers alongside either side of the
engine to support the engine mounts. So it's often the case--- as it is
for the old Ford Lehman 120, for example--- that the oil filter cannot
be mounted "rightside up" in it's normal automotive position because the
engine stringers prevent this.
The solution is to mount the filter upside down so it will clear the
stringer. The filter itself doesn't care which way it's mounted. So
the only drawback is the fact that unscrewing the filter lets the oil
out all over the place. The cure is simple--- after the engine has been
run to warm up the oil and shut down, punch one or two holes in the
bottom (aka top) of the filter. Then go about the task of draining or
pumping out the oil from the engine sump. By the time you've finished
doing this, almost all the oil will have drained out of the filter back
into the sump. Wrap a rag around the top (aka bottom or base) of the
filter and unscrew it. The rag should catch the bit of oil that will
still be in the filter. Put the filter into a plastic bag immediately.
Do not turn it rightside up--- remember those holes you punched in the
other end? Oil will continue to seep out of the filter element so you
want to get the thing into a garbage bag right away because this oil
will start escaping from one end or the other.
But with this method, changing an upside-down oil filter can be done
with no mess whatsoever.
C. Marin Faure
GB36-403 "La Perouse"
Bellingham, Washington
