trawlers@lists.trawlering.com
TRAWLERS & TRAWLERING LIST
FW: RE: Deluo USB Update - good and not so good
T
trawlerphil
Tue, Nov 15, 2005 12:05 AM
FYI.. Response from Deluo on a discussion Peter and I had...  Looks like you
can extend them quite far.
                                      Regards....
Phil Rosch
Old Harbor Consulting
M/V "Curmudgeon" MT44 TC
Currently lying Bond Creek, NC
-----Original Message-----
Sent: Monday, November 14, 2005 11:47 AM
To: trawlerphil@earthlink.net
Subject: Re: RE: Deluo USB Update - good and not so good
Dear Phil,
Thank you for your mail. Regarding your inquiry, our GPS unit can be used
with a PS/2 extension between the GPS and the USB adapter. The cables are
easy to find and are also cheap. We are currently offering a 6ft long PS/2
extension and if you would like you can use even longer cables. Unlike the
limitatoin of the USB format, you should be able to cover a distance of up
to 50ft using a PS/2 extension without any problem.
Best Regards,
Alex with the Deluo Team
------ Original Message ------
Good point!  Maybe the best solution would be to offer a longer cord as an
option?
These guys are usually pretty responsive and I must have sold a bunch of
their units which I feature in my electronic navigation speaking
presentations.
                                       Regards....
Phil Rosch
M/V Curmudgeon MT44 TC
Sent: Sunday, November 13, 2005 9:56 AM
Subject: RE: Deluo USB Update - good and not so good
I agree with your basic premise (more cars than boats
  • though Deluo clearly markets to boaters on their
    website), but still, the cord is too short. I use mine
    in a very wide variety of situations - on many, many
    different boats and many, many different cars (I rent
    a lot of cars). The short cord will be a problem. On
    your MT with sloped windshield, theres no problem
    having a laptop near the helm and setting the Deluo
    forward on the dashboard. Not all helm stations are
    laid out that way. If the windows have a reverse rake
    to them and a flybridge that overhands substantially
    (very common), getting a clear view with a short cord
    is impossible.
Hope all is well there Phil.
Peter
--- trawlerphil trawlerphil@earthlink.net wrote:
Peter, Ive had them for 5 years.  The newer unit
doesnt need to go
outside.  Dash is fine in a car and mine works great
just lying inside the
window on the lower helm.  I wrap the usb/pda
connection with self
amalgamating tape to seal it.  It syncs about twice
as fast as the old unit
which still runs fine.
I think the bottom line is there are more cars on
the road than boats so
they address that market.
Regards....
Phil Rosch
trawlers-and-trawlering-bounces@lists.samurai.com
On Behalf Of
Peter Pisciotta
Sent: Sunday, November 13, 2005 12:28 AM
To: TrawlerList TrawlerList
Cc: support@deluo.com
Subject: T&T: Deluo USB Update - good and not so
good
I recently ordered a replacement for my 2-year old
Deluo USB-powered GPS. The new unit is smaller,
streamline, and waterproof.
Unfortunately, the connector cable is about half the
length of the old one (the length was not readily
disclosed on the website), too short to route
cleanly
out a car window, and definitely too short to find
clear sky from the pilothouse of a boat. Also, there
is no longer a native USB connector - instead, a
USB/PDA pigtail is included. So while a USB
extension
could be used, it would be far from an elegant
solution, plus USB extensions are expensive, and the
pigtail connection may end up outside and exposed to
spray.
Sadly, I can no longer recommend this otherwise fine
product for marine use (or automotive/laptop for
that
matter - fine for a PDA mounted on dashboard).
What other recent USB GPSs are people using these
days?
Peter
www.SeaSkills.com
To unsubscribe send email to
trawlers-and-trawlering-request@lists.samurai.com
with the word
UNSUBSCRIBE and nothing else in the subject or body
of the message.
Trawlers & Trawlering and T&T are trademarks of
Water World
Productions. Unauthorized use is prohibited.
FYI.. Response from Deluo on a discussion Peter and I had... Looks like you can extend them quite far. Regards.... Phil Rosch Old Harbor Consulting M/V "Curmudgeon" MT44 TC Currently lying Bond Creek, NC -----Original Message----- From: support@deluo.com [mailto:support@deluo.com] Sent: Monday, November 14, 2005 11:47 AM To: trawlerphil@earthlink.net Subject: Re: RE: Deluo USB Update - good and not so good Dear Phil, Thank you for your mail. Regarding your inquiry, our GPS unit can be used with a PS/2 extension between the GPS and the USB adapter. The cables are easy to find and are also cheap. We are currently offering a 6ft long PS/2 extension and if you would like you can use even longer cables. Unlike the limitatoin of the USB format, you should be able to cover a distance of up to 50ft using a PS/2 extension without any problem. Best Regards, Alex with the Deluo Team ------ Original Message ------ Good point! Maybe the best solution would be to offer a longer cord as an option? These guys are usually pretty responsive and I must have sold a bunch of their units which I feature in my electronic navigation speaking presentations. Regards.... Phil Rosch Old Harbor Consulting M/V Curmudgeon MT44 TC Currently lying Bond Creek, NC -----Original Message----- From: Peter Pisciotta [mailto:peter@seaskills.com] Sent: Sunday, November 13, 2005 9:56 AM To: trawlerphil@earthlink.net Subject: RE: Deluo USB Update - good and not so good I agree with your basic premise (more cars than boats - though Deluo clearly markets to boaters on their website), but still, the cord is too short. I use mine in a very wide variety of situations - on many, many different boats and many, many different cars (I rent a lot of cars). The short cord will be a problem. On your MT with sloped windshield, theres no problem having a laptop near the helm and setting the Deluo forward on the dashboard. Not all helm stations are laid out that way. If the windows have a reverse rake to them and a flybridge that overhands substantially (very common), getting a clear view with a short cord is impossible. Hope all is well there Phil. Peter --- trawlerphil <trawlerphil@earthlink.net> wrote: > Peter, Ive had them for 5 years. The newer unit > doesnt need to go > outside. Dash is fine in a car and mine works great > just lying inside the > window on the lower helm. I wrap the usb/pda > connection with self > amalgamating tape to seal it. It syncs about twice > as fast as the old unit > which still runs fine. > > I think the bottom line is there are more cars on > the road than boats so > they address that market. > > > Regards.... > > Phil Rosch > Old Harbor Consulting > M/V Curmudgeon MT44 TC > Currently lying Bond Creek, NC > > > -----Original Message----- > From: > trawlers-and-trawlering-bounces@lists.samurai.com > [mailto:trawlers-and-trawlering-bounces@lists.samurai.com] > On Behalf Of > Peter Pisciotta > Sent: Sunday, November 13, 2005 12:28 AM > To: TrawlerList TrawlerList > Cc: support@deluo.com > Subject: T&T: Deluo USB Update - good and not so > good > > I recently ordered a replacement for my 2-year old > Deluo USB-powered GPS. The new unit is smaller, > streamline, and waterproof. > > http://www.deluoelectronics.com/customer/product.php?productid=109 > > Unfortunately, the connector cable is about half the > length of the old one (the length was not readily > disclosed on the website), too short to route > cleanly > out a car window, and definitely too short to find > clear sky from the pilothouse of a boat. Also, there > is no longer a native USB connector - instead, a > USB/PDA pigtail is included. So while a USB > extension > could be used, it would be far from an elegant > solution, plus USB extensions are expensive, and the > pigtail connection may end up outside and exposed to > spray. > > Sadly, I can no longer recommend this otherwise fine > product for marine use (or automotive/laptop for > that > matter - fine for a PDA mounted on dashboard). > > What other recent USB GPSs are people using these > days? > > Peter > www.SeaSkills.com > _______________________________________________ > http://lists.samurai.com/mailman/listinfo/trawlers-and-trawlering > > To unsubscribe send email to > trawlers-and-trawlering-request@lists.samurai.com > with the word > UNSUBSCRIBE and nothing else in the subject or body > of the message. > > Trawlers & Trawlering and T&T are trademarks of > Water World > Productions. Unauthorized use is prohibited.
