USRP1 Support
PH
Pol Henarejos
Mon, May 15, 2017 1:30 PM
Dear all,
I am trying to get my old USRP1 running again but unfortunately I cannot
receive properly. To test it I use benchmark_rate utility.
Whilst transmission seems works properly (no underflows or complaints),
the reception is not working. A lot of "D" appear, regardless the
sampling rate.
I am using UHD 3.9 LTS (but I am able to use my self-compilation from
git source).
The command I use is
benchmark_rate --rx_rate 500e3
and the output is
-- Loading firmware image: C:\CTTC\UHD\share\uhd\images\usrp1_fw.ihx... done
*** Warning! ***
Benchmark results will be inaccurate on USRP1 due to insufficient features.
Creating the usrp device with: ...
-- Opening a USRP1 device...
-- Loading FPGA image: C:\CTTC\UHD\share\uhd\images\usrp1_fpga.rbf... done
-- Using FPGA clock rate of 64.000000MHz...
Using Device: Single USRP:
Device: USRP1 Device
Mboard 0: USRP1
RX Channel: 0
RX DSP: 0
RX Dboard: B
RX Subdev: BasicRX (AB)
TX Channel: 0
TX DSP: 0
TX Dboard: A
TX Subdev: LFTX (AB)
Setting device timestamp to 0...
Testing receive rate 0.500000 Msps on 1 channels
DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
Benchmark rate summary:
Num received samples:    5001216
Num dropped samples:    19148
Num overflows detected:  0
Num transmitted samples: 0
Num sequence errors:    0
Num underflows detected: 0
Num late commands:      0
Num timeouts:            0
Done!
Any clue?
Thank you.
Pol Henarejos
Researcher, MSc
pol.henarejos@cttc.es
Centre Tecnològic de Telecomunicacions de Catalunya (CTTC)
Av. Carl Friedrich Gauss, 7
08860 Castelldefels, Barcelona (Spain)
Tel: +34 93 645 29 00  Ext: 2177
Fax. +34 93 645 29 01
www.cttc.es
Dear all, I am trying to get my old USRP1 running again but unfortunately I cannot receive properly. To test it I use benchmark_rate utility. Whilst transmission seems works properly (no underflows or complaints), the reception is not working. A lot of "D" appear, regardless the sampling rate. I am using UHD 3.9 LTS (but I am able to use my self-compilation from git source). The command I use is benchmark_rate --rx_rate 500e3 and the output is -- Loading firmware image: C:\CTTC\UHD\share\uhd\images\usrp1_fw.ihx... done *** Warning! *** Benchmark results will be inaccurate on USRP1 due to insufficient features. Creating the usrp device with: ... -- Opening a USRP1 device... -- Loading FPGA image: C:\CTTC\UHD\share\uhd\images\usrp1_fpga.rbf... done -- Using FPGA clock rate of 64.000000MHz... Using Device: Single USRP: Device: USRP1 Device Mboard 0: USRP1 RX Channel: 0 RX DSP: 0 RX Dboard: B RX Subdev: BasicRX (AB) TX Channel: 0 TX DSP: 0 TX Dboard: A TX Subdev: LFTX (AB) Setting device timestamp to 0... Testing receive rate 0.500000 Msps on 1 channels DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD Benchmark rate summary: Num received samples: 5001216 Num dropped samples: 19148 Num overflows detected: 0 Num transmitted samples: 0 Num sequence errors: 0 Num underflows detected: 0 Num late commands: 0 Num timeouts: 0 Done! Any clue? Thank you. -- Pol Henarejos Researcher, MSc pol.henarejos@cttc.es Centre Tecnològic de Telecomunicacions de Catalunya (CTTC) Av. Carl Friedrich Gauss, 7 08860 Castelldefels, Barcelona (Spain) Tel: +34 93 645 29 00 Ext: 2177 Fax. +34 93 645 29 01 www.cttc.es
MM
Marcus Müller
Mon, May 15, 2017 1:37 PM
Hi Pol,
Ds on USB2 are really really rare. I don't have a USRP1 to test here,
locally, but my first suspect would be your Operating System's USB
stack. Can you try to use the device on a different OS, maybe on a
different machine?
To try, you could download and burn the GNU Radio liveSDR environment[1]
to an USB stick, and boot just any PC with it. For your downloading
pleasure, I'd recommend either using the torrent file, or the eu2 Mirror
(which happens to be my server).
Best regards, and thanks,
Marcus
[1] https://wiki.gnuradio.org/index.php/GNU_Radio_Live_SDR_Environment
On 05/15/2017 03:30 PM, Pol Henarejos via USRP-users wrote:
Dear all,
git source).
and the output is
*** Warning! ***
features.
done
Mboard 0: USRP1
RX Channel: 0
RX DSP: 0
RX Dboard: B
TX Channel: 0
TX DSP: 0
TX Dboard: A
Num timeouts:            0
Done!
Any clue?
Thank you.
USRP-users mailing list
USRP-users@lists.ettus.com
Hi Pol, Ds on USB2 are really really rare. I don't have a USRP1 to test here, locally, but my first suspect would be your Operating System's USB stack. Can you try to use the device on a different OS, maybe on a different machine? To try, you could download and burn the GNU Radio liveSDR environment[1] to an USB stick, and boot just any PC with it. For your downloading pleasure, I'd recommend either using the torrent file, or the eu2 Mirror (which happens to be my server). Best regards, and thanks, Marcus [1] https://wiki.gnuradio.org/index.php/GNU_Radio_Live_SDR_Environment On 05/15/2017 03:30 PM, Pol Henarejos via USRP-users wrote: > Dear all, > > I am trying to get my old USRP1 running again but unfortunately I > cannot receive properly. To test it I use benchmark_rate utility. > Whilst transmission seems works properly (no underflows or > complaints), the reception is not working. A lot of "D" appear, > regardless the sampling rate. > > I am using UHD 3.9 LTS (but I am able to use my self-compilation from > git source). > The command I use is > > benchmark_rate --rx_rate 500e3 > > and the output is > > -- Loading firmware image: > C:\CTTC\UHD\share\uhd\images\usrp1_fw.ihx... done > *** Warning! *** > Benchmark results will be inaccurate on USRP1 due to insufficient > features. > > Creating the usrp device with: ... > -- Opening a USRP1 device... > -- Loading FPGA image: C:\CTTC\UHD\share\uhd\images\usrp1_fpga.rbf... > done > -- Using FPGA clock rate of 64.000000MHz... > Using Device: Single USRP: > Device: USRP1 Device > Mboard 0: USRP1 > RX Channel: 0 > RX DSP: 0 > RX Dboard: B > RX Subdev: BasicRX (AB) > TX Channel: 0 > TX DSP: 0 > TX Dboard: A > TX Subdev: LFTX (AB) > > Setting device timestamp to 0... > Testing receive rate 0.500000 Msps on 1 channels > DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD > > Benchmark rate summary: > Num received samples: 5001216 > Num dropped samples: 19148 > Num overflows detected: 0 > Num transmitted samples: 0 > Num sequence errors: 0 > Num underflows detected: 0 > Num late commands: 0 > Num timeouts: 0 > > > Done! > > Any clue? > > Thank you. > > > > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
M
mleech@ripnet.com
Mon, May 15, 2017 2:23 PM
Are you perhaps running this inside a VM?
On 2017-05-15 09:30, Pol Henarejos via USRP-users wrote:
Dear all,
and the output is
*** Warning! ***
Mboard 0: USRP1
RX Channel: 0
RX DSP: 0
RX Dboard: B
TX Channel: 0
TX DSP: 0
TX Dboard: A
Num timeouts:            0
Done!
Any clue?
Thank you.
Are you perhaps running this inside a VM? On 2017-05-15 09:30, Pol Henarejos via USRP-users wrote: > Dear all, > > I am trying to get my old USRP1 running again but unfortunately I cannot receive properly. To test it I use benchmark_rate utility. > Whilst transmission seems works properly (no underflows or complaints), the reception is not working. A lot of "D" appear, regardless the sampling rate. > > I am using UHD 3.9 LTS (but I am able to use my self-compilation from git source). > The command I use is > > benchmark_rate --rx_rate 500e3 > > and the output is > > -- Loading firmware image: C:\CTTC\UHD\share\uhd\images\usrp1_fw.ihx... done > *** Warning! *** > Benchmark results will be inaccurate on USRP1 due to insufficient features. > > Creating the usrp device with: ... > -- Opening a USRP1 device... > -- Loading FPGA image: C:\CTTC\UHD\share\uhd\images\usrp1_fpga.rbf... done > -- Using FPGA clock rate of 64.000000MHz... > Using Device: Single USRP: > Device: USRP1 Device > Mboard 0: USRP1 > RX Channel: 0 > RX DSP: 0 > RX Dboard: B > RX Subdev: BasicRX (AB) > TX Channel: 0 > TX DSP: 0 > TX Dboard: A > TX Subdev: LFTX (AB) > > Setting device timestamp to 0... > Testing receive rate 0.500000 Msps on 1 channels > DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD > Benchmark rate summary: > Num received samples: 5001216 > Num dropped samples: 19148 > Num overflows detected: 0 > Num transmitted samples: 0 > Num sequence errors: 0 > Num underflows detected: 0 > Num late commands: 0 > Num timeouts: 0 > > Done! > > Any clue? > > Thank you. > > _______________________________________________ > USRP-users mailing list > USRP-users@lists.ettus.com > http://lists.ettus.com/mailman/listinfo/usrp-users_lists.ettus.com
