Re: GNU Radio Companion N310 GPIO Sink/Source block
WJ
White, Joshua J
Wed, Jun 29, 2022 6:37 PM
Thanks for all the replies. I’m going to start with a Python block and see if I can get it to do what I need it to do, and if not I’ll bite the bullet and try to write an OOT module.
Very respectfully,
Joshua White
Precision Timing Systems Engineer
Engineering & Support Solutions Directorate
www.riversideresearch.org http://www.riversideresearch.org/
T: 937.986.3153 | F: 937.431.3811
This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain proprietary, confidential or privileged information or otherwise be protected by law. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please notify the sender and destroy all copies and the original message.
Sent: Tuesday, June 28, 2022 7:56 PM
To: Fabien PELLET fpellet.f4ctz@free.fr
Cc: usrp-users usrp-users@lists.ettus.com; undefined discuss-gnuradio@gnu.org; White, Joshua J jjwhite@RiversideResearch.org
Subject: Re: GNU Radio Companion N310 GPIO Sink/Source block
Joshua,
Generally Fabien is right. To exercise the full feature set of the GPIO you would likely need an OOT block. However, if only limited performance and features are needed then you might get away with using the Python embedded block or Python snippet in GRC to implement something quick and easy. This was the route I took to control an external TX/RX switch. I imagine any low-rate control would be feasible.
Jared.
On Tue, Jun 28, 2022 at 5:06 PM Fabien PELLET <fpellet.f4ctz@free.fr mailto:fpellet.f4ctz@free.fr > wrote:
Hi Joshua,
I'm also using GPIO on LFTX and LFRX on a N210 and I can tell you that you will not find source or sink that deal with that IO as far as I know.
The only way to use them is to write an OOT that uses the UHD methods.
Best regards,
Fabien, F4CTZ
---- White, Joshua J a écrit ----
(Cross-posted on usrp-users and discuss-gnuradio)
For anyone who's familiar with using the USRP3 (specifically the N310) with GNU Radio:
I'm trying to create a flowgraph in gnu radio companion that incorporates reading a value from one pin on the front panel GPIO of the N310 and writing a value to another pin. I'm looking for a source/sink block for GNU Radio companion that can accomplish this. Has anyone done this previously, or can anyone point me in the right direction? I have very little experience with GNU Radio and have no expertise in programming OOT modules. Thank you for any help you can provide.
Very respectfully,
Joshua White
T: 937.986.3153 tel:937.986.3153  | F: 937.431.3811 tel:937.431.3811
Thanks for all the replies. I’m going to start with a Python block and see if I can get it to do what I need it to do, and if not I’ll bite the bullet and try to write an OOT module. Very respectfully, Joshua White Precision Timing Systems Engineer Engineering & Support Solutions Directorate www.riversideresearch.org <http://www.riversideresearch.org/> T: 937.986.3153 | F: 937.431.3811 This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain proprietary, confidential or privileged information or otherwise be protected by law. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please notify the sender and destroy all copies and the original message. From: U L <jareddpub@gmail.com> Sent: Tuesday, June 28, 2022 7:56 PM To: Fabien PELLET <fpellet.f4ctz@free.fr> Cc: usrp-users <usrp-users@lists.ettus.com>; undefined <discuss-gnuradio@gnu.org>; White, Joshua J <jjwhite@RiversideResearch.org> Subject: Re: GNU Radio Companion N310 GPIO Sink/Source block Joshua, Generally Fabien is right. To exercise the full feature set of the GPIO you would likely need an OOT block. However, if only limited performance and features are needed then you might get away with using the Python embedded block or Python snippet in GRC to implement something quick and easy. This was the route I took to control an external TX/RX switch. I imagine any low-rate control would be feasible. Jared. On Tue, Jun 28, 2022 at 5:06 PM Fabien PELLET <fpellet.f4ctz@free.fr <mailto:fpellet.f4ctz@free.fr> > wrote: Hi Joshua, I'm also using GPIO on LFTX and LFRX on a N210 and I can tell you that you will not find source or sink that deal with that IO as far as I know. The only way to use them is to write an OOT that uses the UHD methods. Best regards, Fabien, F4CTZ ---- White, Joshua J a écrit ---- (Cross-posted on usrp-users and discuss-gnuradio) For anyone who's familiar with using the USRP3 (specifically the N310) with GNU Radio: I'm trying to create a flowgraph in gnu radio companion that incorporates reading a value from one pin on the front panel GPIO of the N310 and writing a value to another pin. I'm looking for a source/sink block for GNU Radio companion that can accomplish this. Has anyone done this previously, or can anyone point me in the right direction? I have very little experience with GNU Radio and have no expertise in programming OOT modules. Thank you for any help you can provide. Very respectfully, Joshua White Precision Timing Systems Engineer Engineering & Support Solutions Directorate www.riversideresearch.org <http://www.riversideresearch.org/> T: 937.986.3153 <tel:937.986.3153> | F: 937.431.3811 <tel:937.431.3811> This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain proprietary, confidential or privileged information or otherwise be protected by law. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please notify the sender and destroy all copies and the original message.
