View all threadsHello Ettus Experts,
we have a Linux-based SDR application up and running that currently uses X300 USRPs as Interfaces, does some sample processing on the realtime data stream and then does some further OpenCL-based processing on those results.
Now we are consider buying a N310 for this application. According to the Xilinx website, Xilinx supports compiling OpenCL kernels for the Zynq device built into the N310. So it would be great if our application could be ported to the N310 running the sample processing on the ARM and the OpenCL work would be done on the FPGA which has far as I know has some resources left in the standard image used by the N310.
However I have no practical experience with Xilinx Tools and never took a deep look at the Ettus FPGA configurations, so before buying an N310 and finding out that this approach is impossible for some reason I’d ask if the experts round here if they see any problem in trying to get this kind of setup working? Furthermore, is building a highly custom yocto based image for the ARM an option supported by Ettus or is the advice to stick to the prebuilt Linux Image supplied by Ettus for the N310?
Thanks in Advance
Janos Buttgereit
