View all threadsHi all,
I just updated 4.1.0.1 --> 4.1.0.5, and unfortunately DPDK support was broken by commit a629ce3a46. Here's a quick trace of the problem:
(1) The commit increased MPMD_10GE_DATA_FRAME_MAX_SIZE from 7972 to 8016.
(2) In mpmd_link_if_ctrl_udp.cpp, this constant is passed as the max frame size to discover_mtu(), which then tries to send a 8016-byte buffer via dpdk_simple::send.
(3) dpdk_simple::send asserts if provided a buffer size >8000. This is because its constructor always makes a udp_dpdk_link object with default link parameters, which hard-codes send_frame_size and recv_frame_size to be to 8000 (toward the bottom of dpdk_simple.cpp).
Unfortunately, the behavior cannot be circumvented using args. A quick fix might be to increase the hard-coded link params in dpdk_simple, but I noted that a value of 8000 is also hard-coded in a couple other places (e.g. DEFAULT_FRAME_SIZE in dpdk_common.cpp). In the meantime, my temporary solution is to locally revert commit a629ce3a46 until it can be confirmed with DPDK with 10GbE.
Cheers,
David Raeman
Synoptic Engineering
On 2022-02-09 21:17, David Raeman wrote:
Hi all,
Cheers,
David Raeman
USRP-users mailing list --usrp-users@lists.ettus.com
To unsubscribe send an email tousrp-users-leave@lists.ettus.com
David:
Thanks very much for your diligence on this. I'll be passing this
information along to Ettus/NI developers.
I see that you've already posted an issue in the public UHD
bug-tracker. Thanks.
