I've actually done this... Lady Heather has built in "alternate disciplining" algorithm for the Thunderbolt. I tricked up some code to use this along with a TAPR-TICC to make a GPSDO. The first (rather crude) hack worked pretty well. I haven't had a chance to do it properly... yet.
The idea was to allow the 5071A to run with the CBT in standby for applications that do not require the cesium goodness.
A fun (and actually very useful) project would be to turn it into a
GPSDO
My experiment is not going well so far. I have NOT done any tuning. Just connected 1 pps out from GPS to 1 pps IN on 5071A. Frequency keeps increasing, which I think is weird. I thought it might just be unstable without proper parameters, but no. Over last 24 hours, it kept going up. I was about to start reading the 5071A manual. Likely as TVB says, it will likely be needing quite a bit of refining loop parameters. One unknown is, in this current state (fault), if OCXO is even steerable. 1 pps WAS detected and menu option did tell me so.
I didn't know you can put 5071A in (Cs tube only) STAND-BY mode... Mine is dead so it's in permanent stand-by. It's initial boot sequence detects this and shuts it down.
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
On Thursday, December 19, 2019, 5:34:55 PM EST, Mark Sims <holrum@hotmail.com> wrote:
GPSDO
time-nuts mailing list -- time-nuts@lists.febo.com
To unsubscribe, go to http://lists.febo.com/mailman/listinfo/time-nuts_lists.febo.com
Hi
The PPS input on the 5071 does not set the frequency of the device. To do so would “break” the
Cs ( = you use the beam to get frequency). The only thing the PPS input gets used for is to reset
the time to sync with UTC.
Bob
On Dec 19, 2019, at 5:56 PM, Taka Kamiya via time-nuts time-nuts@lists.febo.com wrote:
(Mr.) Taka Kamiya
KB4EMF / ex JF2DKG
GPSDO
