View all threadsI sent the follwing to discuss-gnuradio-list -- but it has never been
published..
so I will try it here:
After compiling Gnuradio 3.5.3, I got errors (seg faults) and other
indication to upgrade the very old uhd and fpga firmware software for
USRP N200 r2.
I got the images 003.004.000 and uhd source. I compiled and installed
the source on ubuntu 11.10
every step as expected from the building guides.
But trying to update the firmware-fpga fails
After powerdown und hold S2, the N200 did work with the follwing output
-------------------8<------------------
./usrp_n2xx_net_burner.py --addr=192.168.10.2 --fw=uhd-images_003.004.000-release/share/uhd/images/usrp_n200_fw.bin
USRP-N2XX found.
Flash size: 4194304
Sector size: 65536
Begin firmware write: this should take about 1 second...
Erasing 31744 bytes at 3145728
Writing image
Verifying data
Read back 16383 bytes
Success.
Time elapsed: 1.149688 seconds
./usrp_n2xx_net_burner.py --addr=192.168.10.2 --fpga=uhd-images_003.004.000-release/share/uhd/images/usrp_n200_r2_fpga.bin
USRP-N2XX found.
Flash size: 4194304
Sector size: 65536
Begin FPGA write: this should take about 1 minute...
Erasing 1572864 bytes at 1572864
Traceback (most recent call last):
File "./usrp_n2xx_net_burner.py", line 522, in <module>
else: burner.burn_fw(fw=options.fw, fpga=options.fpga, reset=options.reset, safe=options.overwrite_safe, check_rev=not options.dont_check_rev)
File "./usrp_n2xx_net_burner.py", line 310, in burn_fw
self.erase_image(image_location, FPGA_IMAGE_SIZE_BYTES)
File "./usrp_n2xx_net_burner.py", line 452, in erase_image
in_pkt = self.send_and_recv(out_pkt)
File "./usrp_n2xx_net_burner.py", line 245, in send_and_recv
return self._sock.recv(UDP_MAX_XFER_BYTES)
socket.timeout: timed out
this leaves the system without the expeceted functionality
help is very welcome to get the system working again
thanks in advance
Michael Hartje
Prof. Dr.-Ing. Michael Hartje
Labor Hochspannungstechnik / Labor elektrische Messtechnik
Neustadtswall 30; D-28199 Bremen
Tel +49 421 5905-3444 FAX +49 421 5905-3476
Looks like a packet is lost during the burning process. Can you try this
with a different PC or ethernet card? Does the problem follow?
-josh
