reject call problem
WH
waleed hassan
Mon, Feb 9, 2009 7:29 AM
hi all
i am new on pjsip ,and i am using pjsip on symbian , when i make call to anoher mobile and then end the call from the originator of call the other side still display the incoming call and when i press answer call connected :) how can i solve this problem , i really stuck and don't know what i should do ,
please help me on first time of using pjsip
thanks for every one
Check out the new and improved services from Windows Live. Learn more!
http://clk.atdmt.com/UKM/go/132630768/direct/01/
hi all i am new on pjsip ,and i am using pjsip on symbian , when i make call to anoher mobile and then end the call from the originator of call the other side still display the incoming call and when i press answer call connected :) how can i solve this problem , i really stuck and don't know what i should do , please help me on first time of using pjsip thanks for every one _________________________________________________________________ Check out the new and improved services from Windows Live. Learn more! http://clk.atdmt.com/UKM/go/132630768/direct/01/
BP
Benny Prijono
Tue, Feb 10, 2009 11:20 AM
On Mon, Feb 9, 2009 at 7:29 AM, waleed hassan ronaldo_1001@hotmail.comwrote:
hi all
should do ,
In cases like these, call trace always helps. You can get the call trace
either by activating the logging facilities on both ends (preferable), or
otherwise capture the network traffic with Wireshark or something.
cheers
Benny
On Mon, Feb 9, 2009 at 7:29 AM, waleed hassan <ronaldo_1001@hotmail.com>wrote: > hi all > i am new on pjsip ,and i am using pjsip on symbian , when i make call to > anoher mobile and then end the call from the originator of call the other > side still display the incoming call and when i press answer call connected > :) how can i solve this problem , i really stuck and don't know what i > should do , > please help me on first time of using pjsip > In cases like these, call trace always helps. You can get the call trace either by activating the logging facilities on both ends (preferable), or otherwise capture the network traffic with Wireshark or something. cheers Benny
