Hi John,
Here's what I was able to find out recently about older Borg Warner Velvet
Drive gears:
There were four models; two inline (Model #s 10-17 & 10-18; available ratios:
1.00, 1.52, 1.91, 2.10, 2.57, 2.91 : 1 ) and two (CR2) drop center (10-13 &
10-14; ratios: 1.58, 2.03, 2.47, 2.93 : 1). The drop center versions are no
longer manufactured. Velvet Drive Corp. (spun off from Borg-Warner in the
1990s) continues to build inline models (don't know if they're the same
ratios), but the drop centers are obsolete and "orphaned" (my word) in the
sense that no one is making parts for them. The BW drop center gears
reportedly have a "drop" of about 1.5 inches from the plane where the input
shaft goes in the housing to where the output shaft comes out.
There is a company in Ft. Lauderdale (Transmission Marine, Inc.) which does
repair and rebuild these gears. I visited there recently and learned that
they do have rebuilt trannys in stock, which they sell on a sliding scale that
depends on the condition of the "core" you're trading in. Briefly, the scale
can go as high as $8,000; with the top price for rebuilding a core that is
totally shot. They have a limited number of parts manufactured for them
(primarily output shafts), but by and large they're using reconditioned used
parts to rebuild these gears. Hence the importance of the condition of your
core in determining your price. All of the foregoing figures are for complete
rebuilds, not lesser repairs.
Other alternatives I discussed with them included replacing them altogether
with other brand drop center type gears, or new Velvet Drive inline gears.
Prices ranged from $3,200 for a Twin Disc "drop type" plus $3,000 installation
(because the offset distance is different than that of the BW gear, thus
requiring repositioning of the engine and therefore its exhaust lines, control
cables, etc.), to $3,200 for a new inline Velvet Drive, again with similar
installation costs for repositioning the engine. They recommended putting in
an inline if complete replacement is needed. Please note that all of the
quotes were informal, NOT written, guaranteed estimates! They also told me
that these gears, when mounted behind low power, slow turning engines such as
120HP Lehmans (my case) and properly cared for, will last a VERY long time.
They are strongly built and well engineered.
TMI's website is www.marinegears.com, and their telephone number is (954)
467-1540. (usual disclaimers)
Nils & Nancy Florman
M/V Second Act
Albin 43 Trunk
Surfside, FL
